    Something is wrong ....
    19 Posts 4 Posters 9.1k Views 3 Watching
      Peter
      Thanks!
      Great help!
      I hope this helps.
      Next time I will post my error logs here.
      peter
      • cruunnerrC
        cruunnerr
        Lets hope there will be no “next time” ;)
          Peter
          Unfortunately the problem is not solved.
          Maybe somebody can have a look at my config.js?
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "nl",
          	timeFormat: 24,
          	units: "metric",
          			module: 'MMM-WatchDog',
          			module: 'mmm-systemtemperature',
          			position: 'top_center',	// This can be any of the regions.
          			classes: 'xsmall dimmed', // Add your own styling. Optional.
          			module: 'mmm-wu-moonphase',
          			header: '',   // optionally you can add a header to this block
          			position: 'top_center',  // this can be any of the regions.
          			apikey: 'xxxxxxxxxxxx',
          			country: 'Nederland',
          			city: 'Apeldoorn',
          			apiLang: 'NL',
          			module: "clock",
          			position: "top_left"
          				module: 'calendar_monthly',
          				position: 'top_left',
          						// The config property is optional
          						// Without a config, a default month view is shown
          						// Please see the 'Configuration Options' section for more information
          			header: "Feestdagen en agenda",
          				maximumEntries: '10',
          				timeFormat: 'absolute',
          				urgency: 0,
          				getRelative: 0,
          				dateFormat: 'D MMM',
          				fullDayEventDateFormat: 'D MMM',
          				fadePoint: 0.50, // Start on 1/4th of the list.
          				symbol: 'calendar-check-o ',
          				url: 'https://www.mozilla.org/media/caldata/DutchHolidays.ics'
              				symbol: 'flag-checkered',
              				url: 'http://localhost:8080/MMM-Formula1/schedule.ics',
          				symbol: 'university ',
          				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-5926e1a950f5588d305e66d8b0af0cfa/basic.ics'
          				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-754f959bc1afb34da4f5ec42e92b1d01/basic.ics'
          				symbol: 'birthday-cake ',
          				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-2f98381b817baa8eb5bce7f11ac22120/basic.ics'
          			module: "MMM-MovieListings",
          			position: "bottom_left",
            				// Default module config.
          				defaults: {
              				apiKey: 'xxxxxxxxxxxxxxxxxxxxxxxx',
          				region: 'NL',
              				language: 'en-EN',
              				interface: 'poster', //'list', 'poster', 'detailed'
              				includeMoviePlot: false,
              				maxPlotLength: 198,
              				header: 'Nu in de bioscoop',
              				moviesPerPage: 0,
              				refreshInterval: 1000 * 60 * 60 * 24, //Once a day
              				baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
              				animationSpeed: 2.5 * 1000,
              				pageChangeInterval: 30 * 1000
              			disabled: false,
              			module: 'MMM-NOAA',
              			position: 'top_right',
          			apiKey: "xxxxxxxxxxxxxxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
          			useAir: true,             // set to false if you do not want to use Air Quality Index
          			airKey: "xxxxxxxxxxxxxx",    // IF you want Air Quality Index
          			pws: "xxxxxxxxxx",         // go here to find your pws: https://www.wunderground.com/wundermap
          			showClock: false,           // Hides or shows clock
          			dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
          			format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
          			ampm: false,                // to show AM and PM on Sunrise/Sunset time
          			showGreet: true,          // deafult is false - to show greeting under clock and above date
          			name: "xxxxxxxx",                  // Your name
          			showWind: true,
          			showDate: false,
          			showForecast: true,         //show bottom 3 day forecast
          			flash: true,                 //Today in forecast flashes halo
          			showUV: true,               //show UV index
                  		showBar: true,             // show Barometer
                  		showHum: true,              //show Humidity level
          			position: 'top_right',       //whatever you have in above position must also be here
                  		alert: true                //show weather alerts default is true
                  		module: 'MMM-Formula1',
                  		header: 'Formule 1 Classificatie',
          			maxRows: 6,
          			season: 'current',
                  		calendar: true,
                  		fade: false,
                  		fadePoint: 0.2,
          			grayscale: false,
                      		// Optional configuration options - see https://github.com/ianperrin/MMM-Formula1#configuration-options
          			module: "MMM-ImagesPhotos",
          			position: "bottom_right",
          			header: "Onze reizen door xxxxxxxxxxxxxx .................",
          			opacity: 1,
          			animationSpeed: 5000,
          			updateInterval: 50000,
          			maxWidth: "100%",
          			maxHeight: "100%",
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "Algemeen Dagblad",
          						url: "http://www.ad.nl/home/rss.xml"
          						title: "Telegraaf",
          						url: "http://www.telegraaf.nl/rss/"
          						title: "Trouw",
          						url: "https://www.trouw.nl/home/rss.xml"
          						title: "Volkskrant",
          						url: "https://www.volkskrant.nl/nieuws-voorpagina/rss.xml"
          						title: "Nu.nl",
          						url: "http://www.nu.nl/rss/Algemeen"
          				showSourceTitle: true,
          				showPublishDate: true
          Thanks!
          Peter
          • cruunnerrC
            cruunnerr
            Thats not what u promised ;)
            You wanted to show your logs.
            Your config is ok. Maybe its one of your modules. U have to try out by disabling them step by step or maybe in blocks.
            Or try to run just default modules.
            But first post your logs. i have been asking for it since the last 3 posts :D
            P 1 Reply Last reply
              Peter @cruunnerr
              @cruunnerr , shame on me, you are right!
              This is my error log:
              /home/pi/.pm2/logs/MagicMirror-error-0.log last 15 lines:
              0|MagicMir | npm ERR!
              0|MagicMir | npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
              0|MagicMir | npm ERR! Make sure you have the latest version of node.js and npm installed.
              0|MagicMir | npm ERR! If you do, this is most likely a problem with the magicmirror package,
              0|MagicMir | npm ERR! not with npm itself.
              0|MagicMir | npm ERR! Tell the author that this fails on your system:
              0|MagicMir | npm ERR!     sh run-start.sh
              0|MagicMir | npm ERR! You can get information on how to open an issue for this project with:
              0|MagicMir | npm ERR!     npm bugs magicmirror
              0|MagicMir | npm ERR! Or if that isn't available, you can get their info via:
              0|MagicMir | npm ERR!     npm owner ls magicmirror
              0|MagicMir | npm ERR! There is likely additional logging output above.
              0|MagicMir |
              0|MagicMir | npm ERR! Please include the following file with any support request:
              0|MagicMir | npm ERR!     /home/pi/MagicMirror/npm-debug.log
              Peter
              • cruunnerrC
                cruunnerr
                no need to shame ;)
                i have had this problem, too.
                Since i played around with new modules and deleted other modules it doesn’t comes up again.
                we discussed that issue already here
                I can’t help u, but maybe it really helps if you would uncomment modules step by step (maybe two at the same time) and wait if the error comes up again.
                I know, that will take a while, but for me it would be the choice how to solve it.
                I have no other idea, i am sorry :(
                  Peter @cruunnerr
                  @cruunnerr OK, I will follow your advice.
                  And what to do when I find the module that is causing the ploblem?
                  Delete it and install it again?
                  I love all the modules that I use now, so it would be bad not to have them.
                  Peter
                  Mykle1M 1 Reply Last reply
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @Peter
                    @Peter said in Something is wrong ....:
                    Create a new topic asking for help with that specific module that is causing problems. If the issue can be resolved then someone will help you. Or, tragically, if the issue can not be resolved, you may have to live without it. :-)
                      Peter
                      Maybe I found the problem; I think ImagePhotos caused the problem, but not the module but the pictures I used.
                      I had 70 high resolution holiday pictures roulating in the module and every now and then a picture had problems to load.
                      Some pictures were over 6mb.
                      I reseized a lot of pictures and am running over 2000 pictures now without problems (every picture is about 100kb).
                      Pictures are loading much smoother now.
                      Maybe this helps other people too!
                      Peter
                      • cruunnerrC
                        cruunnerr
                        I am glad u found out what causes your problem :D
                        Yeah, the RPi is very limited in processor power. That is the reason, why some users went over to old laptops or small x86 solutions :)
