    [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
    602 Posts 67 Posters 2.1m Views 68 Watching
    • Cr4z33C Offline
      Cr4z33 @shbatm
      @shbatm thanks for the reply.
      I can confirm that I’ve got rid of the white frame by following @evroom 's suggestion (thanks mate).
      Back in topic I’ve uploaded here the log 'cause I am not sure whether it is actually reporting a problem with MMM-RTSPStream or not. :thinking_face:
      Looking at it it says MMM-RTSPStream.js:161 MMM-RTSPStream has resumed... after two questions I made to Google Assistant, but I found no mention about RTSP pausing or stopping.
      However I can confirm that omx_stream has indeed stopped from running! :frowning_face_with_open_mouth:
       pm2 status
      │ Name        │ id │ mode │ status │ ↺       │ cpu │ memory │
      │ mm          │ 0  │ N/A  │ fork   │ online  │ 0   │ 0%     │ 2.5 MB   │
      │ omx_stream1 │ 1  │ N/A  │ fork   │ stopped │ 0   │ 0%     │ 0 B      │
      • ? Offline
        A Former User @shbatm
        @shbatm @Cr4z33
        It might be due to collision of stream output from multi-source (omxplayer and my voice output)
        I’m not an expert of *nix system, so I cannot give a suggestion about using mixer(ALSA), but…
        in MMM-AssistantMk configuration, this could be help (not tested by myself. I don’t have RTSP-stream…)
        onIdle: {
          timer: 1000*10, //After 10sec of last query,
          command: "RTSP_ACTIVATE"
        onActivate: {
          timer: 0,
          command: "RTSP_DEACTIVATE"
        command: {
          "RTSP_ACTIVATE": {
            notificationExec: {
              notification: "RTSP-PLAY",
              payload: "all"
          "RTSP_DEACTIVATE": {
            notificationExec: {
              notification: "RTSP-STOP",
              payload: "all"
        • Cr4z33C Offline
          Cr4z33 @Guest
          Thanks to @sean I’ve quickly fixed the RTSP issue by applying what he wrote here.
          So if you are like me using both MMM-RTSPStream and MMM-AssistantMk2, open the config and in the MMM-AssistantMk2 module section replace
          with
          				onIdle: {
          				onActivate: {
          				  timer: 0,
          				command: {
          				  "RTSP_ACTIVATE": {
          				    notificationExec: {
          				      payload: "all"
          				    notificationExec: {
          				      payload: "all"
          That way the stream will NEVER stop even if enquiring Google Assistant! :grinning_face_with_smiling_eyes:
          Thank you @shbatm for willing to help me too.
          • ? Offline
            A Former User @Cr4z33
            @cr4z33
            Frankly said, it might not be due to my config modifying suggestion. (Because IT SHOULD PAUSE AND RESUME, but you said NEVER STOP)
            I think it is due to use HDMI as output. I don’t know about it, but it might be able to mix from multi-sources.
            • Cr4z33C Offline
              Cr4z33 @Guest
              @sean yeah I actually forgot to mention that the RTSP outputs to HDMI while Google Assistant outputs to a RPI Voice HAT speaker. :grimacing_face:
              • ? Offline
                @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                That’s how it works. not by my code. :D
                • Cr4z33C Offline
                  Cr4z33 @Guest
                  @sean of course. :winking_face:
                  To everybody else: I removed the white frame and forgot to ask how to move the streaming windows.
                  It is now offset compared to its module position. :confused_face:
                  I guess I need to edit something in
                  .MMM-RTSPStream .canvas {
                    position: absolute;
                    z-index: 1;
                    left: 50%;
                    top: 50%;
                    /*width: 352px;
                    height: 240px;*/
                    -webkit-transform: translate(-50%, -50%);
                      width: 100%;
                  height: 100%;
                  right?
                    shbatm Module Developer @Cr4z33
                    Play with the moduleOffset and absPosition config options. Search this forum for those and check out the README on GitHub for details of what each one does.
                    • cowboysdudeC Offline
                      cowboysdude Module Developer @barnosch
                      @barnosch Are you getting any console.log errors or PM2 errors?
                      • evroomE Offline
                        evroom
                        I tried playing with absPosition, but it does not do what is expected.
                        First of all:
                        absPosition: This overrides the automatic window and moduleOffset settings.
                        Second of all:
                        Format: { top: XX, right: XX, bottom: XX, left: XX } where XX is the pixel position on the screen.
                        This is not quite true.
                        The omxplayer options say: --win ‘x1 y1 x2 y2’
                        This would translate to: { top: XX, left: XX, right: XX, bottom: XX }
                        In principle it is a rectangular with coordinates (x1,y1) - (x2,y2).
                        But most important:
                        Whatever I do, including the module position, the video window is ALWAYS in the center of the screen, for the FULL width of the screen.
                        I will try playing with the other parameters a bit.
                        MagicMirror version: 2.33.0
                        Test environment:
                        MagicMirror version: v2.33.0
                        • 11
                        • 12
                        • 13
                        • 14
                        • 15
                        • 60
                        • 61
                        • 13 / 61
