Problem with Weather forecast
47 Posts 14 Posters 37.9k Views 13 Watching
  • H Offline
    Henrik
    I made a quick’n’dirty hack to make it only display the weather at noon each day. Around line 340, I added a simple if statement. I’m in UTC+2, so I had to put 14 instead of 12 in the comparison.
    this.parserDataWeather(forecast); // hack issue #1017
    if ( moment(forecast.dt, "X").format("HH") != "14")
      continue; //new if statement
    this.forecast.push({
    The limit of 16 no longer means 16 days, but 16 forecasts. Therefore, we need to change the enforced limit, around line 300, I set it to something higher (I chose 57):
    params += "&cnt=" + (((this.config.maxNumberOfDays < 1) || (this.config.maxNumberOfDays > 16)) ? 57
    Don’t forget to change the value in the actual config to the same number (57 in my case).
    I chose 57 to get a full week, but it seems the API won’t return more than 5 days’ worth of data anyway.
    M 1 Reply Last reply Sep 24, 2017, 1:56 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @Henrik
      @Henrik said in Problem with Weather forecast:
      The newest weather module to hit the MM scene. Take a look. I like it, I like it a lot!
      https://github.com/cowboysdude/MMM-NOAA
      H 1 Reply Last reply Sep 24, 2017, 3:02 PM Reply Quote 1
        Sp4M
        I made the module compatible for the “daily” api of openweather. It basically aggregate data of all “3h parts” of each day.
        The min/max are global min/max of each parts
        The icon shows the worst-case (you can reorder what is worse for you in config.iconTableOrdered)
        Hope that will help devs
        Here is the corresponding code of weatherforecast.js
        /* global Module */
        /* Magic Mirror
         * Module: WeatherForecast
         * MIT Licensed.
        Module.register("weatherforecast",{
        	// Default module config.
        	defaults: {
        		locationID: false,
        		appid: "",
        		units: config.units,
        		maxNumberOfDays: 7,
        		showRainAmount: false,
        		updateInterval: 10 * 60 * 1000, // every 10 minutes
        		animationSpeed: 1000,
        		timeFormat: config.timeFormat,
        		lang: config.language,
        		fade: true,
        		fadePoint: 0.25, // Start on 1/4th of the list.
        		colored: false,
        		initialLoadDelay: 2500, // 2.5 seconds delay. This delay is used to keep the OpenWeather API happy.
        		retryDelay: 2500,
        		apiVersion: "2.5",
        		apiBase: "http://api.openweathermap.org/data/",
        		forecastEndpoint: "forecast", //forecast/daily
        		appendLocationNameToHeader: true,
        		calendarClass: "calendar",
        		roundTemp: false,
        		iconTable: {
        			"01d": "wi-day-sunny",
        			"02d": "wi-day-cloudy",
        			"03d": "wi-cloudy",
        			"04d": "wi-cloudy-windy",
        			"09d": "wi-showers",
        			"10d": "wi-rain",
        			"11d": "wi-thunderstorm",
        			"13d": "wi-snow",
        			"50d": "wi-fog",
        			"01n": "wi-night-clear",
        			"02n": "wi-night-cloudy",
        			"03n": "wi-night-cloudy",
        			"04n": "wi-night-cloudy",
        			"09n": "wi-night-showers",
        			"10n": "wi-night-rain",
        			"11n": "wi-night-thunderstorm",
        			"13n": "wi-night-snow",
        			"50n": "wi-night-alt-cloudy-windy"
        		iconTableOrdered: [
        			"11d",
        			"09d",
        			"13d",
        			"10d",
        			"50d",
        			"04d",
        			"03d",
        			"02d",
        			"01d",
        			"11n",
        			"09n",
        			"13n",
        			"10n",
        			"50n",
        			"02n",
        			"03n",
        			"04n",
        			"01n"
        	// create a variable for the first upcoming calendaar event. Used if no location is specified.
        	firstEvent: false,
        	// create a variable to hold the location name based on the API result.
        	fetchedLocationName: "",
        	// Define required scripts.
        	getScripts: function() {
        		return ["moment.js"];
        	getStyles: function() {
        		return ["weather-icons.css", "weatherforecast.css"];
        	// Define required translations.
        	getTranslations: function() {
        		// The translations for the default modules are defined in the core translation files.
        		// Therefor we can just return false. Otherwise we should have returned a dictionary.
        		// If you're trying to build yiur own module including translations, check out the documentation.
        		return false;
        	// Define start sequence.
        	start: function() {
        		Log.info("Starting module: " + this.name);
        		// Set locale.
        		moment.locale(config.language);
        		this.forecast = [];
        		this.loaded = false;
        		this.scheduleUpdate(this.config.initialLoadDelay);
        		this.updateTimer = null;
        	// Override dom generator.
        	getDom: function() {
        		if (this.config.appid === "") {
        			wrapper.innerHTML = "Please set the correct openweather <i>appid</i> in the config for module: " + this.name + ".";
        			wrapper.className = "dimmed light small";
        			return wrapper;
        		if (!this.loaded) {
        			wrapper.innerHTML = this.translate("LOADING");
        			return wrapper;
        		var table = document.createElement("table");
        		table.className = "small";
        		for (var f in this.forecast) {
        			var forecast = this.forecast[f];
        			var row = document.createElement("tr");
        			if (this.config.colored) {
        				row.className = "colored";
        			table.appendChild(row);
        			var dayCell = document.createElement("td");
        			dayCell.className = "day";
        			dayCell.innerHTML = forecast.day;
        			row.appendChild(dayCell);
        			var iconCell = document.createElement("td");
        			iconCell.className = "bright weather-icon";
        			row.appendChild(iconCell);
        			var icon = document.createElement("span");
        			icon.className = "wi weathericon " + forecast.icon;
        			iconCell.appendChild(icon);
        			var maxTempCell = document.createElement("td");
        			maxTempCell.innerHTML = forecast.maxTemp;
        			maxTempCell.className = "align-right bright max-temp";
        			row.appendChild(maxTempCell);
        			var minTempCell = document.createElement("td");
        			minTempCell.innerHTML = forecast.minTemp;
        			minTempCell.className = "align-right min-temp";
        			row.appendChild(minTempCell);
        			if (this.config.showRainAmount) {
        				var rainCell = document.createElement("td");
        				if (isNaN(forecast.rain)) {
        					rainCell.innerHTML = "";
        				} else {
        					if(config.units !== "imperial") {
        						rainCell.innerHTML = forecast.rain + " mm";
        					} else {
        						rainCell.innerHTML = (parseFloat(forecast.rain) / 25.4).toFixed(2) + " in";
        				rainCell.className = "align-right bright rain";
        				row.appendChild(rainCell);
        			if (this.config.fade && this.config.fadePoint < 1) {
        				if (this.config.fadePoint < 0) {
        					this.config.fadePoint = 0;
        				var startingPoint = this.forecast.length * this.config.fadePoint;
        				var steps = this.forecast.length - startingPoint;
        				if (f >= startingPoint) {
        					var currentStep = f - startingPoint;
        					row.style.opacity = 1 - (1 / steps * currentStep);
        		return table;
        	// Override getHeader method.
        	getHeader: function() {
        		if (this.config.appendLocationNameToHeader) {
        			return this.data.header + " " + this.fetchedLocationName;
        		return this.data.header;
        	// Override notification handler.
        	notificationReceived: function(notification, payload, sender) {
        		if (notification === "DOM_OBJECTS_CREATED") {
        				this.hide(0, {lockString: this.identifier});
        		if (notification === "CALENDAR_EVENTS") {
        			var senderClasses = sender.data.classes.toLowerCase().split(" ");
        			if (senderClasses.indexOf(this.config.calendarClass.toLowerCase()) !== -1) {
        				this.firstEvent = false;
        				for (var e in payload) {
        					var event = payload[e];
        					if (event.location || event.geo) {
        						this.firstEvent = event;
        						//Log.log("First upcoming event with location: ", event);
        						break;
        	/* updateWeather(compliments)
        	 * Requests new data from openweather.org.
        	 * Calls processWeather on succesfull response.
        	updateWeather: function() {
        			Log.error("WeatherForecast: APPID not set!");
        			return;
        		var url = this.config.apiBase + this.config.apiVersion + "/" + this.config.forecastEndpoint + this.getParams();
        		var self = this;
        		var retry = true;
        		var weatherRequest = new XMLHttpRequest();
        		weatherRequest.open("GET", url, true);
        		weatherRequest.onreadystatechange = function() {
        			if (this.readyState === 4) {
        				if (this.status === 200) {
        					self.processWeather(JSON.parse(this.response));
        				} else if (this.status === 401) {
        					self.updateDom(self.config.animationSpeed);
        					Log.error(self.name + ": Incorrect APPID.");
        					retry = true;
        				} else {
        					Log.error(self.name + ": Could not load weather.");
        				if (retry) {
        					self.scheduleUpdate((self.loaded) ? -1 : self.config.retryDelay);
        		weatherRequest.send();
        	/* getParams(compliments)
        	 * Generates an url with api parameters based on the config.
        	 * return String - URL params.
        	getParams: function() {
        		var params = "?";
        		if(this.config.locationID) {
        			params += "id=" + this.config.locationID;
        		} else if(this.config.location) {
        			params += "q=" + this.config.location;
        		} else if (this.firstEvent && this.firstEvent.geo) {
        			params += "lat=" + this.firstEvent.geo.lat + "&lon=" + this.firstEvent.geo.lon
        		} else if (this.firstEvent && this.firstEvent.location) {
        			params += "q=" + this.firstEvent.location;
        		} else {
        			this.hide(this.config.animationSpeed, {lockString:this.identifier});
        			return;
        		params += "&units=" + this.config.units;
        		params += "&lang=" + this.config.lang;
        		 * Submit a specific number of days to forecast, between 1 to 16 days.
        		 * The OpenWeatherMap API properly handles values outside of the 1 - 16 range and returns 7 days by default.
        		 * This is simply being pedantic and doing it ourselves.
        		params += "&cnt=" + (((this.config.maxNumberOfDays < 1) || (this.config.maxNumberOfDays > 121)) ? 40 : this.config.maxNumberOfDays);
        		params += "&APPID=" + this.config.appid;
        		return params;
        	/* processWeather(data)
        	 * Uses the received data to set the various values.
        	 * argument data object - Weather information received form openweather.org.
        	processWeather: function(data) {
        		this.fetchedLocationName = data.city.name + ", " + data.city.country;
        		var days_forecast = [];
        		for (var i = 0, count = data.list.length; i < count; i++) {
        			let forecast = data.list[i];
        			let day = forecast.dt_txt.split(" ")[0];
        			if (!(day in days_forecast))
        				days_forecast[day] = {"dt":[], "icon":[], "temp":[]};
        			days_forecast[day].dt.push(forecast.dt);
        			days_forecast[day].icon.push(forecast.weather[0].icon);
        			days_forecast[day].temp.push(forecast.main.temp_min);
        			days_forecast[day].temp.push(forecast.main.temp_max);
        		for (let i in days_forecast) {
        			let min = days_forecast[i].temp.reduce((previous, current) => current = previous < current ? previous : current);
        			let max = days_forecast[i].temp.reduce((previous, current) => current = previous > current ? previous : current);
        			let icon = days_forecast[i].icon.reduce((previous, current) => current = this.config.iconTableOrdered.indexOf(previous) < this.config.iconTableOrdered.indexOf(current) ? previous : current);
        				day: moment(days_forecast[i].dt[0], "X").format("ddd"),
        				icon: this.config.iconTable[icon],
        				maxTemp: this.roundValue(min),
        				minTemp: this.roundValue(max)
        //				rain: this.roundValue(forecast.rain)
        		//Log.log(this.forecast);
        		this.show(this.config.animationSpeed, {lockString:this.identifier});
        		this.loaded = true;
        		this.updateDom(this.config.animationSpeed);
        	/* scheduleUpdate()
        	 * Schedule next update.
        	 * argument delay number - Milliseconds before next update. If empty, this.config.updateInterval is used.
        	scheduleUpdate: function(delay) {
        		var nextLoad = this.config.updateInterval;
        		if (typeof delay !== "undefined" && delay >= 0) {
        			nextLoad = delay;
        		var self = this;
        		clearTimeout(this.updateTimer);
        		this.updateTimer = setTimeout(function() {
        			self.updateWeather();
        		}, nextLoad);
        	/* ms2Beaufort(ms)
        	 * Converts m2 to beaufort (windspeed).
        	 * see:
        	 *  http://www.spc.noaa.gov/faq/tornado/beaufort.html
        	 *  https://en.wikipedia.org/wiki/Beaufort_scale#Modern_scale
        	 * argument ms number - Windspeed in m/s.
        	 * return number - Windspeed in beaufort.
        	ms2Beaufort: function(ms) {
        		var kmh = ms * 60 * 60 / 1000;
        		var speeds = [1, 5, 11, 19, 28, 38, 49, 61, 74, 88, 102, 117, 1000];
        		for (var beaufort in speeds) {
        			var speed = speeds[beaufort];
        			if (speed > kmh) {
        				return beaufort;
        		return 12;
        	/* function(temperature)
        	 * Rounds a temperature to 1 decimal or integer (depending on config.roundTemp).
        	 * argument temperature number - Temperature.
        	 * return number - Rounded Temperature.
        	roundValue: function(temperature) {
        		var decimals = this.config.roundTemp ? 0 : 1;
        		return parseFloat(temperature).toFixed(decimals);
        H F 4 Replies Last reply Sep 24, 2017, 3:04 PM Reply Quote 1
        • H Offline
          Henrik @Mykle1
          @Mykle1 Thanks, will check that out!
          • H Offline
            Henrik @Sp4M
            @Sp4M Good work! :)
            • F Offline
              frank61BS @Sp4M
              @Sp4M
              Yes it looks better now
              For me only 2 forecasts are visible. How can I show more ?
              • F Offline
                frank61BS @Sp4M
                @Sp4M
                Oh, I was pleased to early.
                It is repeating now the two forecasts ?
                see attachment
                • F Offline
                  frank61BS @Sp4M
                  @Sp4M
                  Hi it’s even worse.
                  the two forecast are repeated endless
                    Sp4M
                    @frank61BS
                    Try to increase the maxNumberOfDays parameter.
                    Actually maxNumberOfDays = 2 means “2 slices of time” and not 2 days with this api, as I said in my first posts (eg: 1 day = 8 x 3h)
                    Maybe it will be better by simple use maxNumberOfDays x 8 in the source code
                      Sp4M
                      @frank61BS
                      This corrected version should works with the real maxNumberOfDays (=5 for example)
                      /* global Module */
                      /* Magic Mirror
                       * MIT Licensed.
                      	defaults: {
                      		locationID: false,
                      		appid: "",
                      		maxNumberOfDays: 5,
                      		fade: true,
                      		colored: false,
                      		retryDelay: 2500,
                      		apiVersion: "2.5",
                      		roundTemp: false,
                      		iconTable: {
                      			"03d": "wi-cloudy",
                      			"10d": "wi-rain",
                      			"13d": "wi-snow",
                      			"50d": "wi-fog",
                      		iconTableOrdered: [
                      			"11d",
                      			"09d",
                      			"13d",
                      			"10d",
                      			"50d",
                      			"04d",
                      			"03d",
                      			"02d",
                      			"01d",
                      			"11n",
                      			"09n",
                      			"13n",
                      			"10n",
                      			"50n",
                      			"02n",
                      			"03n",
                      			"04n",
                      			"01n"
                      	firstEvent: false,
                      		return false;
                      	start: function() {
                      		// Set locale.
                      		this.forecast = [];
                      			return wrapper;
                      		if (!this.loaded) {
                      			return wrapper;
                      				} else {
                      					} else {
                      		return table;
                      						break;
                      			return;
                      		var self = this;
                      		var retry = true;
                      					retry = true;
                      				} else {
                      				if (retry) {
                      		var params = "?";
                      		} else {
                      			return;
                      		 * Submit a specific number of days to forecast, between 1 to 5 days.
                      		 * The OpenWeatherMap API properly handles values outside of the 1 - 5 range and returns 5 days by default.
                      		params += "&cnt=" + ((this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 5) ? 5 : this.config.maxNumberOfDays)*8;
                      		return params;
                      		this.forecast = [];
                      		this.loaded = true;
                      	/* scheduleUpdate()
                      			nextLoad = delay;
                      		var self = this;
                      		}, nextLoad);
                      	/* ms2Beaufort(ms)
                      	 * see:
                      			if (speed > kmh) {
                      				return beaufort;
                      		return 12;
                      R F 3 Replies Last reply Sep 25, 2017, 9:26 PM Reply Quote 1
                      • 4 / 5
                      4 / 5
