    How to update the master branch?
    19 Posts 15 Posters 19.6k Views 12 Watching
    • P Offline
      PaulB
      Dear fellows,
      I would like to know how to update the MagicMirror 2 setup. My current problem is following:
      the software tells me that I am 251 commits behind the master branch.
      Unfortunately updating everyhting did not work.
      I updated it via following command:
      “sudo apt-get update && apt-get upgrade”
      Does someone has the same probem?
      Many greetings from Hamburg :)
      • cruunnerrC Offline
        cruunnerr
        thats not how to update MM ;)
        try this:
        cd ~/MagicMirror && git pull
        Keep in mind, that updating COULD result in issues with 3rd party modules, cause not all are up to date and some changes were made in MagicMirror. But in most cases it should be ok.
        • P Offline
          PaulB
          @cruunnerr thank you for your fast reply.
          I ve tried to run it but unfortunately the console tells me to commit changes or to stash them before I can merge.
          Unfortunately I have no clue what this means. Could you help me out? :)
            mochman Module Developer
            Seems like you’ve changed some of the files in the MagicMirror directory. If you want to upgrade you’ll have to stash the changes. run git stash in your MagicMirror directory, then run git pull. Stashing wont affect your config.js or any modules you’ve installed into your modules directory.
            Edit
            @ninjabreadman’s has a better fix for you than I do.
            N 1 Reply Last reply Reply Quote 2
            • N Offline
              ninjabreadman @PaulB
              @PaulB First, make a backup of your install with cp -r ~/MagicMirror ~/MM-Backup. Then run git stash in ~/MagicMirror to temporarily stash your changes so that git can merge all those new commits.
              To merge, run git pull to update your MM install, then use npm install to upgrade or install any new dependencies to the appropriate version.
              Once complete, run git stash apply to reintroduce your changes (while also keeping them in the stash) – you may need to deconflict or otherwise review these changes. You can see your changes with git diff.
              Once you’re happy and MM is running smoothly, you can git stash drop to get rid of the stash. You can run rm -rf ~/MM-Backup once you’re content it’s all working as it should.
              Finally, I recommend you take the opportunity to also run sudo apt-get update && sudo apt-get dist-upgrade npm && sudo dist-upgrade pm2 (I think nodejs should upgrade as a dependency of npm but could be wrong).
              Problem with config or JavaScript? Copy/paste it into JSHint.
              Check out the detailed walkthroughs on install, config, modules, etc.
              E F S 3 Replies Last reply Reply Quote 5
              • N Offline
                ninjabreadman @mochman
                @mochman Thanks! Sorry I subposted on you; I was writing on my phone (so didn’t see your post), plus Mobile Safari really hates the compose window of NodeBB, so it takes forever to post anything decent). That and autocorrect really hates git and npm. Cheers. ;)
                • N Offline
                  navyvette87
                  Thanks guys, I have one more to upgrade. And figure out why MMM-Traffic won’t upgrade, but I think you way around would help that to.
                  MichMichM 1 Reply Last reply Reply Quote 0
                  • MichMichM Offline
                    MichMich @navyvette87
                    cd ~/MagicMirror/modules/MMM-Traffic
                    git pull
                    Restart your MagicMirror and you should be good to go. ;)
                    • E Offline
                      E3V3A @ninjabreadman
                      @ninjabreadman said in How to update the master branch?:
                      Noo! Not a good idea if you’re running on a RPi with small SD card. That is a huge directory: du -sh ./ ~1.3GB, already for a quite small install. You might need that space for the update itself. Never good idea to max out your SD card.
                      Rather use tar, and try one of these:
                      cd ~
                      # remove `v` flag to avoid huge verbose output
                      tar --exclude={.git,node_modules} -zcvf MM_BAK.tgz ./MagicMirror
                      tar --exclude='node_modules' --exclude='.git' -zcvf MM_BAK.tgz ./MagicMirror
                      # This may require you to have the bash shell option globstar' set.
                      # Check with: 'shopt -s globstar'
                      tar --exclude='**/.git/*' --exclude='**/node_modules/*' -zcvf MM_BAK.tgz ./MagicMirror
                      This will avoid getting the huge node_modules and .git directories.
                      (You can always git init and reset your git origin url to git fetch from the resp directories if needed to re-instate.)
                      “Everything I do (here) is for free – altruism is the way!”
                      MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
                      • strawberry 3.141S Offline
                        if you are using mm as supposed to you only need to backup the config.js and custom.css
                        N 1 Reply Last reply Reply Quote 1
                        • N Offline
                          ninjabreadman @strawberry 3.141
                          @e3v3a I take your point; in my case I’m running a reasonable size card and Raspbian/MM are all that is on the card. I do also mention to delete MM-Backup when they’re done. I really just wanted to give them the extra insurance of a full backup. Good call on tar, but they then need to know how to unpack it.
                          @strawberry-3.141 If you’re using git to stash changes, then you’ve clearly modified other files (IIRC, config.js and maybe custom.css are ignored). As above, I just wanted to give extra assurance that they had a full copy if anything went totally awry.
                            Dicous
                            Hallo,
                            noob braucht hilfe =)
                            Wie kann ich bei dieser Fehlermeldung updaten?
                            pi@raspberrypi:~ $ cd ~/MagicMirror && git pull
                            Aktualisiere 8010e62..60b9a5b
                            error: Your local changes to the following files would be overwritten by merge:
                                    modules/default/calendar/calendar.js
                                    modules/default/compliments/compliments.js
                            • F Offline
                              Frans @ninjabreadman
                              @ninjabreadman - I tried to update accordingly your reply but i’m stranded. After git stash the system tells me
                              pi@magicpi:~/MagicMirror $ git stash
                              *** Please tell me who you are.
                              Run
                                git config --global user.email "you@example.com"
                                git config --global user.name "Your Name"
                              to set your account's default identity.
                              Omit --global to set the identity only in this repository.
                              fatal: unable to auto-detect email address (got 'pi@magicpi.(none)')
                              Cannot save the current index state
                              I don’t know how to react on this, you?
                                sdetweil @Frans
                                @frans said in How to update the master branch?:
                                git config --global user.email “you@example.com”
                                git config --global user.name “Your Name”
                                type those commands, add your email and name
                                git doesn’t allow anonymous actions
                                F 1 Reply Last reply Reply Quote 1
                                • F Offline
                                  Frans @sdetweil
                                  @sdetweil said in How to update the master branch?:
                                  Worked!! Thanks!
                                    robiv8
                                    Und was soll uns das sagen?
                                    Any info about this error?
                                    pi@WEG-Infopanel:~/MagicMirror $ git stash
                                    package-lock.json: needs merge
                                    vendor/package-lock.json: needs merge
                                    package-lock.json: unmerged (928d17635a4aff632b96c3d78499948e24eb70be)
                                    package-lock.json: unmerged (1e84cc321d5ecb4199add46a08bfd7f3446d9c11)
                                    package-lock.json: unmerged (281f5adadabad8c0fa36c54a8b5c882b66e06722)
                                    vendor/package-lock.json: unmerged (a326b4026808f4b1ab060fe3c12e385f82330759)
                                    vendor/package-lock.json: unmerged (793948105835abe0d92caaf321cb78150cc983a4)
                                    vendor/package-lock.json: unmerged (9ad15ee58a9adce0f84708789296d2ae2ec1e029)
                                    fatal: git-write-tree: error building trees
                                    Kann den aktuellen Zustand des Index nicht speichern
                                      bhepler Module Developer @robiv8
                                      @robiv8 - You can delete those files and then do another git pull. So:
                                      cd ~/MagicMirror
                                      rm package-lock.json
                                      rm vendor/package-lock.json
                                      git pull
                                      npm install
                                        shazam23 @ninjabreadman
                                        @ninjabreadman I followed these steps and after running git stash apply I still get the “please commit changes” message…I’ve already backed up so unless the new update is thinking it also needs to be backed up I’m lost
                                        • T Offline
                                          tcsabina @shazam23
                                          @shazam23
                                          You have modified files that has not been ‘saved’ in the git database. Type ‘git status’, and it will list those changes.
                                          After that you can decide what to do: keep the changes (in this case use ‘git commit’)
                                          revert or discard the changes (in this case ‘git checkout’ is the command, if I am not mistaken)
                                          Not sure what exactly you try to achieve, but for an update I would use a fresh directory instead. Just create a new one and clone into it…
