    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 849.3k Views 59 Watching
      DanClarkCBET3
      Is there a way to make a desktop shortcut to start MagicMirror?
        sdetweil @DanClarkCBET3
        @DanClarkCBET3 sure. create a batch file
        mm.cmd
        in the installers folder, and then use that for the shortcut
        mm.cmd should do
        @npm start
        • C Offline
          CheapDad
          My apologies if the answer to my question is located somewhere in this long thread. As a quick method of bringing some MM functionality to my kids in college, I’d like to install MM onto their laptops and have it autorun at start (like a batch file) and run in a small window.
          I see that I can install it on their laptops and I know how to create a batch file, but what I don’t know is how to ensure that a linux program starts in a windows batch file and how to get it to autosize to a small window.
          Has anyone done that?
            sdetweil @CheapDad
            @CheapDad use PM2 to auto launch
            this is a node application
            • mumblebajM Offline
              mumblebaj Module Developer @sdetweil
              @sdetweil Don’t think it is an easy straight forward setup for PM2 on Windows to launch the mirror or am I mistaken? Would he have to setup pm2-windows-service and then perform some other setups to get PM2 to work to launch MM on Windows at startup?
                sdetweil @mumblebaj
                @mumblebaj pm2 setup does all that …
                  @sdetweil :thumbs_up:
                    sdetweil @mumblebaj
                    @mumblebaj I was wrong for windows, and setup
                    see here
                    https://stackoverflow.com/questions/42758985/windows-auto-start-pm2-and-node-apps
                    still pm2 is the easiest and same on every platform…
                      @CheapDad Here is a great tutorial to set up PM2 on Windows.
                      https://blog.cloudboost.io/nodejs-pm2-startup-on-windows-db0906328d75
                      • C CheapDad referenced this topic on
                        Bobrae
                        When following your instructions on both Windows 7 and 10 machines, I get the following error message:
                        magicmirror@2.20.0 start C:\Users\Admin\MagicMirror
                        DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                        ‘DISPLAY’ is not recognized as an internal or external command,
                        operable program or batch file.
                        The error log gives the following:
                        1 verbose cli [
                        1 verbose cli ‘C:\Program Files\nodejs\node.exe’,
                        1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
                        1 verbose cli ‘start’
                        1 verbose cli ]
                        2 info using npm@6.14.4
                        3 info using node@v13.14.0
                        4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                        5 info lifecycle magicmirror@2.20.0~prestart: magicmirror@2.20.0
                        6 info lifecycle magicmirror@2.20.0~start: magicmirror@2.20.0
                        7 verbose lifecycle magicmirror@2.20.0~start: unsafe-perm in lifecycle true
                        8 verbose lifecycle magicmirror@2.20.0~start: PATH: C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;C:\Users\Admin\MagicMirror\node_modules.bin;C:\Users\Admin\bin;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\local\bin;C:\Program Files\Git\usr\bin;C:\Program Files\Git\usr\bin;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\bin;C:\Users\Admin\bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files\Intel\Intel® Management Engine Components\DAL;C:\Program Files\Intel\Intel® Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel® Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel® Management Engine Components\IPT;C:\php;C:\Program Files\Calibre2;C:\Program Files\nodejs;C:\Program Files\Git\cmd;C:\Users\Admin\AppData\Roaming\npm;C:\Program Files\Git\usr\bin\vendor_perl;C:\Program Files\Git\usr\bin\core_perl
                        9 verbose lifecycle magicmirror@2.20.0~start: CWD: C:\Users\Admin\MagicMirror
                        10 silly lifecycle magicmirror@2.20.0~start: Args: [
                        10 silly lifecycle ‘/d /s /c’,
                        10 silly lifecycle ‘DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js’
                        10 silly lifecycle ]
                        11 silly lifecycle magicmirror@2.20.0~start: Returned: code: 1 signal: null
                        12 info lifecycle magicmirror@2.20.0~start: Failed to exec start script
                        13 verbose stack Error: magicmirror@2.20.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                        13 verbose stack Exit status 1
                        13 verbose stack at EventEmitter. (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\index.js:332:16)
                        13 verbose stack at EventEmitter.emit (events.js:315:20)
                        13 verbose stack at ChildProcess. (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\lib\spawn.js:55:14)
                        13 verbose stack at ChildProcess.emit (events.js:315:20)
                        13 verbose stack at maybeClose (internal/child_process.js:1026:16)
                        13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                        14 verbose pkgid magicmirror@2.20.0
                        15 verbose cwd C:\Users\Admin\MagicMirror
                        16 verbose Windows_NT 6.1.7601
                        17 verbose argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
                        18 verbose node v13.14.0
                        19 verbose npm v6.14.4
                        20 error code ELIFECYCLE
                        21 error errno 1
                        22 error magicmirror@2.20.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                        22 error Exit status 1
                        23 error Failed at the magicmirror@2.20.0 start script.
                        23 error This is probably not a problem with npm. There is likely additional logging output above.
                        24 verbose exit [ 1, true ]
                          sdetweil @Bobrae
                          @Bobrae see
                          https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1659891805957
                          • Cliff365C Offline
                            Cliff365 @Mykle1
                            @Mykle1 First off, thanks so much for a great guide. I’m having what is likely a simple issue, but I can’t figure out how to resolve it. I am getting the following error message with the npm start command. Not concerned about the warnings, but how do resolve the DISPLAY issue?
                            $ npm start
                            npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
                            'DISPLAY' is not recognized as an internal or external command,
                            cliff@BNC-LAB01 MINGW64 ~/MagicMirror (master)
                              sdetweil @Cliff365
                              @Cliff365 see the end of the post I just linked to in the prior post
                              also, do not run under mingw… just cmd.exe
                              • Cliff365C Offline
                                Cliff365 @Mykle1
                                @Mykle1 Thanks for your help on the DISPLAY issue. I changed the line in packages.json file to:
                                “start”: “node_modules/.bin/electron js/electron.js”,
                                I get the following error message back:
                                'node_modules' is not recognized as an internal or external command,
                                  sdetweil @Cliff365
                                  @Cliff365 you didn’t follow all of the last line of
                                  https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1660158299123
                                  ps, I’m not @Mykle1
                                  Cliff365C D 2 Replies Last reply Reply Quote 0
                                  • Cliff365C Offline
                                    Cliff365 @sdetweil
                                    @sdetweil Oops! Thanks sdetweil
                                      dude31222 @sdetweil
                                      Hey! @sdetweil i’ve spend more than 10 hours whit this because i didn’t read the entire thread. I’ve finally installed mm2 on a 32bit laptop whit w7 and node v16.6 but when i run npm start i just got a black screen. any ideas on how to find a solution? my cmd here:
                                      [08.01.2023 06:58.14.001] [LOG]   Starting MagicMirror: v2.22.0
                                      [08.01.2023 06:58.14.151] [LOG]   Loading config ...
                                      [08.01.2023 06:58.14.201] [LOG]   Loading module helpers ...
                                      [08.01.2023 06:58.14.231] [LOG]   No helper found for module: alert.
                                      [08.01.2023 06:58.14.361] [LOG]   Initializing new module helper ...
                                      [08.01.2023 06:58.14.371] [LOG]   Module helper loaded: updatenotification
                                      [08.01.2023 06:58.14.395] [LOG]   No helper found for module: clock.
                                      [08.01.2023 06:58.17.473] [LOG]   Initializing new module helper ...
                                      [08.01.2023 06:58.17.477] [LOG]   Module helper loaded: calendar
                                      [08.01.2023 06:58.17.497] [LOG]   No helper found for module: compliments.
                                      [08.01.2023 06:58.17.497] [LOG]   No helper found for module: weather.
                                      [08.01.2023 06:58.17.839] [LOG]   Initializing new module helper ...
                                      [08.01.2023 06:58.17.839] [LOG]   Module helper loaded: newsfeed
                                      [08.01.2023 06:58.17.849] [LOG]   No helper found for module: facts.
                                      [08.01.2023 06:58.17.849] [LOG]   All module helpers loaded.
                                      [08.01.2023 06:58.19.559] [LOG]   Starting server on port 8080 ...
                                      [08.01.2023 06:58.23.451] [LOG]   Launching application.
                                      [08.01.2023 06:58.29.838] [LOG]   Server started ...
                                      [08.01.2023 06:58.29.848] [LOG]   Connecting socket for: updatenotification
                                      [08.01.2023 06:58.29.848] [LOG]   Starting module helper: updatenotification
                                      [08.01.2023 06:58.29.848] [LOG]   Connecting socket for: calendar
                                      [08.01.2023 06:58.29.848] [LOG]   Starting node helper for: calendar
                                      [08.01.2023 06:58.29.858] [LOG]   Connecting socket for: newsfeed
                                      [08.01.2023 06:58.29.858] [LOG]   Starting node helper for: newsfeed
                                      [08.01.2023 06:58.29.858] [LOG]   Sockets connected & modules started ...
                                      [3460:0108/070022.937:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL i
                                      s disabled, ANGLE is
                                        sdetweil @dude31222
                                        @dude31222 never tried win7 myself… this topic was created a while ago…
                                        you can TRY setting an environment variable in the cmd.exe window before executing npm start
                                        cd MagicMirror
                                        set ELECTRON_DISABLE_GPU=1
                                        npm start
                                          dude31222 @sdetweil
                                          @sdetweil still having an empty screen but no more error messages in cmd
                                            sdetweil @dude31222
                                            @dude31222 that usually means u didn’t do the fonts install step or vendor install step
                                            those are extra for windows install
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
