    Setting up Magic Mirror remotely?
    Scheduled Pinned Locked Moved Solved General Discussion
    16 Posts 5 Posters 5.9k Views 5 Watching
      Mykle1 Project Sponsor Module Developer @navyvette87
      @navyvette87
      I’ve never encountered that before. Maybe, revert the changes you just made, get your mirror running, then try them again, 1 at a time
      • N Offline
        navyvette87
        fixed the light display thing by rebooting with hdmi unplugged, then repluging it in, then rebooting, but the ssh message still there
        • ? Offline
          A Former User @navyvette87
          @navyvette87
          SSH is enabled and the default password for the ‘pi’ user has not been changed. This is a security risk - please login as the ‘pi’ user and type passwd to set a new password.
          It means as written. Change your password with command passwd.
          just try passwd in your terminal.
          • N Offline
            navyvette87 @Guest
            @Sean It ended up being one of the changes I made to set up the pi for the screensaver edit. I did try passwd though. thanks eveyone. I got it up and running. I have another post for a module problem, once I get that figured out, I will start on the hardware.
            • MikgaboM Offline
              Mikgabo
              Hey guys,
              Noob question…
              So, I’m running MM2 on my Pi Zero W and can’t figure out home to get to my config.js through terminal. Can someone help me out???
              Cheers,
              Mike
              MikgaboM 1 Reply Last reply Reply Quote 0
              • MikgaboM Offline
                Mikgabo @Mikgabo
                NEVER MIND…FIGURED IT OUT :)
