    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 684.2k Views 27 Watching
      mdhenriksen @Mykle1
      @mykle1 said in Hello-Lucy:
      @xclasher-0
      If you want to use MMM-Pages and MMM-voice then there doesn’t seem to be a need for the Hello-Lucy enhancement. I don’t think using MMM-Pages and MMM-voice will allow you to do individual modules. I think you can only go back a page or forward a page rather than from any page to any other page.
      Note: You will have to use @cowboysdude’s fork of MMM-voice with MMM-Pages
      You can make MMM-pages and MMM-voice switch between specific pages with very minors tweaks. 😀
        dazza120
        Do you have to install both forks?
          mdhenriksen @dazza120
          @dazza120 said in Hello-Lucy:
          You need to install the original one and then copy cowboydudes fork (his folders) into the original and overwrite the files that come up.
            @dazza120 Just let me know if it doesn’t work for you.
              dazza120 @mdhenriksen
              @mdhenriksen works a treat but I don’t know how to make a third page. Not sure what I’ll put on it? But I’m sure I’ll find something to install if I figure out how to add more pages it’s stuck on two at the mo 😢
                Mykle1 Project Sponsor Module Developer @mdhenriksen
                @mdhenriksen said in Hello-Lucy:
                Well, sure you can, but he didn’t mention wanting, or being able to do any modifications
                M X 2 Replies Last reply Reply Quote 1
                  mdhenriksen @Mykle1
                  @mykle1 You’re right, guess I was too fast ;-)
                    @mdhenriksen this is my config file so far for pages not sure how I add a third page any ideas
                    module: ‘MMM-pages’,
                    modules:
                    [[ “MMM-NOAA3”, “clock”, “MMM-NetworkConnection”, “mmm-hue-lights”, “mmm-nest-status”, “calendar”, “mmm-systemtemperature”, “compliments”, “newsfeed”],
                    [ “MMM-GoogleMapsTraffic” ]],
                    excludes: [“MMM-page-indicator”],
                      Hey Dazza!
                      It’s pretty easy actually. Now first you should install MMM-page-indicator as well. That makes it easier to see what page you are on.
                      Making several pages:
                             module: 'MMM-pages',
                             modules:
                                         	[[ "weatherforecast", "newsfeed", "compliments"],
                                           	[ "calendar", "compliments", "calendar2"], ["MMM-CalendarWeek"]],
                                      	excludes: ["clock", "currentweather", "MMM-page-indicator", "MMM-voice"],
                      The pages are made in an 2D-array, which is basically a line of elements separated by the brackets “[” and “]”.
                      Your array starts at the double bracket, “[[” right before “weatherforecast” and ends at the “]]” right after “MMM-CalendarWeek”. Inside the array the pages are separated by one bracket.
                      So this is a page: (remember the comma at the end)
                      And this is a page:
                      And lastly this is a page as well:
                      Remember that the array is zero-based which means that the first page will be number 0. The second will be number 1 and the third will be number 2.
                      Hope it helps! :grinning_face_with_smiling_eyes:
                        @mdhenriksen had the page indicator already but I was being a muppet, I didn’t recognise ]] as a closing part for that module, Thank you very much three pages now lol
                          @dazza120 It’s the small things that make the difference :grinning_face_with_smiling_eyes:
                          • X Offline
                            Xclasher 0 @Mykle1
                            @mykle1 Thanks :D I have tested out the integration of both modules. However, I have modified the MMM-voice to have pages in it as stated in the Hello-Lucy documentation. The modules I have included in the MMM-voice pages does not hide when I go to the specific page of the MMM-pages where the MMM-voice is. Any idea how i can hide the modules?
                            Mykle1M M 2 Replies Last reply Reply Quote 0
                            • bheplerB Offline
                              bhepler Module Developer @dazza120
                              @dazza120 - Please use the Markdown features of the forum when posting code.
                                Mykle1 Project Sponsor Module Developer @Xclasher 0
                                @xclasher-0 said in Hello-Lucy:
                                This is a bit confusing. You’re using MMM- voice with Hello-Lucy AND MMM-pages? My guide on the Hello-Lucy repo is quite easy to follow but I can still help with that. If you’re trying to integrate MMM-pages with that as well then I can’t help you. MMM-pages is not my module. I’ve never used it. You would likely have to modify MMM-voice and MMM-pages
                                  mdhenriksen @Xclasher 0
                                  Hey there! I’m not 100% what you mean, but you can easily hide modules in MMM-pages. The ones that keep showing up might be in your “exclude” section of MMM-pages in your config.js. Anything in “exclude” will show up on every page you have, so you have to remove the modules from that.
                                  X 1 Reply Last reply Reply Quote 0
                                    I started thinking, "Why am I using page names like Page One, Page Two? Why not “Weather” for a page of weather modules? Or “Sports” for a page of sports modules? You get the idea. I hope. :-)
                                    https://www.youtube.com/watch?v=Zsm_hi7XvM4&feature=youtu.be
                                    • X Offline
                                      Xclasher 0 @mdhenriksen
                                      @mdhenriksen Hi sorry for the late reply. Let me rephrase my question a bit. What I would like to do is just to have MMM-voice (With Lucy) work on one of the pages (From MMM-pages).
                                      I got that to work however, the pages I created from MMM-voice(With Lucy) aren’t working. And when I included the specific modules, it shows up all the time and does not hide. Though it still response with MMM-voice (With Lucy)
                                      So the problem is, how do I hide the specified modules at the start when magic mirror boot up?.
                                        I’m still not sure why you want to use some pages with MMM-pages and others with Hello-Lucy. However, unless there is some conflict with MMM-pages then we can assume you haven’t created your pages correctly in Hello-Lucy. The readme is explicit and should be followed precisely. When you have done it correctly, the only modules displayed at start up will be MMM-voice (and MMM-EasyPix if you are using the face.gif or another image)
                                          Anthony Project Sponsor
                                          I have some problems with Hello Lucy. Firstly sometimes when the MM reloads after Say"Hello, Lucy" I get an ERROR in mic’s icon place. Secondly when I don’t get the ERROR and I say : “MAGIC MIRROR” (my keyword) tha mic icon start flashing (not saying VOICE) but after that anything I say nothing is shown. And i don’t get any errors in pm2 logs or when I start MM with npm start dev . Any suggestions?
                                            Mykle1 Project Sponsor Module Developer @Anthony
                                            @anthony
                                            If you reload MM while MM is running you will get “an ERROR in mic’s icon place.” If you quit MM and relaunch MM you will not get this error.
                                            When the mic starts flashing after saying your keyword “Magic MIrror” then Lucy is expecting a command. Example: Show Weather, Show Clock, Show Page One, etc.
                                            You have to follow the instructions in the README file precisely if you are adding modules of your own. There is a list of modules that works be default in the README, as well. Those will all work without any modification by you. Any pages you create will have to be done as described in the README.
                                            If you have trouble with a particular module I will help you. What commands are you saying to Lucy that do not work?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 14
                                            • 15
                                            • 8 / 15
