    MMM-syslog
    logginghome automation
    34 Posts 10 Posters 36.8k Views 11 Watching
      PointPubMedia
        PointPubMedia
        Is it normal that the time column is not fully at the right side ?
          PointPubMedia
          @paviro @strawberry-3-141 Do you think it could be possible to have a config option to limit the lenght max of the message to be displayed ? And truncate it ?
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @PointPubMedia
            @PointPubMedia https://github.com/paviro/MMM-syslog/pull/6
            P P 2 Replies Last reply
              PointPubMedia @strawberry 3.141
              @strawberry-3.141 thanks mate! Do you know at the same time, why the column for date/time is not at the right side completely?
              • strawberry 3.141S
                @PointPubMedia could it be the margin from the body?
                P 1 Reply Last reply
                  @strawberry-3.141
                  all other module are correct… except this one!
                    PointPubMedia
                    Another cool thing could be, to be able to use classes for the MMM-Facial into syslog to display Warning/ERROR for some user…
                      paviro @strawberry 3.141
                      @strawberry-3.141 I just merged your pull request thanks! :)
                      – The Doctor
                      • cowboysdudeC
                        Now this is a handy module!
                          PointPubMedia
                          @strawberry-3-141 hey mate… do you think it can be possible to have a way to replicate/centralize the syslog data…
                          Currently I have one installation of MM in the house, but currently building a couple more. And would need to be able to share the syslog data…
                          Maybe a config in syslog module to “send” data to “slave” ?
                          • strawberry 3.141S
                            @PointPubMedia do you plan to run multiple independent Mirrors or do you access the one mirror via browser from the other devices?
                              @strawberry-3.141 Each mirror will run independent!
                              • strawberry 3.141S
                                @PointPubMedia It should be possible to manipulate the socket connection to redirect it to your main mirror so it uses the node_helper there. So all slaves would get the data from the main node_helper. Will be busy with other modules the next days, just give me a note when you’re closer to your first slave and then we will see what we can achieve.
                                  @strawberry-3.141 I finally installed the second screen this weekend!
                                  The thing also, not sure I want to have the same config on both screen (not the same size) The first screen is a 42" 1920x1080 and the second one, 32" at 1280x720…
                                  It will be more useful to be able to have a “centralize” data and that each screen fetch only the data it need…
                                  I currently have a raspberry pi that only have Grafana on it to log all kind of data for graph that I display under MM using iFrame. Maybe we can send all the data there with a MM running in server mode only having ONLY syslog as a module and use it to send data on other with some filtering ?
                                  Maybe we can filter on the “info/warning/critical”…
                                  • strawberry 3.141S
                                    @PointPubMedia
                                    [card:fewieden/MMM-syslog-slave]
                                      jasondreher
                                      Can notificationReceived be used on other modules for this? I am looking for a way to have a PC send a notification (like syslog http request) and MM respond to this with notificationReceived.
                                      Like send “DOM_OBJECTS_CREATED” with http and have the below
                                      15 if (notification === “DOM_OBJECTS_CREATED”) {
                                      16 this.variable=“created”…
                                      For my use it would send a notification when the garage door opens and change the icon on my MM.
                                      N 1 Reply Last reply
                                      • N
                                        nobita @jasondreher
                                        @fewieden
                                        how to add sound alert after sending notifications finish
                                        and can change sound and timer
                                        Thank so much
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @nobita
                                          @nobita there is no sound integration
