    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 111.9k Views 27 Watching
    • ? Offline
      A Former User
      @cowboysdude thanks a lot at 4am almost i can sleep ha ha for 2 hours :/
      Its working, note for others Access Token key is granted here… http://instagram.pixelunion.net/ (when you get to that stage and have created the developer account)0_1477601791572_Screenshot 2016-10-28 03.53.07.png . :
      layout needs tidying up mind but im sure there are some posts on that :)
      • cowboysdudeC Offline
        cowboysdude Module Developer
        JUST to clearify for anyone… the module works GREAT!!
        Create the right thing and it’ll work~
        ACCESS TOKEN is NOT your API KEY LOL
        • P Offline
          Paninpyos
          Oh, Instagram. How to get all these followers? Sure, I can use services of zen-promo com to find people who are interested in my arts. But may be you can suggest anything?
          • ? Offline
            A Former User
            Just go with the flow, you pick them up, some have their accounts private (i did to stop prying eyes at my life) but since just opened, and tbf its mainly likes and comments, etc, it wastes time that’s all… don’t take seriously (father does with his sunset photos ha ha)…
            • ? Offline
              A Former User
              More importantly * at all
              Has anyone played with the css ? how advanced is this module? What’ts it coded in ? Function and Design ?
              CSS for sure but the rest not looked under the hood, but if anyone can answer i’ll have my in-house dev team do the following for me and share here the source
              Generic feed (swipe left / right) through feed (20)
              and popup-view of chosen image.
              (/uploads/files/1477676198837-instagram-feed-general-resized.jpg)0_1477676379169_Instagram Popup.jpg
              Simple enough to get done quickly, once i know what it’s made off, and without having to battle the module code or Magic Mirror core code.
              Many thanks and look forward to some answers.
              • K Offline
                kapsolas Module Developer
                The module is coded in javascript. I started to use some CSS, but did not spend much time on it.
                I focused on just pulling the image and flipping them them on a timer .This was the goal of my project and I met it.
                If you want to enhance it, then I am sure you can. I would start by looking at the method that displays the image. This is all done using DOM.
                • ? Offline
                  A Former User @kapsolas
                  @kapsolas said in MMM-Instagram - Pull and animate photos from Instagram feed:
                  Hi there @kapsolas (not faulting the module at all in the slightest, just trying to get bearing’s (love the module btw), thank’s on the head’s up, Q any particular files that should pay attention too?
                  Once again thanks.
                  • K Offline
                    The file you will want to start to modify is:MMM-Instagram.js
                    This is where the magic happens. The other file node_helper.js is used to handle the “packaging” of the information that the module uses to render the images. It is that file that reaches out to instagram and retrieves the images.
                    In MMM-Instagram.js, you will find a method getDOM. This is where the module is rendering the image by modifying the DOM of the page. It is creating a new DIV and setting up an tag.
                    I believe, you can start from here.
                    Thanks!
                      Jeff @yo-less
                      @yo-less
                      Thanks for your work, but you had a spelling and ; mistakes on the github upload.
                      e.g.: imageWrapper.src = tempimpage.photolink;
                      I got rid of them.
                      https://github.com/jeffjoe/MMM-Instagram
                      • lucallmonL Offline
                        lucallmon
                        This post is deleted!
                        • 6
                        • 7
                        • 8
                        • 9
                        • 6 / 9
