    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 240.2k Views 28 Watching
    • M
      mirko3000 @Albert2002
      Your first config is correct, I guess you might have made an error somewhere else in your config, I could run your config successfully.
      • A
        Albert2002
        Hmm… I must have had a typo somewhere. Now the config is working for me as well but still no icon.
        this is how it works so far:
        		module: 'MMM-xiaomi',
        		position: 'bottom_left',
        		header: 'Temperatur / Feuchtigkeit',  // This is optional
        			gatewayIP: '192.168.2.160',
        			gatewayToken: '6ebf9b84e5c615c09268166a99b95f0a',
        			showWindow: true,
        			rooms: [
        			{ name: 'Wohnzimmer', sortOrder: 30, devices : ['158d00015736a8', '158d000119fcb2'] },
        This is what I get:
        alt text
        mm out:
        > magicmirror@2.1.3 start /home/pi/MagicMirror
        > sh run-start.sh
        Starting MagicMirror: v2.1.3
        Loading config ...
        Loading module helpers ...
        Module helper loaded: MMM-Remote-Control
        Module helper loaded: MMM-PNews
        Module helper loaded: internet-monitor
        Module helper loaded: MMM-MovieListings
        Module helper loaded: MMM-Fuel
        Module helper loaded: MMM-NetworkScanner
        Module helper loaded: MMM-nasaastropic
        Module helper loaded: MMM-SystemStats
        No helper found for module: MMM-Carousel.
        Module helper loaded: MMM-Events
        Module helper loaded: MMM-xiaomi
        All module helpers loaded.
        You're using a full whitelist configuration to allow for all IPs
        Server started ...
        Connecting socket for: MMM-Remote-Control
        Starting node helper for: MMM-Remote-Control
        Connecting socket for: MMM-PNews
        Starting module: MMM-PNews
        Starting module: newsfeed
        Connecting socket for: internet-monitor
        internet-monitor helper started ...
        Connecting socket for: MMM-MovieListings
        MMM-MovieListing helper started...
        Connecting socket for: MMM-Fuel
        Starting module helper: MMM-Fuel
        Connecting socket for: MMM-NetworkScanner
        Starting module: MMM-NetworkScanner
        Connecting socket for: MMM-nasaastropic
        Starting node helper: MMM-nasaastropic
        Connecting socket for: MMM-SystemStats
        Connecting socket for: MMM-Events
        Starting node_helper for: MMM-Events
        Connecting socket for: MMM-xiaomi
        Starting xiaomi helper
        Launching application.
        Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/basic.ics - Interval: 300000
        Create new news fetcher for url: http://www.haz.de/rss/feed/haz_schlagzeilen - Interval: 300000
        Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/index.rss - Interval: 300000
        starting internet monitor node helper
        MMM-NetworkScanner received CONFIG
        astro helper: config received
        retrieveAndUpdate()
        Sat Nov 18 2017 15:55:41 GMT+0100 (CET): Triggering Xiaomi Gateway connect
        NASA Astro Pic of the Day URL: https://apod.nasa.gov/apod/image/1711/20171117dawnTezel1200c.jpg
        Found device with ID 158d000119fcb2 of type magnet
        Found device with ID 158d00015aa973 of type controller
        Found device with ID 158d00015736a8 of type sensor
        No errors in the log
        M 1 Reply Last reply
        • M
          Note that the icon only appears on open windows - its a white star. If the window is closed you will not see any icon. Also I have noticed that the open state is not really reliable, need to check with miio why there are so many false states sent.
          A 1 Reply Last reply
          • A
            Albert2002 @mirko3000
            @mirko3000 said in MMM-xiaomi - Temperature and Humidity from your smarthome:
            That was the point that i’ve missed! when I open the window, the white star appears impatiently! I love this module! Thank you for your work!
            • M
              Don’t forget to update the npm packages (miio), there is a bugfix which caused wrong close events of the windows. Either ‘npm update’ in the MMM-xiaomi folder, or delete the “node_modules” folder and simply execute ‘npm install’ again.
              • A
                Albert2002
                Now I did so. Thank you for the hint!
                • A
                  Albert2002
                  My new sensors are arrived… I love it! Great work!
                  alt text
                  Which lights are supported?
                  • M
                    mirko3000
                    Check your devices here:
                    https://github.com/aholstenson/miio/blob/master/docs/devices/README.md#models-by-name
                    As you see not all Yeelights are supported, others are untested. My module retrieves all devices of type ‘light’, so it might work for all of them.
                    • B
                      barnosch
                      hi,
                      finally my gateway arrived today. Great. it is working after a little struggeling to get the correct App to initally configure the stuff.
                      I added 4 temp/humidity sensors and i am wondering how to see in the miio discovery whick one is in which room?
                      Any chance to get that ?
                      I the app itself i sadly can’t see the IDs of the sensors?
                      How did you figured this out?
                      • A
                        Albert2002
                        I’ve added them one by one. Remove them all and add them one by one. Or add all of them to the module. Then its easy to discover if you keep one of them somewhere cold, all the other warm. The Id and the temperature will guide you.
                        • T
                          trividar
                          Hi, if i set in the custom css file mmm-xiaomi .xsmall and the text-align: right then the humidity and temerature are going on the right side but the “>” stay. How can I move also “>” to right?
                          @barnosch I have done it like @Albert2002 described.
                          THX
                          • B
                            barnosch
                            @trividar
                            they are not belonging to the same TD so it is not moving aswell.
                            is it the trending, or what is it good for? i don’t really like it to be honest.
                            For me it was too close also, i just added some nbsp; to get some spaces between.
                            thanks for the hints.
                            i added all the ids and checked in the app, which room is showing the current values and added it to the correct rooms i created in the config.
                            • M
                              mirko3000
                              Yes the identification of the sensors is not really good, did not find a better solution so far.
                              As for the trend indicators: I pushed a new version where you can disable the trend icons (showTrend: false).
                              Reply Quote 1
                              • A
                                Albert2002
                                Just want to say that there is no different between the Xiaomi and Aqara Temperature sensor. Both are working like a charm. The only different is that the Aqara shows the Air pressure (in the MiHome app) as well.
                                @Mirko3000 Thank you for your hard work! You are always improving the module in light-speed!
                                I was playing around with my Yeelights colorbulbs but I didn’t get it working on MM. Guessing its because of they have they own ID, IP and token. However, thats why am still using the app. :-)
                                • M
                                  mirko3000
                                  Did you try with the ‘miio --discover’ command line utility? Do the lights show up there?
                                  • A
                                    Yes I did so with success. I got the ID, IP and token. I had tried to add it like a sensor this way:
                                    			showWindow: true,
                                    			showVentilation: false,
                                    			minTemperature: false,
                                    			maxHumidity: false,
                                                            showLights: true
                                    			rooms: [
                                    			{ name: 'Bad', sortOrder: 30, devices : ['158d0001b911b9'] },
                                    			{ name: 'Schlafzimmer', sortOrder: 30, devices : ['158d0001b91177', '158d00011919a3', '56234267'] }, //Bulp ID
                                    			{ name: 'Arbeitszimmer', sortOrder: 30, devices : ['158d0001b9035b'] },
                                    			{ name: 'Draußen', sortOrder: 30, devices : ['158d0001b920bd'] },
                                    and this way:
                                    			showWindow: true,
                                    			maxHumidity: false,
                                                            showLights: true
                                    			{ name: 'Schlafzimmer', sortOrder: 30, devices : ['158d0001b91177', '158d00011919a3', ] },
                                                           gatewayIP: '192.168.2.101', // IP of the bulp
                                    			gatewayToken: 'fd1d31c907fc5506fc379445eb6bd146', // token of the bulp
                                    rooms: [
                                    { name: 'Flur', sortOrder: 30, devices : ['56234267'] }, // ID of the bulp
                                    Btw I noticed some behaver am not sure about.
                                    How to get rid of the notification about Humidity?
                                    alt text
                                    Its Full screen and always on the top. Even when the pages changing using MMM-Carousel its still on top.
                                    Using stars as notification for open windows:
                                    When I was gone to bed at night with open window there was a star shown. In the morning still with open window the star was gone. What happens there?
                                    Are there no more indicators for the trent?
                                    alt text
                                    • M
                                      mirko3000
                                      Hmm those Yeelights seem to be quite different, guess it will be hard to implement without having at least one piece on my own…
                                      For the notifications: this is a magic mirror default, so I can’t change the behaviour. In your case you should configure your outside sensor (parameter outsideSensorId), then this will not show any notification. It is mainly used for indoor rooms. I can of course add a config to disable notifications at all.
                                      The window states are not 100% reliable. It seems that sometimes the sensors send wrong values, I need to investigate why this is the case.
                                      To your last question: I disabled the trend indicators by default, but you can re-enable them by setting the config: showTrend: true
                                      • M
                                        mirko3000
                                        Oh and I just fixed an issue with the notifications, they should disappear after 10 seconds, now they do again :)
                                        BTW: please use the issue tracker on github to track issues, this helps other find similar problems:
                                        https://github.com/mirko3000/MMM-xiaomi/issues
                                        • A
                                          Albert2002
                                          Thank you for this! :)
                                          In the future I’ll use the issue tracker.
                                          • cowboysdudeC
                                            cowboysdude Module Developer
                                            Excellent!!! All working.
                                            • 6
                                            • 7
                                            • 8
                                            • 4 / 8
