ipWhitelist - still not working
10 Posts 5 Posters 4.6k Views 5 Watching
    binderth
    I’m using MM2 (latest) with pm2.
    in my config.js I tried everything, even this latest one:
    var config = {
    	port: 8080,
    	language: 'de',
    	timeFormat: 24,
    	units: 'metric',
    	ipWhitelist: [],
    in startup I get this in the log:
    All module helpers loaded.
    You're using a full whitelist configuration to allow for all IPs
    Server started ...
    I have no iptables in place:
    pi@MagicMirror2:~ $ sudo iptables -L
    Chain INPUT (policy ACCEPT)
    target     prot opt source               destination
    Chain FORWARD (policy ACCEPT)
    Chain OUTPUT (policy ACCEPT)
    pi@MagicMirror2:~ $
    stil, if I try to reach the MagicMirror from my Laptop, I see the connection refused message:
    I can reach the Pi without problems on SSH-port and even send him MQTT-updates. So I assume, there’s no issue with iptables (as seen above, it’s all open).
    Is there anywhere, I can have a look on to solve this?
    ? 1 Reply Last reply Nov 8, 2017, 10:15 AM Reply Quote 0
      binderth
      oh. not exactly. After some time now, it works! Don’t know, what it took some time, aber now it works!
        A Former User @binderth
        @binderth
        Try 0.0.0.0/0 for IpWhiteList.
        B 1 Reply Last reply Nov 8, 2017, 10:41 AM Reply Quote 0
          binderth @Guest
          @Sean said in ipWhitelist - still not working:
          0.0.0.0/0
          same error on the Laptop.
          Still no change with the netstat:
          pi@MagicMirror2:~ $ sudo netstat -lnpt
          Aktive Internetverbindungen (Nur Server)
          Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      441/sshd
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      462/mosquitto
          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      490/vncserver-x11-c
          tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      909/electron.js
          M 1 Reply Last reply Nov 8, 2017, 12:07 PM Reply Quote 0
            Mykle1 Project Sponsor Module Developer @binderth
            @binderth
            Add address: "0.0.0.0", to your config, outside your whitelist:
            var config = {
                port: 8080,
                address: "0.0.0.0",
                ipWhitelist: [], // Set [] to allow all IP addresses.
                language: "en",
                timeFormat: 12,
                units: "imperial",
            B S 2 Replies Last reply Nov 8, 2017, 1:10 PM Reply Quote 1
              binderth @Mykle1
              @Mykle1 no Change here… :(
                binderth
                  schlachtkreuzer6 @Mykle1
                  @Mykle1 THAAANKS! ;) run in the same issue after the latest update
                  M 1 Reply Last reply Nov 13, 2017, 10:42 PM Reply Quote 0
                    Mykle1 Project Sponsor Module Developer @schlachtkreuzer6
                    @schlachtkreuzer6 said in ipWhitelist - still not working:
                    You’re welcome, mate! Enjoy!
                    S 1 Reply Last reply Dec 29, 2017, 9:56 AM Reply Quote 0
                      SimtechBen @Mykle1
                      @Mykle1 Thank you! This fixed a problem I was having with openHAB sending sendHttpGetRequest.
                      M 1 Reply Last reply Dec 29, 2017, 11:52 AM Reply Quote 1
                        Mykle1 Project Sponsor Module Developer @SimtechBen
                        @SimtechBen
                        Nice!
