    MMM-syslog
    logginghome automation
    34 Posts 10 Posters 36.8k Views 11 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @PointPubMedia
      @PointPubMedia could it be the margin from the body?
      P 1 Reply Last reply
        PointPubMedia @strawberry 3.141
        @strawberry-3.141
        all other module are correct… except this one!
          PointPubMedia
          Another cool thing could be, to be able to use classes for the MMM-Facial into syslog to display Warning/ERROR for some user…
            paviro @strawberry 3.141
            @strawberry-3.141 I just merged your pull request thanks! :)
            – The Doctor
            • cowboysdudeC
              Now this is a handy module!
                PointPubMedia
                @strawberry-3-141 hey mate… do you think it can be possible to have a way to replicate/centralize the syslog data…
                Currently I have one installation of MM in the house, but currently building a couple more. And would need to be able to share the syslog data…
                Maybe a config in syslog module to “send” data to “slave” ?
                • strawberry 3.141S
                  @PointPubMedia do you plan to run multiple independent Mirrors or do you access the one mirror via browser from the other devices?
                    @strawberry-3.141 Each mirror will run independent!
                    • strawberry 3.141S
                      @PointPubMedia It should be possible to manipulate the socket connection to redirect it to your main mirror so it uses the node_helper there. So all slaves would get the data from the main node_helper. Will be busy with other modules the next days, just give me a note when you’re closer to your first slave and then we will see what we can achieve.
                        @strawberry-3.141 I finally installed the second screen this weekend!
                        The thing also, not sure I want to have the same config on both screen (not the same size) The first screen is a 42" 1920x1080 and the second one, 32" at 1280x720…
                        It will be more useful to be able to have a “centralize” data and that each screen fetch only the data it need…
                        I currently have a raspberry pi that only have Grafana on it to log all kind of data for graph that I display under MM using iFrame. Maybe we can send all the data there with a MM running in server mode only having ONLY syslog as a module and use it to send data on other with some filtering ?
                        Maybe we can filter on the “info/warning/critical”…
                        • strawberry 3.141S
                          @PointPubMedia
                          [card:fewieden/MMM-syslog-slave]
                            jasondreher
                            Can notificationReceived be used on other modules for this? I am looking for a way to have a PC send a notification (like syslog http request) and MM respond to this with notificationReceived.
                            Like send “DOM_OBJECTS_CREATED” with http and have the below
                            15 if (notification === “DOM_OBJECTS_CREATED”) {
                            16 this.variable=“created”…
                            For my use it would send a notification when the garage door opens and change the icon on my MM.
                            N 1 Reply Last reply
                            • N
                              nobita @jasondreher
                              @fewieden
                              how to add sound alert after sending notifications finish
                              and can change sound and timer
                              Thank so much
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @nobita
                                @nobita there is no sound integration
