    Help getting Magic mirror running on Ubuntu Server 16.04.4 LTS as a SERVER
    6 Posts 4 Posters 4.4k Views 4 Watching
      j-lewis
      I’m trying to install MM on Ubuntu Server 16.04.4 LTS (with all latest patches etc.)
      I am following the manual instructions on https://github.com/MichMich/MagicMirror.
      I:
      • Downloaded and installed the latest Node.js version. (v9.7.1)
      • Cloned the repository and checked out the master branch: git clone https://github.com/MichMich/MagicMirror
      • Entered the repository: cd ~/MagicMirror
      • Installed: (update sudo- does not work I removed it) npm install
      • ran SERVER only node serveronly
      got the following messages:
      Loading module helpers …
      Initializing new module helper …
      No helper found for module: helloworld.
      All module helpers loaded.
      Starting server on port 8080 …
      Server started …
      Sockets connected & modules started …
      Ready to go! Please point your browser to: http://localhost:8080
      I then went on my mac and typed in http://192.168.0.100:8080 (ipaddress of my magic mirror ubuntu server) and got The connection was reset.
      I then tried
      npm run config:check
      magicmirror@2.2.2 config:check /home/ubuntu/MagicMirror
      node tests/configs/check_config.js
      File not found: /home/ubuntu/MagicMirror/config/config.js
      Please note: The second time I ran it I’m getting
      WARNING! Could not find config file. Please create one. Starting with default configuration.
      UPDATE: I think the issue is with the binding on NPM as it’s only binding to the localhost and not to the IP address of the machine. Does anyone know how to fix that?
      HELP!
        Alvinger
        @j-lewis,
        For some reason your config.js file is missing or inaccessible. Can you issue the command
        ls -l /home/ubuntu/MagicMirror/config
        and post the output. It would also be easier to help if you can post the content of the file /home/ubuntu/MagicMirror/config/config.js.
          Mykle1 Project Sponsor Module Developer @j-lewis
          @j-lewis said in Help getting Magic mirror running on Ubuntu Server 16.04.4 LTS as a SERVER:
          Installed: sudo npm install
          Installing dependencies for MM using sudo causes permissions problems
            j-lewis @Alvinger
            ubuntu@UbuntuMagic:~$ ls -l /home/ubuntu/MagicMirror/config
            total 4
            -rw-rw-r-- 1 ubuntu ubuntu 2615 Mar  6 20:19 config.js.sample
            ubuntu@UbuntuMagic:~$ more /home/ubuntu/MagicMirror/config
            *** /home/ubuntu/MagicMirror/config: directory ***
              j-lewis @Mykle1
              @Mykle1 Correct. That was a typo as I was initially having install problems, so I removed the install and did it again without the sudo. The log/error above is after doing the install without the sudo. Sorry for any confusion!
              I think the main issue is with the NPM binding… any idea how to fix that?
              • Y Offline
                yawns Moderator
                the file needs to be config.js, the existing file config.js.sample is just a sample and will be ignored
