    Looking for Beta-testers!
    Scheduled Pinned Locked Moved MagicMirror
    56 Posts 17 Posters 60.2k Views 18 Watching
    • MichMichM Offline
      MichMich
      Update: More detailed error message in case config file couldn’t be loaded.
      Please let me know if this works for you.
      PR: https://github.com/MichMich/MagicMirror/pull/391#issuecomment-237919625
      • MichMichM Offline
        MichMich
        Please test the following PR:
        https://github.com/MichMich/MagicMirror/pull/416
        It’s merged into the current develop branch. If you are on the develop branch, please use git pull to update to the latest version.
        Thanks!
        • BangeeB Offline
          Bangee Module Developer
          I’m now on the latest DEV version.
          I had some problems to run it with my PIR Sensor.
          this command helps to run it:
          npm rebuild --runtime=electron-prebuilt --target=0.37.8 --disturl=https://atom.io/download/atom-shell --build-from-source
          IpWithelist:
          I’ve added my Subnet to de Withelist, but I can’t access my MagicMirror using a browser:
          This device is not allowed to access your mirror.
          Please check your config.js or config.js.sample to change this.
          Would it be possible to add something like “Your IP-Adress: 192.168.0.99”?
          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", ["192.168.0.99", "192.168.0.254"]],
          This sould add a range from 192.168.0.99-192.168.0.254, or am I wrong?
          Thanks for your help.
          • MichMichM Offline
            MichMich
            @bangee: Check your node log. It should tell you which IP is trying to access the server. Good idea to add it to the “access denied” message. Will put it on my todo list. (PR is welcome!)
            • BangeeB Offline
              @MichMich Thank you. I’ve had to update my config:
              the Log told me:
              Access denied to IP address: ::ffff:192.168.0.99
              It works with this:
              ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.1/24", "192.168.0.1/24"],
                Jopyth Moderator @MichMich
                My mirror is now also running the development version, and I am experiencing restarts more often than before. I guess it is related to # 150 since there is no error in the log. Anyway I saw this twice yesterday, but this might just be something with a newer electron version, so maybe nothing we can fix. It is still a little bit annoying.
                @MichMich By the way, do you have any particular date in mind for the release?
                Helpful sticky: How to troubleshoot
                • MichMichM Offline
                  MichMich
                  No, can’t give you an ETA.
                  Keep me posted on the restart issue.
                    I am a little bit in the dark on the restart issue. It happens every time I change any file in my source code directory, i.e. config/config.js or even package.json.
                    All I have so far, is this appeared after I updated to development branch (hence updated all npm dependencies), plus I had to update my PIR-Sensor module (got a version XX expected, got XX error), and rebuild dependencies there also.
                    Does anyone have any idea on this? And is anyone else even seeing this behavior also? If I have time, I will try a complete reinstall and see if that fixes it.
                    • MichMichM Offline
                      MichMich
                      Arent you running any tool that watches your directory and restarts? Like nodemon or pm2?
                        Jopyth Moderator
                        I am using pm2 but watch & reload was disabled.
                        I did a complete update, which apparently helped people before with #150, that seems to have fixed it:
                        sudo apt-get update
                        sudo apt-get upgrade
                        sudo apt-get dist-upgrade
                        sudo apt-get clean
                        sudo rpi-update
                        • 6
                        • 3 / 6
