    MMM-NOAA - Another Weather Module
    690 Posts 77 Posters 2.6m Views 70 Watching
      Mykle1 Project Sponsor Module Developer @tbbear
      @tbbear
      My son on both sides of the pool. The magic of panoramic photos!
      tbbearT 1 Reply Last reply Reply Quote 2
      • P Offline
        planet4
        I have some questions regarding this module. In the screenshots I do not se the grey boxes like in the image below. 0 G. I have tried to set everything as false but still.
        Also the font size is smaller on this module compared to all other modules on my MM2. I suppose I can change this in the CSS but it seems to be worong.
        alt text
        • cowboysdudeC Offline
          cowboysdude Module Developer @planet4
          @planet4 Not sure what you have there but that looks all wrong…
          • P Offline
            planet4 @cowboysdude
            @cowboysdude
            Thanks for the reply. Just like this.
            		module: 'MMM-NOAA',
            		disabled: false,
            		position: 'top_right',
            			apiKey: "xxxxxxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
            			useAir: false,             // set to false if you do not want to use Air Quality Index
            			airKey: "xxxxxxxxxxxxxxxx",    // IF you want Air Quality Index
            			pws: "IMLNLYCK10",         // go here to find your pws: https://www.wunderground.com/wundermap
            			showClock: false,           // Hides or shows clock
            			dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
            			format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
            			ampm: false,                // to show AM and PM on Sunrise/Sunset time
            			showGreet: true,          // deafult is false - to show greeting under clock and above date
            			name: "Persson",                  // Your name
            			showWind: false,
            			showDate: false,
            			showForecast: true,         //show bottom 3 day forecast
            			flash: false,                 //Today in forecast flashes halo
            			showUV: false,               //show UV index
            			showBar: false,             // show Barometer
            			showHum: false,              //show Humidity level
            			position: 'top_right'       //whatever you have in above position must also be here
              @planet4 said in MMM-NOAA - Another Weather Module:
              disabled: false,
              Delete that line for now…
              Then go a git pull and npm install and see if that helps…changes have been made to fix certain things :)
              • P Offline
                @cowboysdude Thanks but it looks the same unfortunatly.
                tbbearT 1 Reply Last reply Reply Quote 0
                • tbbearT Offline
                  tbbear Module Developer
                  @planet4 Hi, please try to select showWind: true it should fix your problem
                  Robert the Bear
                  • tbbearT Offline
                    tbbear Module Developer @Mykle1
                    @Mykle1 oo i see so u are an iphone fan ?
                    Robert the Bear
                      @tbbear said in MMM-NOAA - Another Weather Module:
                      I’m an iPhone user but I am not a fan of iPhone prices.
                      • tbbearT Offline
                        @Mykle1 hahah thats true but they are the best, i have a iphone x and its unbelievable
                        Robert the Bear
                        • 21
                        • 22
                        • 23
                        • 24
                        • 25
                        • 68
                        • 69
                        • 23 / 69
