    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 860.9k Views 59 Watching
      sdetweil @dwburger
      @dwburger said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
      The laptop came with Edge, but I’ve been using Chrome.
      http://192.168.1.65:8080 fails
      http://localhost:8080 works
      so, that looks like the address/ipWhitelist setting above…
      (by default MM thinks it is in a closed box on the wall, so only allows connections from INSIDE the box)
        dwburger @sdetweil
        @sdetweil :thumbs_up:
          sdetweil @dwburger
          Runs fine” = On the laptop, using Git Bash, I can start the MM2 normally with “npm start”.
          but I don’t understand this…
          with the change to the start script, it runs in windows without bash… just regular windows batch
          (cmd/powershell)
            dwburger @sdetweil
            @sdetweil OK
              sdetweil @dwburger
              I want to manage it from my desktop in my office using Git Bash ssh connection.
              also, don’t know what this means… manage… it doesn’t NEED to run MM at all… just display it.
              u could have two instances running on the base machine… 2 different ports…
              the tablet accesses port(8081) , the base another (8080)
              run the tablet instance as serveronly then no ui memory consumption on the base for that instance
              to make a second copy from the first, just copy the MM folder to MM1, and change the config for port (and address/whitelist above)
              then do npm serveronly for the tablet mm
              • P Offline
                Plainbroke 0
                All,
                You can not copy and paste though. I had to manually type it all in to make it work.
                Still in MagicMirror;
                nano package.json
                right under the other “start”: “???”
                go to the line below it and hit enter.
                Then type in the blank space you just made.
                “start”: “node_modules/.bin/electron js/electron.js”,
                //DO NOT LEAVE OUT THE PUNCTUATION. ESPECIALLY THE COMMA AT THE END.
                //I speak from expereince on this matter.
                //Mykle1 usually has to help me find it after struggling for a couple hours.
                THEN:
                cd ~/MagicMirror/vendor
                npm install
                cd fonts
                npm install
                NOW IT will RUN
                Thank you agian Mykle1
                I am really enjoying this on my laptop,
                so much easier to do testing ect.
                  sdetweil @Plainbroke 0
                  @Plainbroke-0 it was Sam, but anyway I cut and paste ALL the time. you need to add the code block marks around the actual steps to make them readable
                  • blake_northrupB Offline
                    blake_northrup @OldShaterhan
                    @OldShaterhan
                    I just made the change, and this is what I get when trying npm start:
                    $ npm start
                    magicmirror@2.12.0 start C:\Users\blake\MagicMirror
                    run-start.sh
                    ‘run-start.sh’ is not recognized as an internal or external command,
                    operable program or batch file.
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! magicmirror@2.12.0 start: run-start.sh
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.12.0 start script.
                    npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-07T18_11_04_725Z-debug.log
                      blake_northrup @dwburger
                      Thank you dwburger! This fixed my issue!
                        blake_northrup
                        I guess I spoke too soon. npm starts, but I have a blank screen. Haven’t done anything to the config.js file, except make a copy of the config.js.sample, and removed the .sample. See output:
                        $ npm run config:check
                        magicmirror@2.12.0 config:check C:\Users\blake\MagicMirror
                        node js/check_config.js
                        [2020-07-07 13:50:13.582] [INFO] Checking file… C:\Users\blake\MagicMirror\config\config.js
                        [2020-07-07 13:50:13.630] [LOG] Line 1 col 1 Definition for rule ‘prettier/prettier’ was not found.
                        C:\Users\blake\MagicMirror\js\check_config.js:66
                        throw new Error(“Wrong syntax in config file!”);
                        Error: Wrong syntax in config file!
                        at C:\Users\blake\MagicMirror\js\check_config.js:66:10
                        at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:63:3)
                        npm ERR! errno 1
                        npm ERR! magicmirror@2.12.0 config:check: node js/check_config.js
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.12.0 config:check script.
                        npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-07T18_50_13_660Z-debug.log
                          sdetweil @blake_northrup
                          @blake_northrup not run-start
                          “start”:“node_modules/.bin/electron js/electron.js”,
                            @blake_northrup because u installed on windows, there are a couple extra steps
                            cd MagicMirror
                            cd vendor
                            npm install
                            cd …\fonts. 2dots
                            npm install
                            cd … 2dot
                            the npm start
                            this phone editor will not let me enter 2 dots, displays as 3
                            blake_northrupB 3 Replies Last reply Reply Quote 2
                              blake_northrup @sdetweil
                              @sdetweil Thank you sdetweil. I will try thins now, and let you know.
                                @sdetweil Still getting black screen after performing these steps. For some reason, it is stating that I have the wrong syntax in the config file.
                                [2020-07-08 07:59:36.797] [INFO] Checking file… C:\Users\blake\MagicMirror\config\config.js
                                [2020-07-08 07:59:36.854] [LOG] Line 1 col 1 Definition for rule ‘prettier/prettier’ was not found.
                                npm ERR! errno 1
                                npm ERR!
                                npm ERR! C:\Users\blake\AppData\Roaming\npm-cache_logs\2020-07-08T12_59_36_872Z-debug.log
                                  @sdetweil Nevermind. All is now working. Had an extra bit of info in my config file that didn’t need to be there. Thanks again for all of your help sdetweil!
                                    dphotograph @blake_northrup
                                    @blake_northrup
                                    what was your “extra bit of info in my config file” ? i haf the same error and dont find an error with my config file on my new installed MagicMirror
                                    blake_northrupB 1 Reply Last reply Reply Quote 0
                                      blake_northrup @dphotograph
                                      @dphotograph Hey dphotograph, I had somehow copied the bottom part twice, and that was my problem. I just copied the config sample again, and built all of my modules, one by one.
                                        djkj84
                                        Hey guys,
                                        Really new to this so i’m doing my best… But i am stuck… Any help with this please?
                                        I’m on Windows 10 Pro.
                                        Thanks in advance.
                                        npm start
                                        magicmirror@2.12.0 start C:\Users\Smart Mirror\MagicMirror
                                        DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                                        ‘DISPLAY’ is not recognized as an internal or external command,
                                        npm ERR! errno 1
                                        npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                        npm ERR!
                                        npm ERR! C:\Users\Smart Mirror\AppData\Roaming\npm-cache_logs\2020-08-19T10_14_26_713Z-debug.log
                                        earnestrichardsE 1 Reply Last reply Reply Quote 0
                                        • earnestrichardsE Offline
                                          earnestrichards @djkj84
                                          @djkj84 I had this same problem on Win7.
                                          I searched the forum and found this post by @sdetweil…
                                          fix
                                          • U Offline
                                            Uwe Kretsen @Mykle1
                                            @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                            Had enough? Lets run that MagicMirror, NOW!
                                            Hallo there,
                                            if you will find some free time to help :
                                            I tried a few times to process the whole procedure of starting new MM software on PC - I am not even a newbie so it is really hard to say what I am doing wrong.
                                            see pic - does it say to you anything? 18f689c8-c4ec-4f15-9558-c554ee194971-image.png
                                            it seems I will have to give up - programming is not for all ;-)
                                            BR
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 16
                                            • 17
                                            • 7 / 17
