    MMM-syslog
    logginghome automation
    34 Posts 10 Posters 32.1k Views 11 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @PointPubMedia
      @PointPubMedia could it be the margin from the body?
      PointPubMediaP 1 Reply Last reply Reply Quote 0
      • PointPubMediaP Offline
        PointPubMedia @strawberry 3.141
        @strawberry-3.141
        all other module are correct… except this one!
          PointPubMedia
          Another cool thing could be, to be able to use classes for the MMM-Facial into syslog to display Warning/ERROR for some user…
          • paviroP Offline
            paviro @strawberry 3.141
            @strawberry-3.141 I just merged your pull request thanks! :)
            We're all stories in the end. Just make it a good one, eh?
            – The Doctor
            • cowboysdudeC Offline
              cowboysdude Module Developer
              Now this is a handy module!
                PointPubMedia
                @strawberry-3-141 hey mate… do you think it can be possible to have a way to replicate/centralize the syslog data…
                Currently I have one installation of MM in the house, but currently building a couple more. And would need to be able to share the syslog data…
                Maybe a config in syslog module to “send” data to “slave” ?
                  @PointPubMedia do you plan to run multiple independent Mirrors or do you access the one mirror via browser from the other devices?
                    @strawberry-3.141 Each mirror will run independent!
                      @PointPubMedia It should be possible to manipulate the socket connection to redirect it to your main mirror so it uses the node_helper there. So all slaves would get the data from the main node_helper. Will be busy with other modules the next days, just give me a note when you’re closer to your first slave and then we will see what we can achieve.
                      PointPubMediaP 1 Reply Last reply Reply Quote 1
                        @strawberry-3.141 I finally installed the second screen this weekend!
                        The thing also, not sure I want to have the same config on both screen (not the same size) The first screen is a 42" 1920x1080 and the second one, 32" at 1280x720…
                        It will be more useful to be able to have a “centralize” data and that each screen fetch only the data it need…
                        I currently have a raspberry pi that only have Grafana on it to log all kind of data for graph that I display under MM using iFrame. Maybe we can send all the data there with a MM running in server mode only having ONLY syslog as a module and use it to send data on other with some filtering ?
                        Maybe we can filter on the “info/warning/critical”…
                        • 3 / 4
