    MMM-syslog
    logginghome automation
    34 Posts 10 Posters 31.0k Views 11 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @DirkS
      @DirkS http://192.168.2.1:8080/syslog?type=INFO&message=This is a test message you need to replace the ip to yours of the mirror
      @Pbaan93 there is an undocumented config option title for it :)
        DirkS
        Oh so easy :D Thanks for the info.
        • PointPubMediaP Offline
          PointPubMedia
          @strawberry-3-141 Is it the same module you made for me a while ago or it’s a new version?
          I’m still using your https://www.github.com/fewieden/MMM-syslog
          I need to change my repo to use this one if I want the latest version ?
            PointPubMedia
            @paviro @strawberry-3-141 I would like that the column for “time” should be justify at right completely. !0_1481377257671_2016-12-10 08_39_44-10.99.99.15 - PuTTY.png
              strawberry 3.141 Project Sponsor Module Developer @PointPubMedia
              @PointPubMedia yes the module got merged into the repo of @paviro a while ago and another user made an update on that one, so you have to use the other repo
                PointPubMedia
                This post is deleted!
                  PointPubMedia
                  Is it normal that the time column is not fully at the right side ?
                    PointPubMedia
                    @paviro @strawberry-3-141 Do you think it could be possible to have a config option to limit the lenght max of the message to be displayed ? And truncate it ?
                      @PointPubMedia https://github.com/paviro/MMM-syslog/pull/6
                      PointPubMediaP paviroP 2 Replies Last reply Reply Quote 0
                        PointPubMedia @strawberry 3.141
                        @strawberry-3.141 thanks mate! Do you know at the same time, why the column for date/time is not at the right side completely?
                        • 2 / 4
