    MMM-MyCalendar
    109 Posts 40 Posters 152.1k Views 38 Watching
    • C Offline
      cola0927 @justjim1220
      @justjim1220 Cool! Thank you so much!
      • H Offline
        hoveeman
        This module is great! Thank you!
        Is it possible to add a header/title for the day of the week with the items below it? Essentially you would see Monday and the corresponding items below it. Then Tuesday and it’s items, and so forth.
        Any thoughts?
          j.e.f.f Project Sponsor Module Developer @hoveeman
          @hoveeman yeah should be doable. Let me take a look over the next few days.
          H B 2 Replies Last reply Reply Quote 0
          • H Offline
            hoveeman @j.e.f.f
            @j-e-f-f Awesome, that would be great! Really appreciate it!
            Also, I would envision if there were no items for Wednesday it would not list anything and go straight to Thursday. Thoughts?
            • bokifideB Offline
              bokifide
              Hi! Love the module :). Just wondering if there’s a way to space out the columns enough so that the titles don’t get cut off:
              Thank you for your work!!
              Boki
              • MedoM Offline
                Medo
                Hey there!
                For some time now, i have the following issue:
                My MMM-MyCalendar is showing dates wrongly (one day in the past) although they are correct in the used ics-file.
                I moved my question over to the “troubleshooting” section (as it seems it fits better there):
                https://forum.magicmirror.builders/topic/8963/mmm-mycalendar-showing-wrong-dates-days-one-day-in-the-past
                  j.e.f.f Project Sponsor Module Developer @bokifide
                  @bokifide You would need to write some custom CSS to adjust the width of the containing column. The module is designed to used all of the space available in its container.
                  • V Offline
                    VinGroot
                    I’d like to have absolute days in my calendar, but all I see is ‘today’, Saturday (without date), etc.
                    My config is:
                    maximumEntries: 8,
                    useRelativeDates: false,
                    joiningWord: “om”,
                    maxTitleLength: 48,
                    dateFormat: “D MMMM YYYY”,
                    timeFormat: “HH:mm”,
                    urgency: 0,
                    getRelative: 0,
                    * secret *]
                    Am I doing something wrong?
                    Some things like timeFormat (HH:mm), maxTitleLength and joiningWord work fine.
                    • V Offline
                      VinGroot
                      This post is deleted!
                      • V Offline
                        VinGroot
                        When I set maximumEntries: 8 I only see items 3 items.
                        I did some testing and I think the reason I only see 3 items is because some items are excluded.
                        I think the excluded items are counted as well.
                          DolphinScientist
                          Hi @j-e-f-f , thanks for the great module. The config indicates that the icons are customizable using Font Awesome, but the behavior and the code (line ~181) seem to indicate otherwise. Any chance we could get it back? Do you know how you would want it implement with the svg system you have?
                            My module does not have a configurable icon. It wouldn’t work with the calendar icon with the date inside.
                            I based my modyle off the default calendar midule included wth MM. that one has a configurablenicon and perhaps I forgot to remove the instruction in my version.
                            Mine never had a configurable icon. I might enable a few options that would work with the date number inside, but at the moment you just get the one.
                            • H Offline
                              hnsy
                              Hi @j-e-f-f , thanks a lot for your really great modules. I really appreciate the style and convenience of your modules.
                              As I am using MyCalendar now for a while, I was wondering, if there is a possibility to display time-ranges? I mean the start date of a range is displayed, but when an event is taking place for, let’s say three days, currently I can only display the first day (start time).
                              Is there a possibility that all (3) days would appear in the list?
                              Maybe it is already integrated and I just didn’t get it.
                              Once more: Thumbs up for your work!!
                              Cheers, HNSY
                                j.e.f.f Project Sponsor Module Developer @hnsy
                                @hnsy I’m not sure… I’m using the default calendar code to retrieve the calendar data. I’ve only customized the display portion. If multi-day blocks are included in the data then it should be possible. I’ll have to take a look.
                                • bdeelmanB Offline
                                  bdeelman @j.e.f.f
                                  • N Offline
                                    nagaculun
                                    • N Offline
                                      nagaculun
                                      • G Offline
                                        ganget
                                        • F Offline
                                          Fonfon
                                          is it possible to color text ?
                                          because when i you have a wallpaper sometimes text is not visible.
                                          thanks for your help
                                            j.e.f.f Project Sponsor Module Developer @Fonfon
                                            @Fonfon No, but you can add a background colour to the module to make the text stand out better. try something like this in your custom.css file:
                                            .MMM-MyCalendar .module-content {
                                              background-color: rgba(0,0,0,0.5);
                                            The first three parameters 0,0,0 mean black, and the fourth parameter 0.5 is the level of transparency. Specify a decimal between 0 and 1, where 0 is fully transparent, and 1 is fully opaque.
                                            F 1 Reply Last reply Reply Quote 1
                                            • 6
                                            • 5 / 6
