    Mirror No°1 - Girlfriends birthday present
    20 Posts 4 Posters 21.5k Views 6 Watching
    • prototype0815P Offline
      prototype0815
      Hey folks,
      this is the first MagicMirror I built. In my opinion it´s quite well done, isn’t it? All of my friends was very amazed about this dressy mirror.
      Unfortunately you can’t read the text as well, because the day I took the photo, was very bright inside the living room.
      (It was temporarily mounted on a wooden plate)
      alt text
      Wilco89W 1 Reply Last reply Reply Quote 3
      • Wilco89W Offline
        Wilco89 @prototype0815
        @prototype0815 Is the PIR sensor working with the module of @paviro or with a Python script?
        prototype0815P 1 Reply Last reply Reply Quote 0
          prototype0815 @Wilco89
          @Wilco89 I bought a usually PIR sensor at Amazon for arduino. This one is working with a python script. What kind of module are you talking about?
          Wilco89W 1 Reply Last reply Reply Quote 0
          • Wilco89W Offline
            @prototype0815 https://forum.magicmirror.builders/topic/52/pir-sensor-put-your-mirror-to-sleep-if-not-used
              prototype0815
              Ah Ok, this “module” doesn’t do anything other than my PIR sensor. In addition, I can’t find any relays which is able to switch enough ampere for my 24" display.
              Disabling the HDMI output of the RasPi3 is very easy. Give this a try…
              https://helentronica.wordpress.com/2016/01/11/magic-mirror-with-motion-detector/
              • paviroP Offline
                paviro
                My module does that too if you don’t have a relay :)
                We're all stories in the end. Just make it a good one, eh?
                – The Doctor
                Wilco89W prototype0815P 2 Replies Last reply Reply Quote 0
                • Wilco89W Offline
                  Wilco89 @paviro
                  @paviro i’m waiting for the jumper wires so i can connect and try the module.
                  @prototype0815 There are several options, and i was just wondering which one you were using.
                    prototype0815 @paviro
                    @paviro what is the exact identity number of the relay you are using?
                    • paviroP Offline
                      paviro
                      I am not a home right now so no idea, sorry :/ but it should not really matter :)
                      – The Doctor
                      • MrHM Offline
                        MrH
                        That casing you have for the PIR, made it yourself or how do I get one? :)
