    ipWhitelist - still not working
    10 Posts 5 Posters 5.3k Views 5 Watching
    • binderthB Offline
      binderth @Guest
      @Sean said in ipWhitelist - still not working:
      0.0.0.0/0
      same error on the Laptop.
      Still no change with the netstat:
      pi@MagicMirror2:~ $ sudo netstat -lnpt
      Aktive Internetverbindungen (Nur Server)
      Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      441/sshd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      462/mosquitto
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      490/vncserver-x11-c
      tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      909/electron.js
        Mykle1 Project Sponsor Module Developer @binderth
        @binderth
        Add address: "0.0.0.0", to your config, outside your whitelist:
        var config = {
            port: 8080,
            address: "0.0.0.0",
            ipWhitelist: [], // Set [] to allow all IP addresses.
            language: "en",
            timeFormat: 12,
            units: "imperial",
        binderthB schlachtkreuzer6S 2 Replies Last reply Reply Quote 1
        • binderthB Offline
          binderth @Mykle1
          @Mykle1 no Change here… :(
          • binderthB Offline
            binderth
            oh. not exactly. After some time now, it works! Don’t know, what it took some time, aber now it works!
            • schlachtkreuzer6S Offline
              schlachtkreuzer6 @Mykle1
              @Mykle1 THAAANKS! ;) run in the same issue after the latest update
                Mykle1 Project Sponsor Module Developer @schlachtkreuzer6
                @schlachtkreuzer6 said in ipWhitelist - still not working:
                You’re welcome, mate! Enjoy!
                  SimtechBen @Mykle1
                  @Mykle1 Thank you! This fixed a problem I was having with openHAB sending sendHttpGetRequest.
                    Mykle1 Project Sponsor Module Developer @SimtechBen
                    @SimtechBen
                    Nice!
