    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 858.6k Views 59 Watching
    • ? Offline
      A Former User @ionut322
      @ionut322 take a picture? What do you mean?
      • justjim1220J Offline
        justjim1220 Module Developer @ionut322
        @ionut322
        I’m with @Sean, need more info to help you…:winking_face:
        “Life’s Too Short To Dance With Ugly People”
        Jim Hallock - 1995
          Johans @Mykle1
          @mykle1
          Followed your guide to install on my windows 10 - 64 bit machine.
          Installation went OK, but when I start mirror I just get a black screen.
          This is the error message
          Launching application.
          { Error: listen EADDRINUSE 127.0.0.1:8080
              at Object._errnoException (util.js:1024:11)
              at _exceptionWithHostPort (util.js:1046:20)
              at Server.setupListenHandle [as _listen2] (net.js:1351:14)
              at listenInCluster (net.js:1392:12)
              at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
              at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
            code: 'EADDRINUSE',
            errno: 'EADDRINUSE',
            syscall: 'listen',
            address: '127.0.0.1',
            port: 8080 }
          Hope you can help me out.
            Mykle1 Project Sponsor Module Developer @Johans
            @johans said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
            This typically means that another application or program is using the port (8080) that MagicMirror uses. You would have to resolve that issue
              Johans
              @mykle1
              Thanks for the info, can’t find out who is using port 8080, but I changed in the config to use another port.
              Now all is working. :thumbs_up_light_skin_tone:
                @johans
                Well done, mate. :thumbsup:
                  Johans @Mykle1
                  @mykle1 FYI
                  Meanwhile I found the problem of port 8080, due to some malware on that PC, the proxi settings where modified, only option was to re-install OS. Lucky I had some backup so that didn’t took so long.
                  Now proxi settings are no longer hi-jacked and I can run MM normally.
                  Problem solved!
                    @johans
                    Ahh, Windows. I no longer use it for MM. I’m strictly a ubuntu 16.04 LTS guy now.
                      djniuss
                      Hi. quick question. the MM work with the basic modules. as soon as i try to install a 3rd party module i have a syntax error. Checked and rechecked the code and there is no error. is there special thing to add code thant im not aware of
                        sdetweil @djniuss
                        @djniuss from the MM folder do
                        npm run config:check
                        fix errors from top down
                          djniuss @sdetweil
                          @sdetweil Thank you sir. All is good now.
                            djniuss
                            Other question.
                            is there a way to acces to mirror server from another device ( like the rpi does)
                            i have withelisted all ip. and cant seem to connect. i have created rules in the windows firewall and router and still nothing.
                            instead og localhost if i enter 0.0.0.0 i only have a black screen.
                            is this possible . im building a smaller mirror and would like to connnect to the mirror that i already have running.
                            D Mykle1M 2 Replies Last reply Reply Quote 0
                              djniuss @djniuss
                              forgot to mention that i can acces the server from chrome on the cpu thats running the mirror
                                Mykle1 Project Sponsor Module Developer @djniuss
                                @djniuss said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                When you try 0.0.0.0, is it in quotes?
                                        address: "0.0.0.0", // "localhost",
                                	port: 8080,
                                	ipWhitelist: [],
                                	language: "en",
                                	timeFormat: 12,
                                	units: "imperial",
                                  djniuss
                                  yes its in quote.
                                    sdetweil
                                    hm,… mine is like Mykle1’s
                                      address: "0.0.0.0", // Address to listen on, can be:
                                      port: 8086,
                                      ipWhitelist: [], // Set [] to allow all IP addresses
                                    but u get a black screen? that sounds like two versions trying to run at the same time…
                                    did u reboot?
                                      djniuss @sdetweil
                                      @sdetweil yep did reboot a few time. it does not seem that i have more thant one mingw32 running or electron browser.
                                      the only error i have in the log is regardin the polution ( NOAA3 weather updated… next update in 1 hour
                                      fr
                                      Whoops! There was an uncaught exception…
                                      TypeError: Cannot read property ‘pollution’ of undefined)
                                      if this helps
                                      C:\WINDOWS\system32>netstat -aon | findstr 8080
                                      TCP 127.0.0.1:8080 0.0.0.0:0 LISTENING 5216
                                      TCP 127.0.0.1:8080 127.0.0.1:53407 ESTABLISHED 5216
                                      TCP 127.0.0.1:53407 127.0.0.1:8080 ESTABLISHED 5216
                                        djniuss
                                        just found out that if i enter 0.0.0.0 i can acces from other computer via Chrome. but the computer that runs MM as a black screen.
                                        and by mistake : on the computer that as the MM running i had the black screen so i opend up the chrmome browser wit the local host add . i was about the drag the top bar on the desktop in order to have a MM browser chrome link on the desktop … i droped it on the black screen ( electron) and automatically the MM showed up.
                                          sdetweil @djniuss
                                          @djniuss sorry, I don’t understand what you said.
                                          if u have black screen, ctrl-shift-i to open the developers env, and then select the console tab and scroll to find errors (red text)…
                                          most of the UI errors like this, will kill the UI (and result in a black screen)
                                            jelbear
                                            Thanks for this guide its been really helpful, it has enabled me to install MM on a win7 VM acting as a node serveronly on an always on machine, which helps to release some resources on a Pi zero attached to a display.
                                            Everything seems to run OK, other than any module that pulls images from a path e.g. MMM-Wallpaper, MMM-Backgroundslideshow, even when the config is left to use the default paths to the module’s examples, there is an ENOENT error shown in the Git Bash window. Doesn’t matter if they are url link images i.e. bing or locally stored images.
                                            Using the exact same config script when installed on a Pi the background images show.
                                            Anyone got any ideas about how this can be fixed, as I’m not using it as a mirror, but as a family kitchen dashboard so the images are fairly important.
                                            a “npm run config:check” command says that there are no syntax errors in the config file
                                            I believe it has to to with path syntax between windows and linux but that is about all I can come up with
                                            { Error: ENOENT: no such file or directory, scandir '/modules/MMM-BackgroundSlid
                                            eshow/exampleImages'
                                                at Object.readdirSync (fs.js:785:3)
                                                at Class.getFiles (C:\Users\Admin\MagicMirror\modules\MMM-BackgroundSlidesho
                                            w\node_helper.js:71:45)
                                                at Class.gatherImageList (C:\Users\Admin\MagicMirror\modules\MMM-BackgroundS
                                            lideshow\node_helper.js:60:12)
                                                at Class.socketNotificationReceived (C:\Users\Admin\MagicMirror\modules\MMM-
                                            BackgroundSlideshow\node_helper.js:92:28)
                                                at Socket.<anonymous> (C:\Users\Admin\MagicMirror\modules\node_modules\node_
                                            helper\index.js:113:11)
                                                at Socket.emit (events.js:189:13)
                                                at C:\Users\Admin\MagicMirror\node_modules\socket.io\lib\socket.js:528:12
                                                at process._tickCallback (internal/process/next_tick.js:61:11)
                                              errno: -4058,
                                              syscall: 'scandir',
                                              code: 'ENOENT',
                                              path: '/modules/MMM-BackgroundSlideshow/exampleImages' }
                                            If you think this really is an issue, please open an issue on GitHub: https://gi
                                            thub.com/MichMich/MagicMirror/issues
                                            justjim1220J lavolp3L 2 Replies Last reply Reply Quote 0
                                            • 16
                                            • 17
                                            • 3 / 17
