    Problem with Weather forecast
    47 Posts 14 Posters 40.5k Views 13 Watching
      Mykle1 Project Sponsor Module Developer @Mykle1
      @Mykle1 said in Problem with Weather forecast:
      I don’t know what to tell you. That entry is working.
      Reply to myself! LOL
      An oversight on my part. I was testing that in MM 2.1.1 and it WAS working. I just moved to MM 2.1.2 and it does NOT
      • P Offline
        plybz18
        Same problem here, for weatherforecast it shows incorrect appid, but same appid is working for current weather.!!!
          Aurelsam @Mykle1
          @Mykle1
          So it means that it does not work with the latest version ??
          How do you install 2.1.1?
            Mykle1 Project Sponsor Module Developer @Aurelsam
            @Aurelsam said in Problem with Weather forecast:
            It would appear so. You could try the workaround that @SP4M provided above. I have not tried it.
            https://github.com/MichMich/MagicMirror/releases
              Sp4M @Mykle1
              I did. It works with additionnal calculations if you want to use temperatures - you have to average all temperatures (min and max) from all 3h timepoints of one day.
              By the way, it’s less precise than real min and max of the day …
              @Mykle1 : how could it be a problem of MM version if openweather does not recognize “forecast/daily” in its url in your opinion ? I should have missed something
              Mykle1M 2 Replies Last reply Reply Quote 0
                Mykle1 Project Sponsor Module Developer @Sp4M
                @Sp4M said in Problem with Weather forecast:
                Honestly, I don’t know. What I DO know is my appid was being rejected under MM 2.1.2, as reported by the console. Went back to 2.1.1 and the appid is accepted normally. I didn’t investigate any further. Perhaps something in the way the request is being made? I just don’t know.
                  Well, I just moved to the develop branch, and although the unauthorized appid error is gone, weatherforecast still won’t work, and a new error is reported. The module simply stays on “Loading . . .”
                  0_1504656609763_dev.JPG 0_1504656628065_dev error.JPG 0_1504656640984_dev loading.JPG
                  ? 2 Replies Last reply Reply Quote 0
                  • ? Offline
                    A Former User @Mykle1
                    @Mykle1 I dont know about rhis module, but youd better to see scale field in config. I guess it is missed or invalid.
                    • ? Offline
                      @Mykle1 I read dev codes now, scale is not documented yet.(and it has also defined wrongly in defaults.)
                      Maybe scale:"c" or scale:"f" may work.
                      • L Offline
                        luizcarlosnery
                        Same personal problem.
                        Mm2 does not display the Weatherforecast on the screen.
                        • 2 / 5
