    Something is wrong ....
    19 Posts 4 Posters 8.1k Views 3 Watching
      Peter @retroflex
      @retroflex , I can reach my mirror after freezing with VNC.
      But the Jessie GUI is also frozen; time has stopped …
      So maybe the problem is Jessie?
      I use normal Jessie, not lite.
      Peter
        Mykle1 Project Sponsor Module Developer @Peter
        @Peter said in Something is wrong ....:
        I doubt very much that the problem is Jessie. It’s the most stable OS for MM that I’ve found, aside from ubuntu. If there was a problem with the installation of Jessie then that would be another matter completely.
        Have you tried running just the default modules to see if the problem still occurs?
          Peter @Mykle1
          @Mykle1 , thanks.
          I think that is the only way: start with the default modules and the rest one by one until the problem occurs.
          Peter
          cruunnerrC 1 Reply Last reply Reply Quote 1
          • cruunnerrC Offline
            cruunnerr
            Had/Have the same problem. I just copied all modules and the config of my main running RPi 3.
            I set up a RPi 2 with the copied files just for experimental usage. When i run up both at the same time my RPi 3 stops after a few minutes or 1-2 hours and put these errors:
            Tue Jan 16 2018 06:51:13 GMT+0100 (CET) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
            fatal: unable to access 'https://github.com/MichMich/MMM-WatchDog.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/vicmora/MMM-GoogleMapsTraffic.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/mykle1/MMM-EasyPix/': SSL connection timeout
            fatal: unable to access 'https://github.com/Jopyth/MMM-Remote-Control.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/Jopyth/MMM-Buttons.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/paviro/MMM-Wunderlist.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/eouia/MMM-Remote-Control-Repository/': SSL connection timeout
            fatal: unable to access 'https://github.com/jclarke0000/MMM-MyCommute.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/BenRoe/MMM-SystemStats/': SSL connection timeout
            fatal: unable to access 'https://github.com/ptrbld/MMM-Podcast.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/cowboysdude/MMM-NOAA/': SSL connection timeout
            fatal: unable to access 'https://github.com/KirAsh4/calendar_monthly/': SSL connection timeout
            fatal: unable to access 'https://github.com/Tueti/MMM-MovieListings.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/PtrBld/MMM-Scrobbler.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/jclarke0000/MMM-MyCalendar.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/MichMich/MagicMirror/': SSL connection timeout
            fatal: unable to access 'https://github.com/eouia/MMM-Remote-Control-Repository/': Couldn't connect to server
            fatal: unable to access 'https://github.com/ptrbld/MMM-Podcast.git/': Couldn't connect to server
            fatal: unable to access 'https://github.com/KirAsh4/calendar_monthly/': Couldn't connect to server
            fatal: unable to access 'https://github.com/jclarke0000/MMM-MyCalendar.git/': Couldn't connect to server
            fatal: unable to access 'https://github.com/MichMich/MagicMirror/': Couldn't connect to server
            fatal: unable to access 'https://github.com/cowboysdude/MMM-NOAA/': Couldn't connect to server
            fatal: unable to access 'https://github.com/BenRoe/MMM-SystemStats/': Couldn't connect to server
            fatal: unable to access 'https://github.com/Tueti/MMM-MovieListings.git/': Couldn't connect to server
            fatal: unable to access 'https://github.com/paviro/MMM-Wunderlist.git/': Couldn't connect to server
            fatal: unable to access 'https://github.com/mykle1/MMM-EasyPix/': Couldn't connect to server
            fatal: unable to access 'https://github.com/PtrBld/MMM-Scrobbler.git/': Couldn't connect to server
            fatal: unable to access 'https://github.com/jclarke0000/MMM-MyCommute.git/': Couldn't connect to server
            fatal: unable to access 'https://github.com/Jopyth/MMM-Remote-Control.git/': Couldn't connect to server
            Even if i run just the modules without an API the problem comes up. Don’t know why yet
              cruunnerr @Peter
              @Peter
              Lets write here, so the other thread would not be filled up with this problem ;)
              so u don’t know how it starts. That sound like u used the automatic installer and clicked “YES” when it asked u to start automatically.
              Please type in console:
              pm2 status
              U will see a process name (probably “MagicMirror”)
              now u can use
              pm2 start MagicMirror to start MM
              pm2 stop MagicMirror to stop MM
              pm2 restart MagicMirror to restart MM
              or even
              pm2 logs MagicMirror to see logs and errors. Please try if i am right and then post the error log here
              P 1 Reply Last reply Reply Quote 2
                Peter @cruunnerr
                @cruunnerr after typing pm2 status I see two processes:
                MagicMirror online
                mm. stopped
                after typing pm2 stop MagicMirror both processes are stopped.
                Peter
                  cruunnerr
                  alright. so u used the automatic installer AND did the “how to autostart”-Tutorial from MichMich, too ^^
                  no problem, we will try to fix. As u can read here, ninjabreadman wrote how to remove one of the instances.
                  so please try:
                  cd
                  pm2 stop mm && pm2 delete mm && pm2 save
                  rm mm.sh
                  now there should just be the “MagicMirror” process even when u reboot.
                  Better now, to erase all logs and wait, if your problems come up again. So type:
                  pm2 flush
                  Next time u got any problems, please type:
                  and post it here
                  Hope that will help ;)
                    Peter
                    Thanks!
                    Great help!
                    I hope this helps.
                    Next time I will post my error logs here.
                    peter
                      cruunnerr
                      Lets hope there will be no “next time” ;)
                        Peter
                        Unfortunately the problem is not solved.
                        Maybe somebody can have a look at my config.js?
                        /* Magic Mirror Config Sample
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	language: "nl",
                        	timeFormat: 24,
                        	units: "metric",
                        			module: 'MMM-WatchDog',
                        			module: 'mmm-systemtemperature',
                        			position: 'top_center',	// This can be any of the regions.
                        			classes: 'xsmall dimmed', // Add your own styling. Optional.
                        			module: 'mmm-wu-moonphase',
                        			header: '',   // optionally you can add a header to this block
                        			position: 'top_center',  // this can be any of the regions.
                        			apikey: 'xxxxxxxxxxxx',
                        			country: 'Nederland',
                        			city: 'Apeldoorn',
                        			apiLang: 'NL',
                        			module: "clock",
                        			position: "top_left"
                        				module: 'calendar_monthly',
                        				position: 'top_left',
                        						// The config property is optional
                        						// Without a config, a default month view is shown
                        						// Please see the 'Configuration Options' section for more information
                        			header: "Feestdagen en agenda",
                        				maximumEntries: '10',
                        				timeFormat: 'absolute',
                        				urgency: 0,
                        				getRelative: 0,
                        				dateFormat: 'D MMM',
                        				fullDayEventDateFormat: 'D MMM',
                        				fadePoint: 0.50, // Start on 1/4th of the list.
                        				symbol: 'calendar-check-o ',
                        				url: 'https://www.mozilla.org/media/caldata/DutchHolidays.ics'
                            				symbol: 'flag-checkered',
                            				url: 'http://localhost:8080/MMM-Formula1/schedule.ics',
                        				symbol: 'university ',
                        				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-5926e1a950f5588d305e66d8b0af0cfa/basic.ics'
                        				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-754f959bc1afb34da4f5ec42e92b1d01/basic.ics'
                        				symbol: 'birthday-cake ',
                        				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-2f98381b817baa8eb5bce7f11ac22120/basic.ics'
                        			module: "MMM-MovieListings",
                        			position: "bottom_left",
                          				// Default module config.
                        				defaults: {
                            				apiKey: 'xxxxxxxxxxxxxxxxxxxxxxxx',
                        				region: 'NL',
                            				language: 'en-EN',
                            				interface: 'poster', //'list', 'poster', 'detailed'
                            				includeMoviePlot: false,
                            				maxPlotLength: 198,
                            				header: 'Nu in de bioscoop',
                            				moviesPerPage: 0,
                            				refreshInterval: 1000 * 60 * 60 * 24, //Once a day
                            				baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
                            				animationSpeed: 2.5 * 1000,
                            				pageChangeInterval: 30 * 1000
                            			disabled: false,
                            			module: 'MMM-NOAA',
                            			position: 'top_right',
                        			apiKey: "xxxxxxxxxxxxxxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
                        			useAir: true,             // set to false if you do not want to use Air Quality Index
                        			airKey: "xxxxxxxxxxxxxx",    // IF you want Air Quality Index
                        			pws: "xxxxxxxxxx",         // go here to find your pws: https://www.wunderground.com/wundermap
                        			showClock: false,           // Hides or shows clock
                        			dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
                        			format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
                        			ampm: false,                // to show AM and PM on Sunrise/Sunset time
                        			showGreet: true,          // deafult is false - to show greeting under clock and above date
                        			name: "xxxxxxxx",                  // Your name
                        			showWind: true,
                        			showDate: false,
                        			showForecast: true,         //show bottom 3 day forecast
                        			flash: true,                 //Today in forecast flashes halo
                        			showUV: true,               //show UV index
                                		showBar: true,             // show Barometer
                                		showHum: true,              //show Humidity level
                        			position: 'top_right',       //whatever you have in above position must also be here
                                		alert: true                //show weather alerts default is true
                                		module: 'MMM-Formula1',
                                		header: 'Formule 1 Classificatie',
                        			maxRows: 6,
                        			season: 'current',
                                		calendar: true,
                                		fade: false,
                                		fadePoint: 0.2,
                        			grayscale: false,
                                    		// Optional configuration options - see https://github.com/ianperrin/MMM-Formula1#configuration-options
                        			module: "MMM-ImagesPhotos",
                        			position: "bottom_right",
                        			header: "Onze reizen door xxxxxxxxxxxxxx .................",
                        			opacity: 1,
                        			animationSpeed: 5000,
                        			updateInterval: 50000,
                        			maxWidth: "100%",
                        			maxHeight: "100%",
                        			module: "newsfeed",
                        			position: "bottom_bar",
                        				feeds: [
                        						title: "Algemeen Dagblad",
                        						url: "http://www.ad.nl/home/rss.xml"
                        						title: "Telegraaf",
                        						url: "http://www.telegraaf.nl/rss/"
                        						title: "Trouw",
                        						url: "https://www.trouw.nl/home/rss.xml"
                        						title: "Volkskrant",
                        						url: "https://www.volkskrant.nl/nieuws-voorpagina/rss.xml"
                        						title: "Nu.nl",
                        						url: "http://www.nu.nl/rss/Algemeen"
                        				showSourceTitle: true,
                        				showPublishDate: true
                        Thanks!
                        Peter
                          cruunnerr
                          Thats not what u promised ;)
                          You wanted to show your logs.
                          Your config is ok. Maybe its one of your modules. U have to try out by disabling them step by step or maybe in blocks.
                          Or try to run just default modules.
                          But first post your logs. i have been asking for it since the last 3 posts :D
                            Peter @cruunnerr
                            @cruunnerr , shame on me, you are right!
                            This is my error log:
                            /home/pi/.pm2/logs/MagicMirror-error-0.log last 15 lines:
                            0|MagicMir | npm ERR!
                            0|MagicMir | npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
                            0|MagicMir | npm ERR! Make sure you have the latest version of node.js and npm installed.
                            0|MagicMir | npm ERR! If you do, this is most likely a problem with the magicmirror package,
                            0|MagicMir | npm ERR! not with npm itself.
                            0|MagicMir | npm ERR! Tell the author that this fails on your system:
                            0|MagicMir | npm ERR!     sh run-start.sh
                            0|MagicMir | npm ERR! You can get information on how to open an issue for this project with:
                            0|MagicMir | npm ERR!     npm bugs magicmirror
                            0|MagicMir | npm ERR! Or if that isn't available, you can get their info via:
                            0|MagicMir | npm ERR!     npm owner ls magicmirror
                            0|MagicMir | npm ERR! There is likely additional logging output above.
                            0|MagicMir |
                            0|MagicMir | npm ERR! Please include the following file with any support request:
                            0|MagicMir | npm ERR!     /home/pi/MagicMirror/npm-debug.log
                            Peter
                              cruunnerr
                              no need to shame ;)
                              i have had this problem, too.
                              Since i played around with new modules and deleted other modules it doesn’t comes up again.
                              we discussed that issue already here
                              I can’t help u, but maybe it really helps if you would uncomment modules step by step (maybe two at the same time) and wait if the error comes up again.
                              I know, that will take a while, but for me it would be the choice how to solve it.
                              I have no other idea, i am sorry :(
                                Peter @cruunnerr
                                @cruunnerr OK, I will follow your advice.
                                And what to do when I find the module that is causing the ploblem?
                                Delete it and install it again?
                                I love all the modules that I use now, so it would be bad not to have them.
                                Peter
                                  Create a new topic asking for help with that specific module that is causing problems. If the issue can be resolved then someone will help you. Or, tragically, if the issue can not be resolved, you may have to live without it. :-)
                                    Peter
                                    Maybe I found the problem; I think ImagePhotos caused the problem, but not the module but the pictures I used.
                                    I had 70 high resolution holiday pictures roulating in the module and every now and then a picture had problems to load.
                                    Some pictures were over 6mb.
                                    I reseized a lot of pictures and am running over 2000 pictures now without problems (every picture is about 100kb).
                                    Pictures are loading much smoother now.
                                    Maybe this helps other people too!
                                    Peter
                                      cruunnerr
                                      I am glad u found out what causes your problem :D
                                      Yeah, the RPi is very limited in processor power. That is the reason, why some users went over to old laptops or small x86 solutions :)
