    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 537.1k Views 29 Watching
    • B
      BD0G @cowboysdude
      @cowboysdude He helped me resolve the issue so its looking goooooooood!
      • V
        Vauxdvihl
        Unfortunately no image is shown
        And i am not able to reach the linked homepage here (location germany)
        Is there a workaround?
        Thanks a lot
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Vauxdvihl
          @Vauxdvihl said in MMM-Lunartic:
          Yes, the API is down. However, there is a workaround. (temporary fix)
          1. Do a “git pull” in the MMM-Lunartic directory to make sure the module is up to date
          2. Rename your current MMM-Lunartic.js file to MMM-Lunartic.bak
          3. You will now notice a folder named “temporary fix” inside the module folder. Inside the “temporary fix” folder is another MMM-Lunartic.js file. Copy and paste that to the root of the MMM-Lunartic folder.
          4. Restart MM
          • V
            Vauxdvihl
            @Mykle1
            :thumbs_up:
            Thanks a lot
            it works
            • Mykle1M
              Thanks a lot
              You’re welcome. :thumbsup:
              it works
              A minor miracle. :-)
              • E
                Egnos @Mykle1
                @Mykle1 said in MMM-Lunartic:
                4. Restart MM
                Hi @Mykle1,
                I tried to do your work around but I only see this writing: “When the Moon hits your eye…”
                This is my configuration:
                			disabled: false,
                			module: 'MMM-Lunartic',
                			//position: 'bottom_center', // Best in left, center, or right regions
                			pages: {Prova: "top_left"},
                				mode: "rotating", // rotating or static
                				image: "current", // animation, current, DayNight or static
                				distance: "miles", // miles or km
                				sounds: "yes", // howling wolf, only on a full moon
                				useHeader: false, // true if you want a header
                				header: "The Lunartic is in my head", // Any text you want
                				maxWidth: "300px",
                				animationSpeed: 0,
                				rotateInterval: 15000,
                Could you help me?
                Many thanks!
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @Egnos
                  @Egnos
                  I’m surprised you even saw “When the Moon hits your eye…” at all.
                  I don’t know where this came from --> pages: {Prova: “top_left”},
                  This works:
                  			disabled: false,
                  		//	pages: {Prova: "top_left"},
                  				maxWidth: "300px",
                  				animationSpeed: 0,
                  • E
                    Egnos @Mykle1
                    Thanks @Mykle1.
                    My MM has multiple pages and uses the “MMM-Page-Selector” module.
                    Using the configuration below I should display your module on the “Prova” page, but showing only "When the Moon hits your eye…”
                    All other modules (about 21 …) respect this rule …
                    Could you do something?
                    Thanks a lot!
                    • Mykle1M
                      @Egnos
                      Well, first a question. Does it work with the default config entry after you’ve done the temporary fix?
                      • E
                        Egnos @Mykle1
                        @Egnos
                        Yes, if you comment the line
                        the module seems to work correctly.
                        I did this test using a new “config.js”, without the other 21 modules.
                        It is also possible that Lunartic conflicts with some other module.
                        Here are the modules I installed:
                        MMM-iFrame-Ping
                        MMM-Page-Selector
                        MM-orrery
                        MMM-DarkSkyForecast
                        MMM-ISS
                        MMM-RTSPStream
                        planetrise
                        MMM-EARTH-Live
                        MMM-ISS-Live
                        MMM-Screencast
                        MMM-Formula1
                        MMM-Lunartic
                        MMM-SoccerLiveScore
                        MMM-Globe
                        MMM-MyCommute
                        mmm-suncalc
                        MMM-GoogleMapsTraffic
                        MMM-page-indicator
                        MMM-Voice-Commands
                        Thanks.
                        • Mykle1M
                          @Egnos said in MMM-Lunartic:
                          Sure, it’s possible. Anything is possible. However, Lunartic works, without issue, with every other module (as far as I know). I don’t use MMM-Page-Selector. I use Hello-Lucy for my page selections and Lunartic lives happily there. No issues. No conflicts.
                          With that said, I’ll see if I can discover anything.
                          In the meantime, you can uncomment the pages: {Prova: "top_left"}, line and start you mirror with npm start dev. Report any errors from the dev console that appears.
                          • E
                            Egnos @Mykle1
                            @Mykle1 Hello Lucy allows you to create pages like MMM-Page Selector?
                            Is it possible to change the pages automatically after a set time?
                            Many thanks @Mykle1.
                            PS: I try your advice as soon as possible!👍
                            • Mykle1M
                              @Egnos
                              I’m not familiar with MMM-PageSelector so I don’t know how things work within that module.
                              Changing pages after a set time is not a feature that I have a use for. I can simply change a page with a voice command any time I want. Feel free to fork the module and make any changes your like. Send a PR if you like.
                              I think there are already modules that might do that.
                              • E
                                Egnos
                                HI @Mykle1
                                I don’t know why but the module started working!
                                I have some questions:
                                • How should I modify the config.js to not display the image of the moon but only the text?
                                • I am Italian, how can I translate the text?
                                • If you want to use “Hello Lucy” to call up the page with my voice, could you recommend a good microphone?
                                Thank you so much for your patience.:winking_face:
                                • Mykle1M
                                  Uhh, I don’t know why either.
                                  Well, you can achieve that this way. Add this to you custom.css file:
                                  .MMM-Lunartic img.photo {
                                    display: none;
                                  You can contribute to this module by replacing the Spanish in the following file with Italian. I will then add it to the module. By doing so, you make Italian available to everyone that uses this module.
                                  "Distance from Earth's core = ": "Distancia desde la Tierra: ",
                                  "Distance from sun = ": "Distancia desde el Sol: ",
                                  "The next full moon is ": "Próxima Luna llena ",
                                  "The next new moon is ": "Próxima Luna nueva: ",
                                  "The current moon is ": "La fase actual lleva ",
                                  "The moon is ": "Esta Luna está  ",
                                  "% illuminated": "% iluminada",
                                  " days old": " dias transcurridos",
                                  "New Moon Phase": "Luna Nueva",
                                  "Waxing Crescent Moon": "Luna Creciente",
                                  "First Quarter Half Moon": "Primer cuarto de media luna",
                                  "Waxing Gibbous Moon": "Luna creciente Gibosa",
                                  "Full Moon": "Luna Llena",
                                  "Waning Gibbous Moon": "Luna Gibosa menguante",
                                  "Third Quarter Half Moon": "Tercer cuarto de Media Luna",
                                  "Waning Crescent Moon": "Luna creciente menguante",
                                  "When the Moon hits your eye . . .": "Cuando la Luna ilumina tus ojos . . ."
                                  Are you using a Pi? I think the PSEye cam works well from what I’ve read here. I really don’t know. I don’t use Pi’s any longer.
                                  • E
                                    Egnos
                                    For you:
                                    "Distance from Earth's core = ": "Distanza dal nucleo della Terra",
                                    "Distance from sun = ": "Distanza dal Sole",
                                    "The next full moon is ": "La prossima Luna piena è",
                                    "The next new moon is ": "La prossima Luna nuova è",
                                    "The current moon is ": "La fase lunare corrente è",
                                    "The moon is ": "La Luna è",
                                    "% illuminated": "% illuminata",
                                    " days old": "Giorni trascorsi",
                                    "New Moon Phase": "Luna Nuova",
                                    "Waxing Crescent Moon": "Luna Crescente",
                                    "First Quarter Half Moon": "Primo Quarto di Luna",
                                    "Waxing Gibbous Moon": "Luna Gibbosa Crescente",
                                    "Full Moon": "Luna Piena",
                                    "Waning Gibbous Moon": "Luna Gibbosa Calante",
                                    "Third Quarter Half Moon": "Ultimo Quarto di Luna",
                                    "Waning Crescent Moon": "Luna Calante",
                                    "When the Moon hits your eye . . .": "Quando la Luna illumina i tuoi occhi..."
                                    No, now for convenience I’m using a virtual machine with VirtualBox, could it work?
                                    • Mykle1M
                                      MMM-Lunartic now has Italian translation!
                                      • Thanks to @Egnos
                                      I have no way of testing that.
                                      git pull in the MMM-Lunartic directory ot visit https://github.com/mykle1/MMM-Lunartic
                                      • Mykle1M
                                        Notice from the USNO api for MMM-Lunartic
                                        “This US Naval Observatory Website is undergoing modernization and will be offline starting Thursday, 24 October 2019. The expected completion of work and return of service is estimated as 30 April 2020.”
                                        So, hopefully, the module will be back to normal soon.
                                        StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                                        • StoffbeuteluweS
                                          Stoffbeuteluwe Project Sponsor @Mykle1
                                          @Mykle1 Super… thanks Mykle
                                          • StoffbeuteluweS
                                            This post is deleted!
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
