    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 240.2k Views 28 Watching
    • cowboysdudeC
      cowboysdude Module Developer @mirko3000
      @mirko3000 said in MMM-xiaomi - Temperature and Humidity from your smarthome:
      window sensors
      What is the module your door/window sensors? I find two but not sure which ones to use here.
      • A
        Albert2002
        I have the Xiaomi. I don’t think there is a difference apart from the design:
        Xiaomi vs Aqara door/window sensors
        • B
          barnosch
          So.
          At least 4 Temperature sensors arrived today. Waiting for the gateway which comes another way.
          looks great @mirko3000
          Really looking forward for it.
          I hate waiting for stuff…
          M 1 Reply Last reply
          • M
            mirko3000 @barnosch
            Ok, get ready to test the latest version! I kept the current table view for now, still planning to also support a grid view soon.
            New features:
            • Listens to update events of the sensors instead of refreshing the whole list all x seconds
            • Reorganized your smart home structure, introducing rooms with sensors
            • Shows ventilation recommendation, window open state and light on state per rooms
            Looking forward to get some feedback. As I do not have any lights at the moment this is untested.
            Not for the update: you will need to execute “npm install” again as I had to fork the miio library to support the events (maybe even delete the node_modules folder in your modules directory). Also you need to update your module configuration!
            K 1 Reply Last reply
            Reply Quote 1
            • cowboysdudeC
              WOW this is really awesome! Thank you for your hard work. Looking forward to getting my sensors… should be here next week I hope
              • A
                Albert2002
                Its working for me. No errors in the logs or the brower debug. Well done & thank you for your work!
                I can test it whit only one sensor so far. Waiting for the others.
                • K
                  kasperb @mirko3000
                  @mirko3000 This looks like a great module, and can’t wait to try it! Just ordered the gateway, and will be ordering some temperature sensors soon.
                  Will the Smart Air Pressure Temperature Humidity Environment Sensor work with this module as well? Like this one on: Aliexpress
                  Thanks!
                  • A
                    Albert2002
                    Haven’t seen, that the Aqara sensor has pressure as well! They both has been on sale last week for less than 6€ on GB.
                    I have taken the Xiaomi…
                    • M
                      mirko3000 @kasperb
                      @kasperb Yes I am pretty sure they work as well. Did not see those before, looks interesting though I am not sure what to use the air pressure values for!? :)
                      • K
                        kasperb @mirko3000
                        @mirko3000 Thanks! And agreed, I’ve opted for the regular temperature sensor instead.
                        • T
                          trividar
                          could someone help me? I installed it how described but it didn’t show any informations on the MM just temperature/humidity. At the beginning i see connecting to xiaomi getway and after that nothing. In the MM out i get this:
                          Found device with ID 158.... of type sensor
                          but no errors.
                          Once I saw this, but just once (but nothing on the mirror):
                          • M
                            mirko3000 @trividar
                            So technically your gateway and sensors seem to be working properly. What exactly is the problem? Did you configure your rooms and devices as described? Do you see anything on the MM? “just temperature/humidity” - that is actually the main feature :)
                            • T
                              trividar
                              Hi mirko,
                              the problem is, that i did’t see any values on the MM:
                              and also something strange, if i start this module my WunderGround module change the top of it:
                              if I disable this module it looks like usual, i changed in other positions but the same things.
                              Why is this happen?
                              What you mean with: “Did you configure your rooms and devices as described?” I did exactly what was on github.
                              THX a lot for your help
                              • M
                                mirko3000 @trividar
                                Can you post the configuration for the Xiaomi module? You need to provide a list of rooms, each of one with the assigned device IDs:
                                	            rooms:  [
                                		            	sortOrder: 40,
                                		            	devices : ['158d010171840d', '158d00016cddae']
                                		            	sortOrder: 70,
                                		            	devices : ['158d0001735ac2']
                                Also please check that you use the latest version.
                                About that WunderGround module: I need to test that myself, not sure why there are such kind of interferences.
                                • T
                                  trividar
                                  I have the latest version and thats my config:
                                  		module: 'MMM-xiaomi',
                                  		position: 'bottom_left',
                                  		header: 'Temperature / Humidity',  // This is optional
                                  			interval: 30,
                                  			gatewayIP: '192.168.1.128',
                                  			gatewayToken: '65764848557cccc2170d1fd8c06b32cb',
                                  			devices: [{
                                  • M
                                    mirko3000
                                    That is the config for the old version. Please check the README carefully:
                                    https://github.com/mirko3000/MMM-xiaomi#configuration-options
                                    			interval: 30,
                                    			rooms: [{
                                    			       name: 'Schlafzimmer temp' ,
        devices:[ '158d0001dfdb14'],
        sortOrder: 1
                                    • T
                                      trividar
                                      oooo shit…my mistake! It works now… thank’s a lot for your help…your a hero.
                                      please chack this with WunderGround it would be really nice…
                                      THANKS A LOT!
                                      • A
                                        Albert2002
                                        I’ve pulled the latest update today. Since this i don’t see the temperature / humidity any more. I don’t have any errors in my logs depending MMM-xiaomi. The config.js is the same as well. Browser debug without errors. The only error which is new in my log is about the module nerwork scanner.
                                        By the way: Do I add the window sensors the same way as the Temperature sensor? Which lights are supported?
                                        empty
                                        mm error:
                                        TypeError: Cannot read property 'network' of undefined
                                            at Class.scanNetworkMAC (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
                                            at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
                                            at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:103:11)
                                            at emitTwo (events.js:106:13)
                                            at Socket.emit (events.js:194:7)
                                            at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:514:12
                                            at _combinedTickCallback (internal/process/next_tick.js:73:7)
                                            at process._tickCallback (internal/process/next_tick.js:104:9)
                                        mm out:
                                        > magicmirror@2.1.3 start /home/pi/MagicMirror
                                        > sh run-start.sh
                                        Starting MagicMirror: v2.1.3
                                        Loading config ...
                                        Loading module helpers ...
                                        Module helper loaded: MMM-Remote-Control
                                        Module helper loaded: MMM-DWD-WarnWeather
                                        Module helper loaded: MMM-PNews
                                        Module helper loaded: internet-monitor
                                        Module helper loaded: MMM-MovieListings
                                        Module helper loaded: MMM-Fuel
                                        Module helper loaded: MMM-NetworkScanner
                                        Module helper loaded: MMM-nasaastropic
                                        Module helper loaded: MMM-SystemStats
                                        No helper found for module: MMM-Carousel.
                                        Module helper loaded: MMM-Events
                                        Module helper loaded: MMM-xiaomi
                                        All module helpers loaded.
                                        You're using a full whitelist configuration to allow for all IPs
                                        Server started ...
                                        Connecting socket for: MMM-Remote-Control
                                        Starting node helper for: MMM-Remote-Control
                                        Connecting socket for: MMM-DWD-WarnWeather
                                        MMM-DWD-WarnWeather helper started...
                                        Connecting socket for: MMM-PNews
                                        Starting module: MMM-PNews
                                        Starting module: newsfeed
                                        Connecting socket for: internet-monitor
                                        internet-monitor helper started ...
                                        Connecting socket for: MMM-MovieListings
                                        MMM-MovieListing helper started...
                                        Connecting socket for: MMM-Fuel
                                        Starting module helper: MMM-Fuel
                                        Connecting socket for: MMM-NetworkScanner
                                        Starting module: MMM-NetworkScanner
                                        Connecting socket for: MMM-nasaastropic
                                        Starting node helper: MMM-nasaastropic
                                        Connecting socket for: MMM-SystemStats
                                        Connecting socket for: MMM-Events
                                        Starting node_helper for: MMM-Events
                                        Connecting socket for: MMM-xiaomi
                                        Starting xiaomi helper
                                        Launching application.
                                        MMM-NetworkScanner received SCAN_NETWORK
                                        MMM-NetworkScanner is performing arp-scan
                                        Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/basic.ics - Interval: 300000
                                        Create new news fetcher for url: http://www.haz.de/rss/feed/haz_schlagzeilen - Interval: 300000
                                        Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/index.rss - Interval: 300000
                                        starting internet monitor node helper
                                        MMM-NetworkScanner received CONFIG
                                        astro helper: config received
                                        retrieveAndUpdate()
                                        Sat Nov 18 2017 10:10:53 GMT+0100 (CET): Triggering Xiaomi Gateway connect
                                        NASA Astro Pic of the Day URL: https://apod.nasa.gov/apod/image/1711/20171117dawnTezel1200c.jpg
                                        Found device with ID 158d000119fcb2 of type magnet
                                        Found device with ID 158d00015aa973 of type controller
                                        Found device with ID 158d00015736a8 of type sensor
                                        • M
                                          mirko3000 @Albert2002
                                          Can you post your configuration for the module? You now need to define your rooms, it looks like the module simply does not find any room to show.
                                          And yes, you add all devices to your room configuration, the module can identify the type and handle it correspondingly.
                                          BTW: suggest tracking issues on the github issue tracker: https://github.com/mirko3000/MMM-xiaomi/issues
                                          • A
                                            Albert2002
                                            Am sorry, it was my mistake. I did not checked my config.js. Out of nowhere there was again
                                            devices:
                                            instead of
                                            rooms:
                                            Thank you for your help!
                                            I’ve tried to get the icon for the open state of the window sensors working this way:
                                            The first ID is the temperature sensor, the second one the window sensors:
                                            		header: 'Temperatur / Feuchtigkeit',  // This is optional
                                            			gatewayIP: '192.168.2.160',
                                            			gatewayToken: '6ebf9b84e5c615c09268166a99b95f0a',
                                            			showWindow: true,
                                            			rooms: [
                                            			{ name: 'Wohnzimmer', sortOrder: 30, devices : ['158d00015736a8', '158d000119fcb2'] },
                                            and this way:
                                            			rooms: [
                                            			{ name: 'Wohnzimmer', sortOrder: 30, showWindow: true, devices : ['158d00015736a8', '158d000119fcb2'] },
                                            Both times MM did not started because of errors in the config. How is the right way to get this solved?
                                            • 6
                                            • 7
                                            • 8
                                            • 3 / 8
