    ipWhitelist - still not working
    10 Posts 5 Posters 5.7k Views 5 Watching
    • B
      binderth
      I’m using MM2 (latest) with pm2.
      in my config.js I tried everything, even this latest one:
      var config = {
      	port: 8080,
      	language: 'de',
      	timeFormat: 24,
      	units: 'metric',
      	ipWhitelist: [],
      in startup I get this in the log:
      All module helpers loaded.
      You're using a full whitelist configuration to allow for all IPs
      Server started ...
      I have no iptables in place:
      pi@MagicMirror2:~ $ sudo iptables -L
      Chain INPUT (policy ACCEPT)
      target     prot opt source               destination
      Chain FORWARD (policy ACCEPT)
      Chain OUTPUT (policy ACCEPT)
      pi@MagicMirror2:~ $
      stil, if I try to reach the MagicMirror from my Laptop, I see the connection refused message:
      I can reach the Pi without problems on SSH-port and even send him MQTT-updates. So I assume, there’s no issue with iptables (as seen above, it’s all open).
      Is there anywhere, I can have a look on to solve this?
      ? 1 Reply Last reply
      • B
        binderth
        oh. not exactly. After some time now, it works! Don’t know, what it took some time, aber now it works!
          A Former User @binderth
          @binderth
          Try 0.0.0.0/0 for IpWhiteList.
          B 1 Reply Last reply
          • B
            binderth @Guest
            @Sean said in ipWhitelist - still not working:
            0.0.0.0/0
            same error on the Laptop.
            Still no change with the netstat:
            pi@MagicMirror2:~ $ sudo netstat -lnpt
            Aktive Internetverbindungen (Nur Server)
            Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      441/sshd
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      462/mosquitto
            tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      490/vncserver-x11-c
            tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      909/electron.js
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @binderth
              @binderth
              Add address: "0.0.0.0", to your config, outside your whitelist:
              var config = {
                  port: 8080,
                  address: "0.0.0.0",
                  ipWhitelist: [], // Set [] to allow all IP addresses.
                  language: "en",
                  timeFormat: 12,
                  units: "imperial",
              B S 2 Replies Last reply
              Reply Quote 1
              • B
                binderth @Mykle1
                @Mykle1 no Change here… :(
                • B
                  binderth
                    schlachtkreuzer6 @Mykle1
                    @Mykle1 THAAANKS! ;) run in the same issue after the latest update
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @schlachtkreuzer6
                      @schlachtkreuzer6 said in ipWhitelist - still not working:
                      You’re welcome, mate! Enjoy!
                        SimtechBen @Mykle1
                        @Mykle1 Thank you! This fixed a problem I was having with openHAB sending sendHttpGetRequest.
                        Reply Quote 1
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @SimtechBen
                          @SimtechBen
                          Nice!
