    Something is wrong ....
    19 Posts 4 Posters 9.1k Views 3 Watching
      Peter @cruunnerr
      @cruunnerr after typing pm2 status I see two processes:
      MagicMirror online
      mm. stopped
      after typing pm2 stop MagicMirror both processes are stopped.
      Peter
      • cruunnerrC
        cruunnerr
        alright. so u used the automatic installer AND did the “how to autostart”-Tutorial from MichMich, too ^^
        no problem, we will try to fix. As u can read here, ninjabreadman wrote how to remove one of the instances.
        so please try:
        cd
        pm2 stop mm && pm2 delete mm && pm2 save
        rm mm.sh
        now there should just be the “MagicMirror” process even when u reboot.
        Better now, to erase all logs and wait, if your problems come up again. So type:
        pm2 flush
        Next time u got any problems, please type:
        pm2 logs MagicMirror
        and post it here
        Hope that will help ;)
          Peter
          Thanks!
          Great help!
          I hope this helps.
          Next time I will post my error logs here.
          peter
          • cruunnerrC
            cruunnerr
            Lets hope there will be no “next time” ;)
              Peter
              Unfortunately the problem is not solved.
              Maybe somebody can have a look at my config.js?
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	port: 8080,
              	language: "nl",
              	timeFormat: 24,
              	units: "metric",
              			module: 'MMM-WatchDog',
              			module: 'mmm-systemtemperature',
              			position: 'top_center',	// This can be any of the regions.
              			classes: 'xsmall dimmed', // Add your own styling. Optional.
              			module: 'mmm-wu-moonphase',
              			header: '',   // optionally you can add a header to this block
              			position: 'top_center',  // this can be any of the regions.
              			apikey: 'xxxxxxxxxxxx',
              			country: 'Nederland',
              			city: 'Apeldoorn',
              			apiLang: 'NL',
              			module: "clock",
              			position: "top_left"
              				module: 'calendar_monthly',
              				position: 'top_left',
              						// The config property is optional
              						// Without a config, a default month view is shown
              						// Please see the 'Configuration Options' section for more information
              			header: "Feestdagen en agenda",
              				maximumEntries: '10',
              				timeFormat: 'absolute',
              				urgency: 0,
              				getRelative: 0,
              				dateFormat: 'D MMM',
              				fullDayEventDateFormat: 'D MMM',
              				fadePoint: 0.50, // Start on 1/4th of the list.
              				symbol: 'calendar-check-o ',
              				url: 'https://www.mozilla.org/media/caldata/DutchHolidays.ics'
                  				symbol: 'flag-checkered',
                  				url: 'http://localhost:8080/MMM-Formula1/schedule.ics',
              				symbol: 'university ',
              				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-5926e1a950f5588d305e66d8b0af0cfa/basic.ics'
              				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-754f959bc1afb34da4f5ec42e92b1d01/basic.ics'
              				symbol: 'birthday-cake ',
              				url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-2f98381b817baa8eb5bce7f11ac22120/basic.ics'
              			module: "MMM-MovieListings",
              			position: "bottom_left",
                				// Default module config.
              				defaults: {
                  				apiKey: 'xxxxxxxxxxxxxxxxxxxxxxxx',
              				region: 'NL',
                  				language: 'en-EN',
                  				interface: 'poster', //'list', 'poster', 'detailed'
                  				includeMoviePlot: false,
                  				maxPlotLength: 198,
                  				header: 'Nu in de bioscoop',
                  				moviesPerPage: 0,
                  				refreshInterval: 1000 * 60 * 60 * 24, //Once a day
                  				baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
                  				animationSpeed: 2.5 * 1000,
                  				pageChangeInterval: 30 * 1000
                  			disabled: false,
                  			module: 'MMM-NOAA',
                  			position: 'top_right',
              			apiKey: "xxxxxxxxxxxxxxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
              			useAir: true,             // set to false if you do not want to use Air Quality Index
              			airKey: "xxxxxxxxxxxxxx",    // IF you want Air Quality Index
              			pws: "xxxxxxxxxx",         // go here to find your pws: https://www.wunderground.com/wundermap
              			showClock: false,           // Hides or shows clock
              			dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
              			format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
              			ampm: false,                // to show AM and PM on Sunrise/Sunset time
              			showGreet: true,          // deafult is false - to show greeting under clock and above date
              			name: "xxxxxxxx",                  // Your name
              			showWind: true,
              			showDate: false,
              			showForecast: true,         //show bottom 3 day forecast
              			flash: true,                 //Today in forecast flashes halo
              			showUV: true,               //show UV index
                      		showBar: true,             // show Barometer
                      		showHum: true,              //show Humidity level
              			position: 'top_right',       //whatever you have in above position must also be here
                      		alert: true                //show weather alerts default is true
                      		module: 'MMM-Formula1',
                      		header: 'Formule 1 Classificatie',
              			maxRows: 6,
              			season: 'current',
                      		calendar: true,
                      		fade: false,
                      		fadePoint: 0.2,
              			grayscale: false,
                          		// Optional configuration options - see https://github.com/ianperrin/MMM-Formula1#configuration-options
              			module: "MMM-ImagesPhotos",
              			position: "bottom_right",
              			header: "Onze reizen door xxxxxxxxxxxxxx .................",
              			opacity: 1,
              			animationSpeed: 5000,
              			updateInterval: 50000,
              			maxWidth: "100%",
              			maxHeight: "100%",
              			module: "newsfeed",
              			position: "bottom_bar",
              				feeds: [
              						title: "Algemeen Dagblad",
              						url: "http://www.ad.nl/home/rss.xml"
              						title: "Telegraaf",
              						url: "http://www.telegraaf.nl/rss/"
              						title: "Trouw",
              						url: "https://www.trouw.nl/home/rss.xml"
              						title: "Volkskrant",
              						url: "https://www.volkskrant.nl/nieuws-voorpagina/rss.xml"
              						title: "Nu.nl",
              						url: "http://www.nu.nl/rss/Algemeen"
              				showSourceTitle: true,
              				showPublishDate: true
              Thanks!
              Peter
              • cruunnerrC
                cruunnerr
                Thats not what u promised ;)
                You wanted to show your logs.
                Your config is ok. Maybe its one of your modules. U have to try out by disabling them step by step or maybe in blocks.
                Or try to run just default modules.
                But first post your logs. i have been asking for it since the last 3 posts :D
                P 1 Reply Last reply
                  Peter @cruunnerr
                  @cruunnerr , shame on me, you are right!
                  This is my error log:
                  /home/pi/.pm2/logs/MagicMirror-error-0.log last 15 lines:
                  0|MagicMir | npm ERR!
                  0|MagicMir | npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
                  0|MagicMir | npm ERR! Make sure you have the latest version of node.js and npm installed.
                  0|MagicMir | npm ERR! If you do, this is most likely a problem with the magicmirror package,
                  0|MagicMir | npm ERR! not with npm itself.
                  0|MagicMir | npm ERR! Tell the author that this fails on your system:
                  0|MagicMir | npm ERR!     sh run-start.sh
                  0|MagicMir | npm ERR! You can get information on how to open an issue for this project with:
                  0|MagicMir | npm ERR!     npm bugs magicmirror
                  0|MagicMir | npm ERR! Or if that isn't available, you can get their info via:
                  0|MagicMir | npm ERR!     npm owner ls magicmirror
                  0|MagicMir | npm ERR! There is likely additional logging output above.
                  0|MagicMir |
                  0|MagicMir | npm ERR! Please include the following file with any support request:
                  0|MagicMir | npm ERR!     /home/pi/MagicMirror/npm-debug.log
                  Peter
                  • cruunnerrC
                    cruunnerr
                    no need to shame ;)
                    i have had this problem, too.
                    Since i played around with new modules and deleted other modules it doesn’t comes up again.
                    we discussed that issue already here
                    I can’t help u, but maybe it really helps if you would uncomment modules step by step (maybe two at the same time) and wait if the error comes up again.
                    I know, that will take a while, but for me it would be the choice how to solve it.
                    I have no other idea, i am sorry :(
                      Peter @cruunnerr
                      @cruunnerr OK, I will follow your advice.
                      And what to do when I find the module that is causing the ploblem?
                      Delete it and install it again?
                      I love all the modules that I use now, so it would be bad not to have them.
                      Peter
                      Mykle1M 1 Reply Last reply
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Peter
                        @Peter said in Something is wrong ....:
                        Create a new topic asking for help with that specific module that is causing problems. If the issue can be resolved then someone will help you. Or, tragically, if the issue can not be resolved, you may have to live without it. :-)
                          Peter
                          Maybe I found the problem; I think ImagePhotos caused the problem, but not the module but the pictures I used.
                          I had 70 high resolution holiday pictures roulating in the module and every now and then a picture had problems to load.
                          Some pictures were over 6mb.
                          I reseized a lot of pictures and am running over 2000 pictures now without problems (every picture is about 100kb).
                          Pictures are loading much smoother now.
                          Maybe this helps other people too!
                          Peter
                          • cruunnerrC
                            cruunnerr
                            I am glad u found out what causes your problem :D
                            Yeah, the RPi is very limited in processor power. That is the reason, why some users went over to old laptops or small x86 solutions :)
