Navigation
    • Search
    MagicMirror² v2.15.0 is available! For more information about this release, check out this topic.
    Add module reference to alerts
    Feature Requests
    alert
    • strawberry 3.141
      strawberry 3.141 Project Sponsor Module Developer last edited by
      Hey guys,
      I recently worked on
      and stumbled on a problem. I want to support normal devices and touch screen devices. Non touch screen is working fine already,
      but there’s a problem for the touch screen mode. I added a button but when I fire an alert from the default alert module, there will be an overlay, so my button will not be clickable. To get around this, I thought about adding a reference to an alert, so I can query the alert of my module and give it a click event.
      My thought was to change this https://github.com/MichMich/MagicMirror/blob/master/modules/default/alert/alert.js#L91 to
      message += "<span data-sender='" + sender.name + "' class='thin' style='font-size:22px;line-height: 30px;'>" + params.message + "</span>";
      What are your thoughts on this?
      • MichMich
        MichMich Admin last edited by
        Paging @paviro since he is te writer of the alert module.
        • MichMich
          Can’t you just change the z-index of the button in your module’s CSS file?
          strawberry 3.141 1 Reply Last reply Reply Quote 0
          • strawberry 3.141
            strawberry 3.141 Project Sponsor Module Developer @MichMich last edited by
            @MichMich z-Index didn’t work for me, but with the following code I could achieve what I was trying to do.
            MM.getModules().enumerate((module) => {
                if(module.name === 'alert'){
                    module.alerts["MMM-AlarmClock"].ntf.addEventListener("click", ()=>{this.resetAlarmClock();});
            • MichMich
              So no more change to the core is required?
              • strawberry 3.141
                @MichMich In my oppinion it’s not a good idea to mess around with other modules variables. If someone has a better approach just let me now, but it would work without changes to the core at the moment.
                • paviro
                  paviro Admin last edited by
                  Well feel free to change things in the alert module since it should be rewritten at some point anyway… 😃
