    MMM-MyScoreboard
    Scheduled Pinned Locked Moved Sport
    277 Posts 60 Posters 635.6k Views 63 Watching
    • M
      mcaminiti
      This post is deleted!
      • sifuhallS
        sifuhall
        I followed the instructions here for the git pull and npm install with no errors.
        In my config file I place this but all I get is a blank screen.
        module: “MMM-MyScoreboard”,
        position: “top_left”,
        classes: “default everyone”,
        header: “My Scoreboard”,
        showLeagueSeparators: true,
        colored: true,
        viewStyle: “mediumLogos”,
        sports: [
        league: “NCAAF”,
        teams: [“UK”]
        • W
          Wenike @sifuhall
          @sifuhall You won’t get anything until the UK football team has a game, which won’t be for a few weeks. Until then, this module displays nothing.
          sifuhallS 1 Reply Last reply Reply Quote 0
          • sifuhallS
            sifuhall @Wenike
            @wenike Thank you for the reply. But I’m saying the entire screen is blank. Not just the scores section.
            W S 2 Replies Last reply Reply Quote 0
            • W
              Wenike @sifuhall
              @sifuhall So, other modules aren’t showing either?
                sdetweil @sifuhall
                @sifuhall this sounds like the the missing libraries problem. when the screen is blank, can u show the message at mm startup?
                if using pm2, use
                pm2 logs --lines=100
                • sifuhallS
                  sifuhall @sdetweil
                  Yes, this was it exactly. Once I added the request module everything was fine.
                  However, I do have one question.
                  How can I add the West Ham United Football Club?
                  • BKeyportB
                    BKeyport Module Developer @sifuhall
                    @sifuhall it looks like it’s not supported based on the code.
                    • sifuhallS
                      sifuhall @BKeyport
                      @bkeyport Thank you for the reply
                      • E
                        Egnos
                        Hello everybody,
                        I’m having trouble with this module, are any of you using it?
                        The following errors MM returns me:
                        [02.09.2022 10:52.55.068] [LOG]   [MMM-MyScoreboard] 2-Sep-22 10:52 ** ERROR ** Couldn't retrieve ITA_SERIE_A data for provider ESPN: Error: getaddrinfo ENOTFOUND site.api.espn.com
                        [02.09.2022 10:52.55.068] [LOG]   [MMM-MyScoreboard] http://site.api.espn.com/apis/site/v2/sports/soccer/ita.1/scoreboard?dates=20220902&limit=200
                        Starting module: MMM-MyScoreboard MMM-MyScoreboard.js:560
                        All modules started!
                        MMM-MyScoreboard.js:552
                        [MMM-MyScoreboard] Updating Scores module.js:195
                        MMM-MyScoreboard is suspended.
                        Below my configuration
                        		  module: "MMM-MyScoreboard",
                        		  classes: "default everyone",
                        		  header: "My Scoreboard",
                        			colored: true,
                        			viewStyle: "mediumLogos",
                        			sports: [
                        				league: "ITA_SERIE_A",
                        				//teams: ["JUV"]
                        				//label: "Seria A TIM 2022/23"
                        Can you help me?
                          sdetweil @Egnos
                          @Egnos looks like the provider changed their API. so the module will have to be changed
                          • E
                            Egnos @sdetweil
                            @sdetweil said in MMM-MyScoreboard:
                            Hi @sdetweil
                            I understand. Do you know if the developer still maintains the module?
                              sdetweil @Egnos
                              @Egnos no idea, go look at the GitHub site, post an issue.
                              • E
                                Egnos @sdetweil
                                I tried to do the recommended fix but nothing has changed.
                                https://github.com/jclarke0000/MMM-MyScoreboard/pull/61
                                I opened a problem on GitHub as you advised me, I await an answer.
                                If someone had solved … give a whistle ;-)
                                  sdetweil @Egnos
                                  @Egnos but that PR fixes the wrong provider… the espn provider is broken
                                  the error u posted
                                  that module is 5 years old… these providers change things every year…
                                  • BKeyportB
                                    @sdetweil ESPN sneezes and the data format changes. Not a reliable source.
                                    E 1 Reply Last reply Reply Quote 1
                                    • E
                                      Egnos @BKeyport
                                      @BKeyport said in MMM-MyScoreboard:
                                      Hi @BKeyport do you know a valid alternative?
                                      • BKeyportB
                                        BKeyport Module Developer @Egnos
                                        @Egnos sadly, no, i don’t. Gave up on scores on my mirror long ago.
                                        • J
                                          j.e.f.f Project Sponsor Module Developer
                                          Sorry folks that I haven’t been around to fix this. There URL for the ticker changed for the SportsNet provider. I’ll be publishing a fix in the cominn g days, but if you want to address it now, make a change in the file providers/SNET.js.
                                          Change line #122 from
                                              var url = "https://d290qmen6zswb.cloudfront.net/ticker?day=" + this.gameDate.format("YYYY-MM-DD");
                                          to
                                             var url = "https://mobile-statsv2.sportsnet.ca/ticker?day=" + this.gameDate.format("YYYY-MM-DD");
                                          This should get you back up and running until I publish the official fix.
                                          • Jeff
                                          • E
                                            Egnos @j.e.f.f
                                            @j-e-f-f said in MMM-MyScoreboard:
                                            Thanks @j-e-f-f we look forward to the official release!:thumbs_up:
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 12 / 14
