    MMM-Tools : System stat monitoring and commanding (ATB Supported)
    38 Posts 7 Posters 22.7k Views 6 Watching
      A Former User
      MMM-Tools
      Dsiplay stats and remote controlling MagicMirror on SBC(ATB & RPI), MMM-TelegramBot supported.
      Screenshots
      on MagicMirror
      on Telegram
      Feature
      • Display system status on MagicMirror
      • MMM-TelegramBot commands, /status and /screen on|off are supported.
      • You can set alert threshold for abnormal status of MagicMirror. You can get warning message by notification and TelegramBot
      Download
      [card:eouia/MMM-Tools]
      note)
      I know there is already MMM-SystemStat, however I need my own because of supporting Asus Tinker Board and my module MMM-TelegramBot.
      Of course, RPI is supported also. Anyway, is there any good way to detect current monitor status on SBC without X ?
      • KimzerK
        Kimzer
        Looks really good. Too bad it wont run on my Pi :\
        ? 2 Replies Last reply Reply Quote 0
          A Former User @Kimzer
          @Kimzer What’s the problem? I have not tested on RPI enough, (I have no RPI currently. my old one was not near me.)
            @Kimzer If you are using Pi Zero or… without LXDE, It could not work properly maybe.
            • KimzerK
              Kimzer
              Im not sure what the issue is, simply wont display anything.
              Using a Pi2 model b.
                @Kimzer test npm start dev, and see which error messages are thrown in your terminal console, and chromium dev console.
                and report issue on my github, I’ll look and try to fix. :)
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @Guest
                  @Sean said in MMM-Tools : System stat monitoring and commanding (ATB Supported):
                  His problem might be the same as mine. My mirror is running MM 2.1.0 so your check stopped the module from loading.
                  Any chance you can add a PC option or move the check to MM version 2.1.0? I’m not really working with Pi’s anymore. A Windows PC dev machine, a Windows PC laptop and a laptop running uBuntu.
                  Nice work Sean!
                    A Former User @Mykle1
                    @Mykle1 okay. You can just remove required version in module js file.
                    I cant be sure my module has any dependency to recent MM version. That code was just… habit? :)
                    I think it could be alright without version. But I cannot test this night. Yup, here is midnight, after sleep, I’ll do that.
                      @Mykle1 maybe genuine Ububtu and Debian, I can add, but not sure. Windows… hmmm my last windows work was 15years ago. ;) I’m oldschooled.
                      • cowboysdudeC
                        cowboysdude Module Developer @Guest
                        You aren’t missing anything LOL
                        • Mykle1M
                          I commented out the version check but it still didn’t display on my Pi3B mirror. No errors, terminal or console
                          • K
                            krisalexroberts
                            Worked fine on my mirror on a Pi3B. Just had to remove some of the final commas from the config
                              A Former User @krisalexroberts
                              @krisalexroberts Thanks! I typed this example not by copy, so i did mistakes. I fixed it.
                              • KimzerK
                                Kimzer
                                Same here. Redownloaded. Used the new settings. No bueno. Doesnt display
                                  @Kimzer I cant figure out what is problem, more detailed info is needed.
                                  • rpi model
                                  • os
                                  • your configuration values…
                                  • npm start dev result
                                  Mykle1M 2 Replies Last reply Reply Quote 0
                                  • Mykle1M
                                    @Sean
                                    I have to go to work, Sean. I will post that info for you when I get home.
                                    • randomnoiseR
                                      randomnoise
                                      Tried this module, even with a default config it doesn’t seem to display any of the actual values, just the titles:
                                      Running Rpi3 Raspian Jesse
                                      No errors during startup:
                                      Starting MagicMirror: v2.1.2
                                      Loading config ...
                                      Loading module helpers ...
                                      Module helper loaded: MMM-Tools
                                      All module helpers loaded.
                                      Server started ...
                                      Connecting socket for: MMM-Tools
                                      Starting module: newsfeed
                                      Launching application.
                                      Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                                      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                      Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
                                      Config used:
                                      		  module: 'MMM-Tools',
                                      		  position: 'bottom_right',
                                      			device : "RPI", // "RPI" is also available
                                      			refresh_interval_ms : 10000,
                                      			warning_interval_ms : 1000 * 60 * 5,
                                      			enable_warning : true,
                                      			warning : {
                                      			  CPU_TEMPERATURE : 65,
                                      			  GPU_TEMPERATURE : 65,
                                      			  CPU_USAGE : 75,
                                      			  STORAGE_USED_PERCENT : 80,
                                      			  MEMORY_USED_PERCENT : 80
                                      • Mykle1M
                                        @Sean
                                        I just reinstalled MMM-Tool and it is working now. I don’t know why it didn’t work the first time. shrug
                                        • Pi 3 Model B, 1GB, Hardware : BCM2709, Revision = a02082, (Sony, UK)
                                        • Raspbian Jessie
                                          	position: 'top_center',
                                        		enable_warning : false,
                                        		    warning : {
                                        		    CPU_USAGE : 75,
                                              		    MEMORY_USED_PERCENT : 80,
                                          A Former User @randomnoise
                                          @randomnoise only label is displayed, when module is stopped before getting results of script execution of node_helper. Possible suspicious point is…
                                          • module(including your other modules) has error, so front electron halts.
                                          npm start dev, see the browser dev console. If there is no suspicious message(usually red lines), hmmmm…
                                          • KimzerK
                                            Kimzer
                                            The issue seems pretty straightforward.
                                            If i place it top_center. It works fine.
                                            bottom_right (where i want it) without any other modules there, it displays the text only. No bars etc. If i re-add the module i already have there it doesnt show at all…
                                            ? randomnoiseR 2 Replies Last reply Reply Quote 0
