    [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
    602 Posts 67 Posters 2.2m Views 68 Watching
      shbatm Module Developer @shbatm
      @djuscha I’ve reverted the changes that I think broke the master channel. Please try updating your module to the current master branch and test.
        shbatm Module Developer @Cr4z33
        @cr4z33 Added something that might help. Please use the develop branch and update your change channel commands to :
        notification: “RTSP-PLAY”,
        payload: { stream:“stream1”, stopOthers: true }
        EDIT: Nevermind, don’t do that. I fixed the glitch on the develop channel that was starting more than one stream when rotateStreams: true was set. Please try that and see if it works now.
          anthony6608 @shbatm
          @shbatm Hey, I updated issue #33 with the errors I am seeing when you have a chance. Also, should I run this update although I am using the VLCplayer method? Let me know what you think. Thanks again for all your help!
          • BKeyportB Offline
            BKeyport Module Developer
            I’m unable to get this module to load and run with FFMPeg anymore - as of 3PM 1/4/19 (Pacific Time (Seattle))
            Update was applied as of that time.
            I don’t know how to retrieve logs.
            – Bug filed on github - https://github.com/shbatm/MMM-RTSPStream/issues/34
              @djuscha, @Cr4z33 @barnosch @anthony6608 @bhepler @evroom, and anyone else using this module:
              I just pushed a bunch of bug fixes for OMX Player to the develop branch. Please test and let me know if you are still seeing the same issues.
              Fixes include:
              • App closing now spawns a new process to actually kill the OMX streams, it was getting cut off in the middle of closing everything due to it being an async process and leaving streams open.
              • Wait for DOM to be shown before calling to start the streams–this was causing the Fullscreen on Resume problems.
              • Only start one stream at a time if we’re in RotateStreams mode
              • Can jump to a specific stream in RotateStreams mode using notifications
              • Fixed and cleaned up all notifications and control from other modules
              • Fixed broken key bindings after MMM-KeyBindings upgrade
              • Fixed issue where module was trying to connect to PM2 while it was already connected (e.g. stop stream 1 and start stream 2 back to back).
              To switch branches:
              cd ~/MagicMirror/modules/MMM-RTSPStream
              sudo rm -R node_modules/
              git fetch --al
              git checkout develop
              git pull
              npm install
              Cr4z33C D 2 Replies Last reply Reply Quote 0
              • evroomE Offline
                evroom
                @shbatm
                I installed the new changes according your procedure.
                I am using omxplayer for a RTSP stream of a IP cam.
                I do not use rotation or any other fancy stuff.
                I see the same issue as before: omx_stream1 has status stopped and when I click on the play button it also will not start.
                I stopped and started mm 2 times and even did a complete reboot
                It only can be started using
                $ pm2 start omx_stream1
                Another restart of mm shows that the omx_stream1 is being stopped, but never restarted.
                After ever mm restart I will need to perform:
                MagicMirror version: 2.37.0
                • evroomE Offline
                  evroom
                  I noticed this in pm2 logs (do not see this after every mm restart):
                  0|mm  | Connecting socket for: MMM-RTSPStream
                  0|mm  | PM2: Stopping all OMXPlayer Streams...
                  0|mm  | Sockets connected & modules started ...
                  0|mm  | Launching application.
                  0|mm  | PM2: Checking if omx_stream1 is running...
                  0|mm  | PM2: Stopping omx_stream1...
                  PM2      | Stopping app:omx_stream1 id:1
                  1|omx_stream1  | Video codec omx-h264 width 640 height 360 profile 77 fps 30.000000
                  1|omx_stream1  | Subtitle count: 0, state: off, index: 1, delay: 0
                  1|omx_stream1  | V:PortSettingsChanged: 640x360@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                  1|omx_stream1  | have a nice day ;)
                  PM2            | App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                  PM2            | pid=2104 msg=process killed
                  In this case it was tried to start the stream, but it exited.
                  Starting it by hand makes it work again.
                  • Cr4z33C Offline
                    Cr4z33 @shbatm
                    @shbatm I ran the develop update.
                    With omxplayer (and autoStart: false) I see stream labels changing when giving a voice command, but then no stream is starting.
                    With vlc nothing happens, not a single stream starting by voice command.
                      djuscha @shbatm
                      @shbatm
                      have made yesterday update without develoop only
                      git pull
                      npm install
                      everything runs :)
                       Name        │ id │ mode │ status │ ↺      │ cpu │ memory │
                      │ mm          │ 0  │ N/A  │ fork   │ online │ 0   │ 0%     │ 2.5 MB   │
                      │ omx_stream1 │ 1  │ N/A  │ fork   │ online │ 17  │ 0%     │ 2.8 MB   │
                      │ omx_stream2 │ 2  │ N/A  │ fork   │ online │ 6   │ 0%     │ 2.8 MB
                      Many Thanks .
                        shbatm Module Developer @evroom
                        @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                        There was a problem with the steams not stopping on a restart, so the module sends a stop command first whenever it starts, do you have autoStart: true in your config?
                        evroomE 1 Reply Last reply Reply Quote 0
                          @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                          OK. I’ll check this later today, the notification RTSP-PLAY should switch and start the stream so that’s an issue.
                            @Cr4z33 try inserting this.playing = true; at Line 574 as the first line in the if statement and see if that works. I’ll test later today.
                            EDIT: Just pushed an update. Please try the latest release in develop
                            • evroomE Offline
                              evroom @shbatm
                              @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                              Yes, I have.
                              Just to understand, when you start fresh, there is no omx_stream1 under pm2 list.
                              When you start your first stream, it is first visible under pm2 list, right?
                              Till now I was able to start the stream with pm2 start, but after removing the stream (pm2 remove omx_stream1), I cannot get it to work anymore.
                              MM restart, reboot, nothing helps.
                              And pm2 start now says:
                              pi@MagicPi:~ $ pm2 start omx_stream1
                              [PM2][ERROR] script not found : /home/pi/omx_stream1
                              │ App name │ id │ version │ mode │ pid │ status │ restart │ uptime │ cpu │ mem      │ user │ watching │
                              │ mm       │ 0  │ 2.5.0   │ fork │ 811 │ online │ 0       │ 4m     │ 0%  │ 2.5 MB   │ pi   │ disabled │
                              Which makes sort of sense.
                              After MM restart, pm2 logs shows:
                              Will revert back to the master branch and try again.
                                Yes, the omx_stream1 is created the first time you play a stream with the module.
                                Please use the develop branch with omxplayer. It was working on my machine the last time I started.
                                • Cr4z33C Offline
                                  Cr4z33 @shbatm
                                  @shbatm things are doing waaaay better now! :grinning_face_with_smiling_eyes:
                                  With omxplayer stream switching is almost OK if it wasn’t that it doesn’t select the wanted stream.
                                  Ie. I want stream3 therefore I give the voice command, but then it starts playing the wrong stream (and always random).
                                  Voice recognition is 100% correct as I always have a textual confirmation of command on screen.
                                  With vlc it’s a mess as multiple streams ALWAYS start at the same time after a voice command.
                                  At this point I don’t care who will be the chosen player as long as we get everything working so omxplayer would be fair enough if running properly. :smiling_face_with_open_mouth_smiling_eyes: :smiling_face_with_open_mouth_cold_sweat:
                                  • evroomE Offline
                                    evroom @shbatm
                                    Back on develop branch again.
                                    No change.
                                    Now the “pm2 remove omx_stream1” looks to be a major mistake, as I cannot get the stream running again.
                                    I do not see the module trying to start a new stream anymore.
                                    What would be the command line for starting the stream and having it appear under “pm2 list” ?
                                    In other words, what does the module do in order to achieve this ?
                                      Please send me your config in a chat.
                                        I can’t replicate this issue. Directly sending notifications: of the form notification: "RTSP-PLAY", payload: "streamX" works as expected and switches to the correct stream when using autoStart: false, rotateStreams: true, rotateStreamTimeout: 0.
                                        How many streams do you have again? Is it less than 10?
                                        I think this is related to the fact that VLC doesn’t close the streams automatically when switching, it puts the window in the background until it times out, then it closes. Try adding a shutdownDelay: 0 to your module config to make the VLC stream close immediately on hiding. Same thing with omxplayer though, switching appears to work as expected on my end.
                                        Please also make sure you have the latest version of PM2: sudo npm install -g pm2
                                          djuscha
                                          @shbatm
                                          did develop update now, both streams are on stop and error messages :(
                                          PM2            | App [omx_stream2:1] online
                                          0|mm           | Initializing new module helper ...
                                          0|mm           | Module helper loaded: newsfeed
                                          2|omx_stream1  | * failed to add service - already in use?
                                          2|omx_stream1  | Video codec omx-mjpeg width 352 height 288 profile -99 fps 30.000000
                                          2|omx_stream1  | Subtitle count: 0, state: off, index: 1, delay: 0
                                          2|omx_stream1  | /usr/bin/omxplayer: Zeile 67:  1221 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                                          PM2            | App [omx_stream1:2] exited with code [134] via signal [SIGINT]
                                          PM2            | App [omx_stream1:2] starting in -fork mode-
                                          PM2            | App [omx_stream1:2] online
                                          1|omx_stream2  | * failed to add service - already in use?
                                          1|omx_stream2  | Video codec omx-mjpeg width 352 height 288 profile -99 fps 30.000000
                                          1|omx_stream2  | Subtitle count: 0, state: off, index: 1, delay: 0
                                          1|omx_stream2  | /usr/bin/omxplayer: Zeile 67:  1244 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                                          PM2            | App [omx_stream2:1] exited with code [134] via signal [SIGINT]
                                          PM2            | App [omx_stream2:1] starting in -fork mode-
                                          2|omx_stream1  | /usr/bin/omxplayer: Zeile 67:  1287 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                                          0|mm           | Module helper loaded: MMM-RTSPStream
                                          0|mm           | All module helpers loaded.
                                          0|mm           | Starting server on port 8080 ...
                                          0|mm           | Server started ...
                                          0|mm           | Connecting socket for: updatenotification
                                          0|mm           | Connecting socket for: MMM-Fuel
                                          0|mm           | Starting module helper: MMM-Fuel
                                          0|mm           | Connecting socket for: newsfeed
                                          0|mm           | Starting module: newsfeed
                                          1|omx_stream2  | /usr/bin/omxplayer: Zeile 67:  1320 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                                          2|omx_stream1  | /usr/bin/omxplayer: Zeile 67:  1349 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                                          1|omx_stream2  | /usr/bin/omxplayer: Zeile 67:  1399 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                                          2|omx_stream1  | /usr/bin/omxplayer: Zeile 67:  1422 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                                          0|mm           | libGL error: MESA-LOADER: failed to retrieve device information
                                          ^C
                                          pi@raspberrypi:~ $ pm2 status
                                          │ Name        │ id │ mode │ status │ ↺       │ cpu │ memory │
                                          │ omx_stream1 │ 2  │ N/A  │ fork   │ stopped │ 9   │ 0%     │ 0 B      │
                                          │ omx_stream2 │ 1  │ N/A  │ fork   │ stopped │ 9   │ 0%     │ 0 B      │
                                           Use `pm2 show <id|name>` to get more details about an app
                                          pi@raspberrypi:~ $
                                          can you undo that somehow?
                                            shbatm Module Developer @djuscha
                                            @djuscha said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                            This looks like the same error I got when I tried to use omxplayer with the OpenGL driver enabled in raspi-config. You’ll have to use the legacy driver if you want to use omxplayer on the most recent version of Raspbian.
                                            EDIT 10-Jan-19: Use the latest develop branch version. omxplayer requires the --no-osd flag to work properly with the OpenGL (Fake KMS) driver.
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 30
                                            • 31
                                            • 10 / 31
