    Something is wrong ....
    19 Posts 4 Posters 8.0k Views 3 Watching
      Peter @retroflex
      @retroflex , I can reach my mirror after freezing with VNC.
      But the Jessie GUI is also frozen; time has stopped …
      So maybe the problem is Jessie?
      I use normal Jessie, not lite.
      Peter
        Mykle1 Project Sponsor Module Developer @Peter
        @Peter said in Something is wrong ....:
        I doubt very much that the problem is Jessie. It’s the most stable OS for MM that I’ve found, aside from ubuntu. If there was a problem with the installation of Jessie then that would be another matter completely.
        Have you tried running just the default modules to see if the problem still occurs?
          Peter @Mykle1
          @Mykle1 , thanks.
          I think that is the only way: start with the default modules and the rest one by one until the problem occurs.
          Peter
          cruunnerrC 1 Reply Last reply Reply Quote 1
          • cruunnerrC Offline
            cruunnerr
            Had/Have the same problem. I just copied all modules and the config of my main running RPi 3.
            I set up a RPi 2 with the copied files just for experimental usage. When i run up both at the same time my RPi 3 stops after a few minutes or 1-2 hours and put these errors:
            Tue Jan 16 2018 06:51:13 GMT+0100 (CET) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
            fatal: unable to access 'https://github.com/MichMich/MMM-WatchDog.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/vicmora/MMM-GoogleMapsTraffic.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/mykle1/MMM-EasyPix/': SSL connection timeout
            fatal: unable to access 'https://github.com/Jopyth/MMM-Remote-Control.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/Jopyth/MMM-Buttons.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/paviro/MMM-Wunderlist.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/eouia/MMM-Remote-Control-Repository/': SSL connection timeout
            fatal: unable to access 'https://github.com/jclarke0000/MMM-MyCommute.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/BenRoe/MMM-SystemStats/': SSL connection timeout
            fatal: unable to access 'https://github.com/ptrbld/MMM-Podcast.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/cowboysdude/MMM-NOAA/': SSL connection timeout
            fatal: unable to access 'https://github.com/KirAsh4/calendar_monthly/': SSL connection timeout
            fatal: unable to access 'https://github.com/Tueti/MMM-MovieListings.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/PtrBld/MMM-Scrobbler.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/jclarke0000/MMM-MyCalendar.git/': SSL connection timeout
            fatal: unable to access 'https://github.com/MichMich/MagicMirror/': SSL connection timeout
            fatal: unable to access 'https://github.com/eouia/MMM-Remote-Control-Repository/': Couldn't connect to server
            fatal: unable to access 'https://github.com/ptrbld/MMM-Podcast.git/': Couldn't connect to server
            fatal: unable to access 'https://github.com/KirAsh4/calendar_monthly/': Couldn't connect to server
            fatal: unable to access 'https://github.com/jclarke0000/MMM-MyCalendar.git/': Couldn't connect to server
            fatal: unable to access 'https://github.com/MichMich/MagicMirror/': Couldn't connect to server
            fatal: unable to access 'https://github.com/cowboysdude/MMM-NOAA/': Couldn't connect to server
            fatal: unable to access 'https://github.com/BenRoe/MMM-SystemStats/': Couldn't connect to server
            fatal: unable to access 'https://github.com/Tueti/MMM-MovieListings.git/': Couldn't connect to server
            fatal: unable to access 'https://github.com/paviro/MMM-Wunderlist.git/': Couldn't connect to server
            fatal: unable to access 'https://github.com/mykle1/MMM-EasyPix/': Couldn't connect to server
            fatal: unable to access 'https://github.com/PtrBld/MMM-Scrobbler.git/': Couldn't connect to server
            fatal: unable to access 'https://github.com/jclarke0000/MMM-MyCommute.git/': Couldn't connect to server
            fatal: unable to access 'https://github.com/Jopyth/MMM-Remote-Control.git/': Couldn't connect to server
            Even if i run just the modules without an API the problem comes up. Don’t know why yet
              cruunnerr @Peter
              @Peter
              Lets write here, so the other thread would not be filled up with this problem ;)
              so u don’t know how it starts. That sound like u used the automatic installer and clicked “YES” when it asked u to start automatically.
              Please type in console:
              pm2 status
              U will see a process name (probably “MagicMirror”)
              now u can use
              pm2 start MagicMirror to start MM
              pm2 stop MagicMirror to stop MM
              pm2 restart MagicMirror to restart MM
              or even
              pm2 logs MagicMirror to see logs and errors. Please try if i am right and then post the error log here
              P 1 Reply Last reply Reply Quote 2
                Peter @cruunnerr
                @cruunnerr after typing pm2 status I see two processes:
                MagicMirror online
                mm. stopped
                after typing pm2 stop MagicMirror both processes are stopped.
                Peter
                  cruunnerr
                  alright. so u used the automatic installer AND did the “how to autostart”-Tutorial from MichMich, too ^^
                  no problem, we will try to fix. As u can read here, ninjabreadman wrote how to remove one of the instances.
                  so please try:
                  cd
                  pm2 stop mm && pm2 delete mm && pm2 save
                  rm mm.sh
                  now there should just be the “MagicMirror” process even when u reboot.
                  Better now, to erase all logs and wait, if your problems come up again. So type:
                  pm2 flush
                  Next time u got any problems, please type:
                  and post it here
                  Hope that will help ;)
                    Peter
                    Thanks!
                    Great help!
                    I hope this helps.
                    Next time I will post my error logs here.
                    peter
                      cruunnerr
                      Lets hope there will be no “next time” ;)
                        Peter
                        Unfortunately the problem is not solved.
                        Maybe somebody can have a look at my config.js?
                        /* Magic Mirror Config Sample
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	language: "nl",
                        	timeFormat: 24,
                        	units: "metric",
                        			module: 'MMM-WatchDog',
                        			module: 'mmm-systemtemperature',
                        			position: 'top_center',	// This can be any of the regions.
                        			classes: 'xsmall dimmed', // Add your own styling. Optional.
                        			module: 'mmm-wu-moonphase',
                        			header: '',   // optionally you can add a header to this block
                        			position: 'top_center',  // this can be any of the regions.
                        			apikey: 'xxxxxxxxxxxx',
                        			country: 'Nederland',
                        			city: 'Apeldoorn',
                        			apiLang: 'NL',
                        			module: "clock",
                        			position: "top_left"
                        				module: 'calendar_monthly',
                        				position: 'top_left',
                        						// The config property is optional
                        						// Without a config, a default month view is shown
                        						// Please see the 'Configuration Options' section for more information
                        			header: "Feestdagen en agenda",
                        				maximumEntries: '10',
                        				timeFormat: 'absolute',
                        				urgency: 0,
                        				getRelative: 0,
                        				dateFormat: 'D MMM',
                        				fullDayEventDateFormat: 'D MMM',
                        				fadePoint: 0.50, // Start on 1/4th of the list.
                        				symbol: 'calendar-check-o ',
                        				url: 'https://www.mozilla.org/media/caldata/DutchHolidays.ics'
                            				symbol: 'flag-checkered',
                            				url: 'http://localhost:8080/MMM-Formula1/schedule.ics',
                        				symbol: 'university ',
                        				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-5926e1a950f5588d305e66d8b0af0cfa/basic.ics'
                        				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-754f959bc1afb34da4f5ec42e92b1d01/basic.ics'
                        				symbol: 'birthday-cake ',
                        				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-2f98381b817baa8eb5bce7f11ac22120/basic.ics'
                        			module: "MMM-MovieListings",
                        			position: "bottom_left",
                          				// Default module config.
                        				defaults: {
                            				apiKey: 'xxxxxxxxxxxxxxxxxxxxxxxx',
                        				region: 'NL',
                            				language: 'en-EN',
                            				interface: 'poster', //'list', 'poster', 'detailed'
                            				includeMoviePlot: false,
                            				maxPlotLength: 198,
                            				header: 'Nu in de bioscoop',
                            				moviesPerPage: 0,
                            				refreshInterval: 1000 * 60 * 60 * 24, //Once a day
                            				baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
                            				animationSpeed: 2.5 * 1000,
                            				pageChangeInterval: 30 * 1000
                            			disabled: false,
                            			module: 'MMM-NOAA',
                            			position: 'top_right',
                        			apiKey: "xxxxxxxxxxxxxxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
                        			useAir: true,             // set to false if you do not want to use Air Quality Index
                        			airKey: "xxxxxxxxxxxxxx",    // IF you want Air Quality Index
                        			pws: "xxxxxxxxxx",         // go here to find your pws: https://www.wunderground.com/wundermap
                        			showClock: false,           // Hides or shows clock
                        			dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
                        			format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
                        			ampm: false,                // to show AM and PM on Sunrise/Sunset time
                        			showGreet: true,          // deafult is false - to show greeting under clock and above date
                        			name: "xxxxxxxx",                  // Your name
                        			showWind: true,
                        			showDate: false,
                        			showForecast: true,         //show bottom 3 day forecast
                        			flash: true,                 //Today in forecast flashes halo
                        			showUV: true,               //show UV index
                                		showBar: true,             // show Barometer
                                		showHum: true,              //show Humidity level
                        			position: 'top_right',       //whatever you have in above position must also be here
                                		alert: true                //show weather alerts default is true
                                		module: 'MMM-Formula1',
                                		header: 'Formule 1 Classificatie',
                        			maxRows: 6,
                        			season: 'current',
                                		calendar: true,
                                		fade: false,
                                		fadePoint: 0.2,
                        			grayscale: false,
                                    		// Optional configuration options - see https://github.com/ianperrin/MMM-Formula1#configuration-options
                        			module: "MMM-ImagesPhotos",
                        			position: "bottom_right",
                        			header: "Onze reizen door xxxxxxxxxxxxxx .................",
                        			opacity: 1,
                        			animationSpeed: 5000,
                        			updateInterval: 50000,
                        			maxWidth: "100%",
                        			maxHeight: "100%",
                        			module: "newsfeed",
                        			position: "bottom_bar",
                        				feeds: [
                        						title: "Algemeen Dagblad",
                        						url: "http://www.ad.nl/home/rss.xml"
                        						title: "Telegraaf",
                        						url: "http://www.telegraaf.nl/rss/"
                        						title: "Trouw",
                        						url: "https://www.trouw.nl/home/rss.xml"
                        						title: "Volkskrant",
                        						url: "https://www.volkskrant.nl/nieuws-voorpagina/rss.xml"
                        						title: "Nu.nl",
                        						url: "http://www.nu.nl/rss/Algemeen"
                        				showSourceTitle: true,
                        				showPublishDate: true
                        Thanks!
                        Peter
