    Problem with Weather forecast
    47 Posts 14 Posters 48.3k Views 13 Watching
    • AzraelA Offline
      Azrael
      Thank you Mykle1. Now the weather forecast shows up where it should be.
      However, I have exactly the same problem what luizcarlosnery mentioned earlier. Today (Saturday) I see: Sat,Sat,Sat,Sat,Sat,Sun,Sun.
        Mykle1 Project Sponsor Module Developer @Azrael
        @Azrael
        Sorry to hear that. Until the issues are resolved, you could always try another weather module. There are many to choose from.
        Scroll down to the weather category
        https://github.com/MichMich/MagicMirror/wiki/MagicMirror²-Modules#3rd-party-modules
        • DuskeD Offline
          Duske
          You see the same day multiple times because this API is a “5 days/3 hour forecast API”, so you won’t get one result per day, but multiple forecasts for one single day with 3 hours between them.
          E.g.
          Result 1: "2017-09-24 00:00:00" Sunday
          Result 2: "2017-09-24 03:00:00" Sunday
          Result 3: "2017-09-24 06:00:00" Sunday
          and so on
          • AzraelA Offline
            Azrael
            OK, it makes sense.
            Is there any option to get only one forecast for one day? Or to display somehow the time periods?
            • H Offline
              Henrik
              I made a quick’n’dirty hack to make it only display the weather at noon each day. Around line 340, I added a simple if statement. I’m in UTC+2, so I had to put 14 instead of 12 in the comparison.
              this.parserDataWeather(forecast); // hack issue #1017
              if ( moment(forecast.dt, "X").format("HH") != "14")
                continue; //new if statement
              this.forecast.push({
              The limit of 16 no longer means 16 days, but 16 forecasts. Therefore, we need to change the enforced limit, around line 300, I set it to something higher (I chose 57):
              params += "&cnt=" + (((this.config.maxNumberOfDays < 1) || (this.config.maxNumberOfDays > 16)) ? 57
              Don’t forget to change the value in the actual config to the same number (57 in my case).
              I chose 57 to get a full week, but it seems the API won’t return more than 5 days’ worth of data anyway.
                Mykle1 Project Sponsor Module Developer @Henrik
                @Henrik said in Problem with Weather forecast:
                The newest weather module to hit the MM scene. Take a look. I like it, I like it a lot!
                https://github.com/cowboysdude/MMM-NOAA
                H 1 Reply Last reply Reply Quote 1
                  Sp4M
                  I made the module compatible for the “daily” api of openweather. It basically aggregate data of all “3h parts” of each day.
                  The min/max are global min/max of each parts
                  The icon shows the worst-case (you can reorder what is worse for you in config.iconTableOrdered)
                  Hope that will help devs
                  Here is the corresponding code of weatherforecast.js
                  /* global Module */
                  /* Magic Mirror
                   * Module: WeatherForecast
                   * MIT Licensed.
                  Module.register("weatherforecast",{
                  	// Default module config.
                  	defaults: {
                  		locationID: false,
                  		appid: "",
                  		units: config.units,
                  		maxNumberOfDays: 7,
                  		showRainAmount: false,
                  		updateInterval: 10 * 60 * 1000, // every 10 minutes
                  		animationSpeed: 1000,
                  		timeFormat: config.timeFormat,
                  		lang: config.language,
                  		fade: true,
                  		fadePoint: 0.25, // Start on 1/4th of the list.
                  		colored: false,
                  		initialLoadDelay: 2500, // 2.5 seconds delay. This delay is used to keep the OpenWeather API happy.
                  		retryDelay: 2500,
                  		apiVersion: "2.5",
                  		apiBase: "http://api.openweathermap.org/data/",
                  		forecastEndpoint: "forecast", //forecast/daily
                  		appendLocationNameToHeader: true,
                  		calendarClass: "calendar",
                  		roundTemp: false,
                  		iconTable: {
                  			"01d": "wi-day-sunny",
                  			"02d": "wi-day-cloudy",
                  			"03d": "wi-cloudy",
                  			"04d": "wi-cloudy-windy",
                  			"09d": "wi-showers",
                  			"10d": "wi-rain",
                  			"11d": "wi-thunderstorm",
                  			"13d": "wi-snow",
                  			"50d": "wi-fog",
                  			"01n": "wi-night-clear",
                  			"02n": "wi-night-cloudy",
                  			"03n": "wi-night-cloudy",
                  			"04n": "wi-night-cloudy",
                  			"09n": "wi-night-showers",
                  			"10n": "wi-night-rain",
                  			"11n": "wi-night-thunderstorm",
                  			"13n": "wi-night-snow",
                  			"50n": "wi-night-alt-cloudy-windy"
                  		iconTableOrdered: [
                  			"11d",
                  			"09d",
                  			"13d",
                  			"10d",
                  			"50d",
                  			"04d",
                  			"03d",
                  			"02d",
                  			"01d",
                  			"11n",
                  			"09n",
                  			"13n",
                  			"10n",
                  			"50n",
                  			"02n",
                  			"03n",
                  			"04n",
                  			"01n"
                  	// create a variable for the first upcoming calendaar event. Used if no location is specified.
                  	firstEvent: false,
                  	// create a variable to hold the location name based on the API result.
                  	fetchedLocationName: "",
                  	// Define required scripts.
                  	getScripts: function() {
                  		return ["moment.js"];
                  	getStyles: function() {
                  		return ["weather-icons.css", "weatherforecast.css"];
                  	// Define required translations.
                  	getTranslations: function() {
                  		// The translations for the default modules are defined in the core translation files.
                  		// Therefor we can just return false. Otherwise we should have returned a dictionary.
                  		// If you're trying to build yiur own module including translations, check out the documentation.
                  		return false;
                  	// Define start sequence.
                  	start: function() {
                  		// Set locale.
                  		moment.locale(config.language);
                  		this.forecast = [];
                  		this.loaded = false;
                  		this.scheduleUpdate(this.config.initialLoadDelay);
                  		this.updateTimer = null;
                  	// Override dom generator.
                  	getDom: function() {
                  		if (this.config.appid === "") {
                  			wrapper.innerHTML = "Please set the correct openweather <i>appid</i> in the config for module: " + this.name + ".";
                  			wrapper.className = "dimmed light small";
                  			return wrapper;
                  		if (!this.loaded) {
                  			wrapper.innerHTML = this.translate("LOADING");
                  			return wrapper;
                  		var table = document.createElement("table");
                  		table.className = "small";
                  		for (var f in this.forecast) {
                  			var forecast = this.forecast[f];
                  			var row = document.createElement("tr");
                  			if (this.config.colored) {
                  				row.className = "colored";
                  			table.appendChild(row);
                  			var dayCell = document.createElement("td");
                  			dayCell.className = "day";
                  			dayCell.innerHTML = forecast.day;
                  			row.appendChild(dayCell);
                  			var iconCell = document.createElement("td");
                  			iconCell.className = "bright weather-icon";
                  			row.appendChild(iconCell);
                  			var icon = document.createElement("span");
                  			icon.className = "wi weathericon " + forecast.icon;
                  			iconCell.appendChild(icon);
                  			var maxTempCell = document.createElement("td");
                  			maxTempCell.innerHTML = forecast.maxTemp;
                  			maxTempCell.className = "align-right bright max-temp";
                  			row.appendChild(maxTempCell);
                  			var minTempCell = document.createElement("td");
                  			minTempCell.innerHTML = forecast.minTemp;
                  			minTempCell.className = "align-right min-temp";
                  			row.appendChild(minTempCell);
                  			if (this.config.showRainAmount) {
                  				var rainCell = document.createElement("td");
                  				if (isNaN(forecast.rain)) {
                  					rainCell.innerHTML = "";
                  				} else {
                  					if(config.units !== "imperial") {
                  						rainCell.innerHTML = forecast.rain + " mm";
                  					} else {
                  						rainCell.innerHTML = (parseFloat(forecast.rain) / 25.4).toFixed(2) + " in";
                  				rainCell.className = "align-right bright rain";
                  				row.appendChild(rainCell);
                  			if (this.config.fade && this.config.fadePoint < 1) {
                  				if (this.config.fadePoint < 0) {
                  					this.config.fadePoint = 0;
                  				var startingPoint = this.forecast.length * this.config.fadePoint;
                  				var steps = this.forecast.length - startingPoint;
                  				if (f >= startingPoint) {
                  					var currentStep = f - startingPoint;
                  					row.style.opacity = 1 - (1 / steps * currentStep);
                  		return table;
                  	// Override getHeader method.
                  	getHeader: function() {
                  		if (this.config.appendLocationNameToHeader) {
                  			return this.data.header + " " + this.fetchedLocationName;
                  		return this.data.header;
                  	// Override notification handler.
                  		if (notification === "DOM_OBJECTS_CREATED") {
                  				this.hide(0, {lockString: this.identifier});
                  		if (notification === "CALENDAR_EVENTS") {
                  			var senderClasses = sender.data.classes.toLowerCase().split(" ");
                  			if (senderClasses.indexOf(this.config.calendarClass.toLowerCase()) !== -1) {
                  				this.firstEvent = false;
                  				for (var e in payload) {
                  					var event = payload[e];
                  					if (event.location || event.geo) {
                  						this.firstEvent = event;
                  						//Log.log("First upcoming event with location: ", event);
                  						break;
                  	/* updateWeather(compliments)
                  	 * Requests new data from openweather.org.
                  	 * Calls processWeather on succesfull response.
                  	updateWeather: function() {
                  			Log.error("WeatherForecast: APPID not set!");
                  			return;
                  		var url = this.config.apiBase + this.config.apiVersion + "/" + this.config.forecastEndpoint + this.getParams();
                  		var self = this;
                  		var retry = true;
                  		var weatherRequest = new XMLHttpRequest();
                  		weatherRequest.open("GET", url, true);
                  		weatherRequest.onreadystatechange = function() {
                  			if (this.readyState === 4) {
                  				if (this.status === 200) {
                  					self.processWeather(JSON.parse(this.response));
                  				} else if (this.status === 401) {
                  					self.updateDom(self.config.animationSpeed);
                  					Log.error(self.name + ": Incorrect APPID.");
                  					retry = true;
                  				} else {
                  					Log.error(self.name + ": Could not load weather.");
                  				if (retry) {
                  					self.scheduleUpdate((self.loaded) ? -1 : self.config.retryDelay);
                  		weatherRequest.send();
                  	/* getParams(compliments)
                  	 * Generates an url with api parameters based on the config.
                  	 * return String - URL params.
                  	getParams: function() {
                  		var params = "?";
                  		if(this.config.locationID) {
                  			params += "id=" + this.config.locationID;
                  		} else if(this.config.location) {
                  			params += "q=" + this.config.location;
                  		} else if (this.firstEvent && this.firstEvent.geo) {
                  			params += "lat=" + this.firstEvent.geo.lat + "&lon=" + this.firstEvent.geo.lon
                  		} else if (this.firstEvent && this.firstEvent.location) {
                  			params += "q=" + this.firstEvent.location;
                  		} else {
                  			this.hide(this.config.animationSpeed, {lockString:this.identifier});
                  			return;
                  		params += "&units=" + this.config.units;
                  		params += "&lang=" + this.config.lang;
                  		 * Submit a specific number of days to forecast, between 1 to 16 days.
                  		 * The OpenWeatherMap API properly handles values outside of the 1 - 16 range and returns 7 days by default.
                  		 * This is simply being pedantic and doing it ourselves.
                  		params += "&cnt=" + (((this.config.maxNumberOfDays < 1) || (this.config.maxNumberOfDays > 121)) ? 40 : this.config.maxNumberOfDays);
                  		params += "&APPID=" + this.config.appid;
                  		return params;
                  	/* processWeather(data)
                  	 * Uses the received data to set the various values.
                  	 * argument data object - Weather information received form openweather.org.
                  	processWeather: function(data) {
                  		this.fetchedLocationName = data.city.name + ", " + data.city.country;
                  		var days_forecast = [];
                  		for (var i = 0, count = data.list.length; i < count; i++) {
                  			let forecast = data.list[i];
                  			let day = forecast.dt_txt.split(" ")[0];
                  			if (!(day in days_forecast))
                  				days_forecast[day] = {"dt":[], "icon":[], "temp":[]};
                  			days_forecast[day].dt.push(forecast.dt);
                  			days_forecast[day].icon.push(forecast.weather[0].icon);
                  			days_forecast[day].temp.push(forecast.main.temp_min);
                  			days_forecast[day].temp.push(forecast.main.temp_max);
                  		for (let i in days_forecast) {
                  			let min = days_forecast[i].temp.reduce((previous, current) => current = previous < current ? previous : current);
                  			let max = days_forecast[i].temp.reduce((previous, current) => current = previous > current ? previous : current);
                  			let icon = days_forecast[i].icon.reduce((previous, current) => current = this.config.iconTableOrdered.indexOf(previous) < this.config.iconTableOrdered.indexOf(current) ? previous : current);
                  				day: moment(days_forecast[i].dt[0], "X").format("ddd"),
                  				icon: this.config.iconTable[icon],
                  				maxTemp: this.roundValue(min),
                  				minTemp: this.roundValue(max)
                  //				rain: this.roundValue(forecast.rain)
                  		//Log.log(this.forecast);
                  		this.show(this.config.animationSpeed, {lockString:this.identifier});
                  		this.loaded = true;
                  		this.updateDom(this.config.animationSpeed);
                  	/* scheduleUpdate()
                  	 * Schedule next update.
                  	 * argument delay number - Milliseconds before next update. If empty, this.config.updateInterval is used.
                  	scheduleUpdate: function(delay) {
                  		var nextLoad = this.config.updateInterval;
                  		if (typeof delay !== "undefined" && delay >= 0) {
                  			nextLoad = delay;
                  		var self = this;
                  		clearTimeout(this.updateTimer);
                  		this.updateTimer = setTimeout(function() {
                  			self.updateWeather();
                  		}, nextLoad);
                  	/* ms2Beaufort(ms)
                  	 * Converts m2 to beaufort (windspeed).
                  	 * see:
                  	 *  http://www.spc.noaa.gov/faq/tornado/beaufort.html
                  	 *  https://en.wikipedia.org/wiki/Beaufort_scale#Modern_scale
                  	 * argument ms number - Windspeed in m/s.
                  	 * return number - Windspeed in beaufort.
                  	ms2Beaufort: function(ms) {
                  		var kmh = ms * 60 * 60 / 1000;
                  		var speeds = [1, 5, 11, 19, 28, 38, 49, 61, 74, 88, 102, 117, 1000];
                  		for (var beaufort in speeds) {
                  			var speed = speeds[beaufort];
                  			if (speed > kmh) {
                  				return beaufort;
                  		return 12;
                  	/* function(temperature)
                  	 * Rounds a temperature to 1 decimal or integer (depending on config.roundTemp).
                  	 * argument temperature number - Temperature.
                  	 * return number - Rounded Temperature.
                  	roundValue: function(temperature) {
                  		var decimals = this.config.roundTemp ? 0 : 1;
                  		return parseFloat(temperature).toFixed(decimals);
                  H F 4 Replies Last reply Reply Quote 1
                  • H Offline
                    Henrik @Mykle1
                    @Mykle1 Thanks, will check that out!
                    • H Offline
                      Henrik @Sp4M
                      @Sp4M Good work! :)
                      • F Offline
                        frank61BS @Sp4M
                        @Sp4M
                        Yes it looks better now
                        For me only 2 forecasts are visible. How can I show more ?
                        • F Offline
                          frank61BS @Sp4M
                          @Sp4M
                          Oh, I was pleased to early.
                          It is repeating now the two forecasts ?
                          see attachment
                          • F Offline
                            frank61BS @Sp4M
                            @Sp4M
                            Hi it’s even worse.
                            the two forecast are repeated endless
                              Sp4M
                              @frank61BS
                              Try to increase the maxNumberOfDays parameter.
                              Actually maxNumberOfDays = 2 means “2 slices of time” and not 2 days with this api, as I said in my first posts (eg: 1 day = 8 x 3h)
                              Maybe it will be better by simple use maxNumberOfDays x 8 in the source code
                                Sp4M
                                @frank61BS
                                This corrected version should works with the real maxNumberOfDays (=5 for example)
                                /* global Module */
                                /* Magic Mirror
                                 * MIT Licensed.
                                	defaults: {
                                		locationID: false,
                                		appid: "",
                                		maxNumberOfDays: 5,
                                		fade: true,
                                		colored: false,
                                		retryDelay: 2500,
                                		apiVersion: "2.5",
                                		roundTemp: false,
                                		iconTable: {
                                			"03d": "wi-cloudy",
                                			"10d": "wi-rain",
                                			"13d": "wi-snow",
                                			"50d": "wi-fog",
                                		iconTableOrdered: [
                                			"11d",
                                			"09d",
                                			"13d",
                                			"10d",
                                			"50d",
                                			"04d",
                                			"03d",
                                			"02d",
                                			"01d",
                                			"11n",
                                			"09n",
                                			"13n",
                                			"10n",
                                			"50n",
                                			"02n",
                                			"03n",
                                			"04n",
                                			"01n"
                                	firstEvent: false,
                                		return false;
                                	start: function() {
                                		// Set locale.
                                		this.forecast = [];
                                			return wrapper;
                                		if (!this.loaded) {
                                			return wrapper;
                                				} else {
                                					} else {
                                		return table;
                                						break;
                                			return;
                                		var self = this;
                                		var retry = true;
                                					retry = true;
                                				} else {
                                				if (retry) {
                                		var params = "?";
                                		} else {
                                			return;
                                		 * Submit a specific number of days to forecast, between 1 to 5 days.
                                		 * The OpenWeatherMap API properly handles values outside of the 1 - 5 range and returns 5 days by default.
                                		params += "&cnt=" + ((this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 5) ? 5 : this.config.maxNumberOfDays)*8;
                                		return params;
                                		this.forecast = [];
                                		this.loaded = true;
                                	/* scheduleUpdate()
                                			nextLoad = delay;
                                		var self = this;
                                		}, nextLoad);
                                	/* ms2Beaufort(ms)
                                	 * see:
                                			if (speed > kmh) {
                                				return beaufort;
                                		return 12;
                                R F 3 Replies Last reply Reply Quote 1
                                  roramirez Core Contributors @Sp4M
                                  So nice work guys! If somebody else can merge your changes with my PR or pushed other PR with theses changes go ahead.
                                  I’ll prefer to keep the same behavior if API not get 401
                                    Sp4M
                                    Thanks @roramirez
                                    Unfortunately it seems that daily API will not come back on the free version (and I guess that 99% percent of MM users use the free version of openweather)
                                    I created a pull request with the code I posted.
                                    • F Offline
                                      frank61BS @Sp4M
                                      @Sp4M
                                      Hm, with this version the module doesn’t come up at all ??
                                      Where should I configure the parameter maxNumberOfDays ??
                                      Btw I have a free acount on openweather
                                      • F Offline
                                        frank61BS @Sp4M
                                        @Sp4M
                                        Sorry it was my mistake.
                                        The modul seems to work.
                                        I think I copied it in a wrong way.
                                        • MichMichM Offline
                                          MichMich
                                          I just pushed a fix to the develop branch that should solve the weather forecast. It’s a bit of a hot fix while we are working on the new weather module.
                                          A new master release is planned to be released this weekend, so if you don’t want to install the develop version, hang tight.
                                            stevegoble @MichMich
                                            @MichMich fresh upgrade to 2.1.3 and using the entire sample config does not display the weather. I tried the develop branch and updated it with git pull but does the same. Was this fixed? Do I need a fresh build?
                                            • 2 / 3
