    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 77.6k Views 35 Watching
    • BKeyportB Offline
      BKeyport Module Developer @v4r23
      @v4r23 If you followed the install completely, reboot the system. It’s the one step that fixed it for me.
        MajorC Project Sponsor
        is there a good way to shrink the font size and the icon size?
        I tried
        .MMM-SystemStats {
        Font-size: 70%;
        but now there are a lot of space between each line.
        Or if I use
        transform: scale(0.90, 0.90);
        than the module is moved into the middle of the screen.
        Thank you
          UPDATE:
          I included into the custom.css
           * MMM-SystemStats
          .MMM-SystemStats table {
                  width: 350px;
                  color: #666;
                  font-size: 20px;
          .MMM-SystemStats td {
              line-height: 20px;
          that works for me. Not sure if that was the right way. But hey, its fine.
          BKeyportB 1 Reply Last reply Reply Quote 1
          • BKeyportB Offline
            BKeyport Module Developer @MajorC
            @MajorC That’s the recommended way, actually. CSS should be the place you make LOOK customizations.
            Good job.
            • BKeyportB Offline
              I’m having a heck of a time with the module freezing after a set amount of time. I believe the problem is that it’s freezing due to getting invalid data from my sensor. Is there anyone around that can help me fix it to where it checks the data, so the module continues to work?
              Thanks much!
                MajorC Project Sponsor @BKeyport
                @BKeyport how long is “a set amount of time”?
                Have you tried https://github.com/MichMich/mmm-systemtemperature
                • BKeyportB Offline
                  I just realized I got my modules mixed up. This one works perfectly.
                    joey @BKeyport
                    @BKeyport said in MMM-SystemStats (cpu temp/load, fre ram ...):
                    I was having the same issue, and rebooting fixed it for me. That surprised me, since I have been able to add modules on the fly (ie., without rebooting) so far. However, since MMM-SystemStats has system calls, I guess that is the difference.
                    • H Offline
                      harney
                      Is there any way to add a second drive stat for an SSD. I run my server of an SSD, but would like to add the second SSD to the stats
                      Cheers.
                      Great module
                      • StoffbeuteluweS Offline
                        Stoffbeuteluwe Project Sponsor @harney
                        Hi i try mmm-systemtemperature but it shows (loading…) anybody the same problem?
                          JohnWick128
                          Thanks for the information, It was very helpful.
                            digied
                            Hi! MMM-SystemStats is working fine, but Free RAM shows: NaN%. How can I fix this?
                            • BKeyportB Offline
                              BKeyport Module Developer @digied
                              @digied Did you reboot? Seems to cure a lot of the problems.
                              • N Offline
                                Nneuland @BenRoe
                                @BenRoe
                                Hi Ben! Love the module!
                                Couple questions. My “Avail Space” portion of this module isn’t giving any values. Do you have any idea why this might be? I also am having trouble with the header not showing. My system load peaks around 2, but I’m reading that with a quad core raspi 4b, this is normal.
                                Any input would be greatly appreciated.
                                Thanks,
                                Nick
                                • 4 / 4
