    MMM-syslog
    logginghome automation
    34 Posts 10 Posters 34.9k Views 11 Watching
      PointPubMedia
      @paviro @strawberry-3-141 I would like that the column for “time” should be justify at right completely. !0_1481377257671_2016-12-10 08_39_44-10.99.99.15 - PuTTY.png
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @PointPubMedia
        @PointPubMedia yes the module got merged into the repo of @paviro a while ago and another user made an update on that one, so you have to use the other repo
          PointPubMedia
            PointPubMedia
            Is it normal that the time column is not fully at the right side ?
              PointPubMedia
              @paviro @strawberry-3-141 Do you think it could be possible to have a config option to limit the lenght max of the message to be displayed ? And truncate it ?
                @PointPubMedia https://github.com/paviro/MMM-syslog/pull/6
                P P 2 Replies Last reply Reply Quote 0
                  PointPubMedia @strawberry 3.141
                  @strawberry-3.141 thanks mate! Do you know at the same time, why the column for date/time is not at the right side completely?
                    @PointPubMedia could it be the margin from the body?
                      @strawberry-3.141
                      all other module are correct… except this one!
                        PointPubMedia
                        Another cool thing could be, to be able to use classes for the MMM-Facial into syslog to display Warning/ERROR for some user…
                          paviro @strawberry 3.141
                          @strawberry-3.141 I just merged your pull request thanks! :)
                          – The Doctor
                          • cowboysdudeC Offline
                            Now this is a handy module!
                              PointPubMedia
                              @strawberry-3-141 hey mate… do you think it can be possible to have a way to replicate/centralize the syslog data…
                              Currently I have one installation of MM in the house, but currently building a couple more. And would need to be able to share the syslog data…
                              Maybe a config in syslog module to “send” data to “slave” ?
                                @PointPubMedia do you plan to run multiple independent Mirrors or do you access the one mirror via browser from the other devices?
                                  @strawberry-3.141 Each mirror will run independent!
                                    @PointPubMedia It should be possible to manipulate the socket connection to redirect it to your main mirror so it uses the node_helper there. So all slaves would get the data from the main node_helper. Will be busy with other modules the next days, just give me a note when you’re closer to your first slave and then we will see what we can achieve.
                                      @strawberry-3.141 I finally installed the second screen this weekend!
                                      The thing also, not sure I want to have the same config on both screen (not the same size) The first screen is a 42" 1920x1080 and the second one, 32" at 1280x720…
                                      It will be more useful to be able to have a “centralize” data and that each screen fetch only the data it need…
                                      I currently have a raspberry pi that only have Grafana on it to log all kind of data for graph that I display under MM using iFrame. Maybe we can send all the data there with a MM running in server mode only having ONLY syslog as a module and use it to send data on other with some filtering ?
                                      Maybe we can filter on the “info/warning/critical”…
                                        @PointPubMedia
                                        [card:fewieden/MMM-syslog-slave]
                                          jasondreher
                                          Can notificationReceived be used on other modules for this? I am looking for a way to have a PC send a notification (like syslog http request) and MM respond to this with notificationReceived.
                                          Like send “DOM_OBJECTS_CREATED” with http and have the below
                                          15 if (notification === “DOM_OBJECTS_CREATED”) {
                                          16 this.variable=“created”…
                                          For my use it would send a notification when the garage door opens and change the icon on my MM.
                                          • N Offline
                                            nobita @jasondreher
                                            @fewieden
                                            how to add sound alert after sending notifications finish
                                            and can change sound and timer
                                            Thank so much
