    MM is eating all memory and crash!
    18 Posts 5 Posters 12.3k Views 4 Watching
      juergschwarz
      Now after two weeks, two different SD Cards and two totaly separated new installations i am at the end of my brain.
      Raspberry 2 B+ with latest stretch
      First i had to downgrade electron to 1.4.15 couse of high cpu usage (over 300%) and stocking seconds on screen in clock module. Like 21…25…35… till nothing anymore.
      Now i am checking my ram usage. With maybee 6 modules like
      clock
      weather
      weatherforecast
      MMM-cryptocurrency.git
      MMM-swisstransport.git
      MMM-pihole-stats.git
      my MM is running only 2 or 3 hours. After that my memory is less than 13% or apr. 100MB free i got the same problem as above.
      Now i check same problem with only 3 standard module. Since last 12h my memory decreased from 50% free to 28% now and counting down.
      What the hell can i do?
      J Mykle1M Y 3 Replies Last reply Reply Quote 0
        juergschwarz @juergschwarz
        Is anyone able to show me a list of used modules, memory and uptime ?
          Mykle1 Project Sponsor Module Developer @juergschwarz
          @juergschwarz said in MM is eating all memory and crash!:
          About three months ago most all of these concerns were addressed by me and a few other fantastic people. We did quite a bit of troubleshooting. You will certainly benefit from reading through this and taking the necessary steps:
          https://forum.magicmirror.builders/topic/4684/electron-cpu-usage
          Note:
          Most, if not all of the people involved, were using a Pi3.
          Some modules present a higher system load than others.
          Opinion:
          Use Jessie, not Stretch
          J Mykle1M 2 Replies Last reply Reply Quote 0
            juergschwarz @Mykle1
            Now i changed to Raspberry 3. After 2h system crashed. 4MB memory left.
            This is my sylog
            Nov 9 22:03:06 raspi32 kernel: [ 5458.473560] Out of memory: Kill process 880 (electron) score 948 or sacrifice child
            Nov 9 22:03:06 raspi32 kernel: [ 5458.473695] Killed process 880 (electron) total-vm:981380kB, anon-rss:671832kB, file-rss:104kB, shmem-rss:7180kB
            Nov 9 22:05:58 raspi32 systemd[1]: Started Session c4 of user pi.
            This is not realy what i can use. I dont like to change to debian 8.
              A memory leak was discussed in the topic I recommended to you. Was that result with the default installation of MM or did you add other modules?
              Your choice, sir. Good luck :-)
                @Mykle1 With Rasp 3 i checked again with this six modules on 1. thread. Whitch Raspi .iso do you guy use for MM? Maybee i should install all things manual instead of this automatic installation? Memory leak not possible couse of Raspi 2 was the same issue and 2 different SD Cards.
                  @juergschwarz
                  Question:
                  Did you read the topic I suggested to you? I’m curious
                    @Mykle1 Yes i read it. All of this suggestions i already checked out. If you tell me to test standard installation whitout any additional modules - what the hell do all this people building such modules when i only can use standard modules?
                    Dont misunderstand me. But i manage two root servers with kvm - lvm and aprox. 30 official domains and nearly 200 email accounts. Longest uptime was 772 days. Nobody can tell me a application with black background and some “only text foreground apps” should not be able to run more than 2 hours or not?
                      Very good. You had the benefit of other people’s time and hard work. Imagine if you had to think of all those tests for yourself.
                      Logically, that would be a starting point, to see if the issue arises before the addition of other modules. If the problem arises afterward, then you can attribute the cause to something that you added. If not, then the cause lies in the OS version, the MM version, or with the Pi itself, or the way it was prepared.
                      I could not be less impressed.
                      Nobody is telling you anything. I thought you wanted help so I started where anyone would start, at the beginning. Instead of some small measure of gratitude, you started spewing your impotent anger at me.
                      I only have one more question for you.
                      With the impressive resume you have, why didn’t you just figure it out and fix it yourself? :-)
                      • cowboysdudeC Offline
                        cowboysdude Module Developer
                        You are in the minority … I have 3 running, without issues… 1 of them has been running a solid year without any issues what-so-ever.
                        With that being said being rude to someone trying to help you is not really a way to get help…
                        • emloweE Offline
                          emlowe Module Developer
                          $ uptime
                           21:34:37 up 37 days, 58 min,  3 users,  load average: 0.08, 0.13, 0.09
                          $ cat /etc/issue
                          Raspbian GNU/Linux 8 \n \l
                          $ uname -a
                          Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
                          $ free -m
                                       total       used       free     shared    buffers     cached
                          Mem:           923        878         44        149         64        487
                          -/+ buffers/cache:        326        596
                          Swap:           99         99          0
                          $ df -k
                          Filesystem     1K-blocks    Used Available Use% Mounted on
                          /dev/root        5863924 4248140   1294864  77% /
                          devtmpfs          468148       0    468148   0% /dev
                          tmpfs             472756  147656    325100  32% /dev/shm
                          tmpfs             472756   12364    460392   3% /run
                          tmpfs               5120       4      5116   1% /run/lock
                          tmpfs             472756       0    472756   0% /sys/fs/cgroup
                          /dev/mmcblk0p6     66528   21418     45110  33% /boot
                          tmpfs              94552       0     94552   0% /run/user/1000
                          tmpfs              94552       0     94552   0% /run/user/1001
                          /dev/mmcblk0p5     30701     463     27945   2% /media/elowe/SETTINGS
                           $ npm ls | grep -i magicmirror
                          magicmirror@2.1.3
                          $ npm ls | grep electron
                          ├─┬ electron@1.7.5
                          │ ├─┬ electron-download@3.3.0
                          │ ├─┬ electron-chromedriver@1.6.0
                          │ │ ├── electron-download@3.3.0 deduped
                          │ │ │ └── electron-to-chromium@1.3.24
                          Modules:
                          • clock
                          • currentweather
                          • weatherforecast
                          • MMM-MyScoreboard
                          • MMM-EnphaseEnvoy
                          • MMM-CalenderExt
                          • MMM-AirNow
                          • MMM-AutelisPentair
                          • MMM-Globe
                          • MMM-Remote-Control
                          • MMM-PIR-Sensor
                          • emloweE Offline
                            Oh, and MM specifically is up for 20days:
                            pm2 show mm
                             Describing process with id 0 - name mm
                            │ status            │ online                               │
                            │ name              │ mm                                   │
                            │ restarts          │ 6                                    │
                            │ uptime            │ 20D
                            • Y Offline
                              yawns Moderator @juergschwarz
                              @juergschwarz
                              Uninstall PiHole. If you search this forum for PiHole you will find two other threads with similar memory issues, both related to PiHole. After removing it the issue was gone.
                              Mykle1M J 2 Replies Last reply Reply Quote 1
                                juergschwarz @emlowe
                                @all Ok sorry. Now my realy newest installation on Raspi 3 stretch wiht realy original config.js and no additional modules or other changes:
                                pi@raspi32:~/MagicMirror $ npm ls | grep electron
                                ├─┬ electron@1.7.9
                                │ │ │ └── electron-to-chromium@1.3.27
                                PageSize:4KB     RAM-Memory  Swap-space     High-Memory     Low-Memory                                    │
                                │ Total in MB           927.3       100.0     - not in use   - not in use                                   │
                                │ Free  in MB           424.9       100.0        │
                                │ Free Percent           45.8%      100.0%        │
                                │ Linux Kernel Internal Memory (MB)        │
                                │                        Cached=     254.6     Active=     259.0                                            │
                                │ Buffers=      36.2 Swapcached=       0.0  Inactive =     203.0                                            │
                                │ Dirty  =       0.1 Writeback =       0.0  Mapped   =     147.6                                            │
                                │ Slab   =      25.3 Commit_AS =    1412.1 PageTables=       4.6                                            │
                                │ Top Processes Procs=161-mode=3-1=Base 3=Perf 4=Size 5=I/O[RootOnly] u=Args────────────────────────────────│
                                │  PID    %CPU  Size   Res   Res   Res   Res Shared   Faults  Command                                       │
                                │          Used    KB   Set  Text  Data   Lib    KB  Min  Maj                                               │
                                │     922 354.8   297m   98m52660   131m    0 56268  249    0 electron                                      │
                                │     928   5.4   295m69924 52660   143m    0 48540  111    0 electron                                      │
                                │     865   4.4   454m85120 52660   297m    0 58716    0    0 electron                                      │
                                │     896   2.0  6156  3828   156  3572     0  1572    0    0 nmon                                          │
                                │     521   1.5   134m43540  1896 62820     0 21740    0    0 Xorg
                                Now i will check it out with jessie :-(
                                  Mykle1 Project Sponsor Module Developer @yawns
                                  This post is deleted!
                                    juergschwarz @yawns
                                    @yawns Thanks. But last “overnight” test with only original config.js also crashed with stretch. So now a new test with jessie looks much better. Including pi-hole. It runs since 22 mins and 47% free ram. :-)
                                    • Y Offline
                                      @juergschwarz
                                      Thanks for your feedback, good to know. So one more reason against Stretch
                                        Mykle1 Project Sponsor Module Developer @Mykle1
                                        @Mykle1 said in MM is eating all memory and crash!:
                                        I rest my case. :-)
