    Something is wrong ....
    19 Posts 4 Posters 7.8k Views 3 Watching
    • P Offline
      Peter @Mykle1
      @Mykle1 , thanks.
      I think that is the only way: start with the default modules and the rest one by one until the problem occurs.
      Peter
      cruunnerrC 1 Reply Last reply Reply Quote 1
      • cruunnerrC Offline
        cruunnerr
        Had/Have the same problem. I just copied all modules and the config of my main running RPi 3.
        I set up a RPi 2 with the copied files just for experimental usage. When i run up both at the same time my RPi 3 stops after a few minutes or 1-2 hours and put these errors:
        Tue Jan 16 2018 06:51:13 GMT+0100 (CET) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
        fatal: unable to access 'https://github.com/MichMich/MMM-WatchDog.git/': SSL connection timeout
        fatal: unable to access 'https://github.com/vicmora/MMM-GoogleMapsTraffic.git/': SSL connection timeout
        fatal: unable to access 'https://github.com/mykle1/MMM-EasyPix/': SSL connection timeout
        fatal: unable to access 'https://github.com/Jopyth/MMM-Remote-Control.git/': SSL connection timeout
        fatal: unable to access 'https://github.com/Jopyth/MMM-Buttons.git/': SSL connection timeout
        fatal: unable to access 'https://github.com/paviro/MMM-Wunderlist.git/': SSL connection timeout
        fatal: unable to access 'https://github.com/eouia/MMM-Remote-Control-Repository/': SSL connection timeout
        fatal: unable to access 'https://github.com/jclarke0000/MMM-MyCommute.git/': SSL connection timeout
        fatal: unable to access 'https://github.com/BenRoe/MMM-SystemStats/': SSL connection timeout
        fatal: unable to access 'https://github.com/ptrbld/MMM-Podcast.git/': SSL connection timeout
        fatal: unable to access 'https://github.com/cowboysdude/MMM-NOAA/': SSL connection timeout
        fatal: unable to access 'https://github.com/KirAsh4/calendar_monthly/': SSL connection timeout
        fatal: unable to access 'https://github.com/Tueti/MMM-MovieListings.git/': SSL connection timeout
        fatal: unable to access 'https://github.com/PtrBld/MMM-Scrobbler.git/': SSL connection timeout
        fatal: unable to access 'https://github.com/jclarke0000/MMM-MyCalendar.git/': SSL connection timeout
        fatal: unable to access 'https://github.com/MichMich/MagicMirror/': SSL connection timeout
        fatal: unable to access 'https://github.com/eouia/MMM-Remote-Control-Repository/': Couldn't connect to server
        fatal: unable to access 'https://github.com/ptrbld/MMM-Podcast.git/': Couldn't connect to server
        fatal: unable to access 'https://github.com/KirAsh4/calendar_monthly/': Couldn't connect to server
        fatal: unable to access 'https://github.com/jclarke0000/MMM-MyCalendar.git/': Couldn't connect to server
        fatal: unable to access 'https://github.com/MichMich/MagicMirror/': Couldn't connect to server
        fatal: unable to access 'https://github.com/cowboysdude/MMM-NOAA/': Couldn't connect to server
        fatal: unable to access 'https://github.com/BenRoe/MMM-SystemStats/': Couldn't connect to server
        fatal: unable to access 'https://github.com/Tueti/MMM-MovieListings.git/': Couldn't connect to server
        fatal: unable to access 'https://github.com/paviro/MMM-Wunderlist.git/': Couldn't connect to server
        fatal: unable to access 'https://github.com/mykle1/MMM-EasyPix/': Couldn't connect to server
        fatal: unable to access 'https://github.com/PtrBld/MMM-Scrobbler.git/': Couldn't connect to server
        fatal: unable to access 'https://github.com/jclarke0000/MMM-MyCommute.git/': Couldn't connect to server
        fatal: unable to access 'https://github.com/Jopyth/MMM-Remote-Control.git/': Couldn't connect to server
        Even if i run just the modules without an API the problem comes up. Don’t know why yet
          cruunnerr @Peter
          @Peter
          Lets write here, so the other thread would not be filled up with this problem ;)
          so u don’t know how it starts. That sound like u used the automatic installer and clicked “YES” when it asked u to start automatically.
          Please type in console:
          pm2 status
          U will see a process name (probably “MagicMirror”)
          now u can use
          pm2 start MagicMirror to start MM
          pm2 stop MagicMirror to stop MM
          pm2 restart MagicMirror to restart MM
          or even
          pm2 logs MagicMirror to see logs and errors. Please try if i am right and then post the error log here
          P 1 Reply Last reply Reply Quote 2
          • P Offline
            Peter @cruunnerr
            @cruunnerr after typing pm2 status I see two processes:
            MagicMirror online
            mm. stopped
            after typing pm2 stop MagicMirror both processes are stopped.
            Peter
              cruunnerr
              alright. so u used the automatic installer AND did the “how to autostart”-Tutorial from MichMich, too ^^
              no problem, we will try to fix. As u can read here, ninjabreadman wrote how to remove one of the instances.
              so please try:
              cd
              pm2 stop mm && pm2 delete mm && pm2 save
              rm mm.sh
              now there should just be the “MagicMirror” process even when u reboot.
              Better now, to erase all logs and wait, if your problems come up again. So type:
              pm2 flush
              Next time u got any problems, please type:
              and post it here
              Hope that will help ;)
              • P Offline
                Peter
                Thanks!
                Great help!
                I hope this helps.
                Next time I will post my error logs here.
                peter
                  cruunnerr
                  Lets hope there will be no “next time” ;)
                  • P Offline
                    Peter
                    Unfortunately the problem is not solved.
                    Maybe somebody can have a look at my config.js?
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: "nl",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: 'MMM-WatchDog',
                    			module: 'mmm-systemtemperature',
                    			position: 'top_center',	// This can be any of the regions.
                    			classes: 'xsmall dimmed', // Add your own styling. Optional.
                    			module: 'mmm-wu-moonphase',
                    			header: '',   // optionally you can add a header to this block
                    			position: 'top_center',  // this can be any of the regions.
                    			apikey: 'xxxxxxxxxxxx',
                    			country: 'Nederland',
                    			city: 'Apeldoorn',
                    			apiLang: 'NL',
                    			module: "clock",
                    			position: "top_left"
                    				module: 'calendar_monthly',
                    				position: 'top_left',
                    						// The config property is optional
                    						// Without a config, a default month view is shown
                    						// Please see the 'Configuration Options' section for more information
                    			header: "Feestdagen en agenda",
                    				maximumEntries: '10',
                    				timeFormat: 'absolute',
                    				urgency: 0,
                    				getRelative: 0,
                    				dateFormat: 'D MMM',
                    				fullDayEventDateFormat: 'D MMM',
                    				fadePoint: 0.50, // Start on 1/4th of the list.
                    				symbol: 'calendar-check-o ',
                    				url: 'https://www.mozilla.org/media/caldata/DutchHolidays.ics'
                        				symbol: 'flag-checkered',
                        				url: 'http://localhost:8080/MMM-Formula1/schedule.ics',
                    				symbol: 'university ',
                    				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-5926e1a950f5588d305e66d8b0af0cfa/basic.ics'
                    				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-754f959bc1afb34da4f5ec42e92b1d01/basic.ics'
                    				symbol: 'birthday-cake ',
                    				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-2f98381b817baa8eb5bce7f11ac22120/basic.ics'
                    			module: "MMM-MovieListings",
                    			position: "bottom_left",
                      				// Default module config.
                    				defaults: {
                        				apiKey: 'xxxxxxxxxxxxxxxxxxxxxxxx',
                    				region: 'NL',
                        				language: 'en-EN',
                        				interface: 'poster', //'list', 'poster', 'detailed'
                        				includeMoviePlot: false,
                        				maxPlotLength: 198,
                        				header: 'Nu in de bioscoop',
                        				moviesPerPage: 0,
                        				refreshInterval: 1000 * 60 * 60 * 24, //Once a day
                        				baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
                        				animationSpeed: 2.5 * 1000,
                        				pageChangeInterval: 30 * 1000
                        			disabled: false,
                        			module: 'MMM-NOAA',
                        			position: 'top_right',
                    			apiKey: "xxxxxxxxxxxxxxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
                    			useAir: true,             // set to false if you do not want to use Air Quality Index
                    			airKey: "xxxxxxxxxxxxxx",    // IF you want Air Quality Index
                    			pws: "xxxxxxxxxx",         // go here to find your pws: https://www.wunderground.com/wundermap
                    			showClock: false,           // Hides or shows clock
                    			dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
                    			format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
                    			ampm: false,                // to show AM and PM on Sunrise/Sunset time
                    			showGreet: true,          // deafult is false - to show greeting under clock and above date
                    			name: "xxxxxxxx",                  // Your name
                    			showWind: true,
                    			showDate: false,
                    			showForecast: true,         //show bottom 3 day forecast
                    			flash: true,                 //Today in forecast flashes halo
                    			showUV: true,               //show UV index
                            		showBar: true,             // show Barometer
                            		showHum: true,              //show Humidity level
                    			position: 'top_right',       //whatever you have in above position must also be here
                            		alert: true                //show weather alerts default is true
                            		module: 'MMM-Formula1',
                            		header: 'Formule 1 Classificatie',
                    			maxRows: 6,
                    			season: 'current',
                            		calendar: true,
                            		fade: false,
                            		fadePoint: 0.2,
                    			grayscale: false,
                                		// Optional configuration options - see https://github.com/ianperrin/MMM-Formula1#configuration-options
                    			module: "MMM-ImagesPhotos",
                    			position: "bottom_right",
                    			header: "Onze reizen door xxxxxxxxxxxxxx .................",
                    			opacity: 1,
                    			animationSpeed: 5000,
                    			updateInterval: 50000,
                    			maxWidth: "100%",
                    			maxHeight: "100%",
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "Algemeen Dagblad",
                    						url: "http://www.ad.nl/home/rss.xml"
                    						title: "Telegraaf",
                    						url: "http://www.telegraaf.nl/rss/"
                    						title: "Trouw",
                    						url: "https://www.trouw.nl/home/rss.xml"
                    						title: "Volkskrant",
                    						url: "https://www.volkskrant.nl/nieuws-voorpagina/rss.xml"
                    						title: "Nu.nl",
                    						url: "http://www.nu.nl/rss/Algemeen"
                    				showSourceTitle: true,
                    				showPublishDate: true
                    Thanks!
                    Peter
                      cruunnerr
                      Thats not what u promised ;)
                      You wanted to show your logs.
                      Your config is ok. Maybe its one of your modules. U have to try out by disabling them step by step or maybe in blocks.
                      Or try to run just default modules.
                      But first post your logs. i have been asking for it since the last 3 posts :D
                      • P Offline
                        Peter @cruunnerr
                        @cruunnerr , shame on me, you are right!
                        This is my error log:
                        /home/pi/.pm2/logs/MagicMirror-error-0.log last 15 lines:
                        0|MagicMir | npm ERR!
                        0|MagicMir | npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
                        0|MagicMir | npm ERR! Make sure you have the latest version of node.js and npm installed.
                        0|MagicMir | npm ERR! If you do, this is most likely a problem with the magicmirror package,
                        0|MagicMir | npm ERR! not with npm itself.
                        0|MagicMir | npm ERR! Tell the author that this fails on your system:
                        0|MagicMir | npm ERR!     sh run-start.sh
                        0|MagicMir | npm ERR! You can get information on how to open an issue for this project with:
                        0|MagicMir | npm ERR!     npm bugs magicmirror
                        0|MagicMir | npm ERR! Or if that isn't available, you can get their info via:
                        0|MagicMir | npm ERR!     npm owner ls magicmirror
                        0|MagicMir | npm ERR! There is likely additional logging output above.
                        0|MagicMir |
                        0|MagicMir | npm ERR! Please include the following file with any support request:
                        0|MagicMir | npm ERR!     /home/pi/MagicMirror/npm-debug.log
                        Peter
