    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 70.0k Views 35 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      This post is deleted!
      • BKeyportB Offline
        BKeyport Module Developer @BenRoe
        @BenRoe Hey, ben - love your module - would like to see a “quick” change if possible. Could you update the module to show both imperial and metric for CPU temp? This is only needed because I’m in a backwards country that hasn’t adopted sensable measurements, and it would be nice to have both temps on screen at the same time, so I can compare easily with others on how cool my system is.
        Thanks!
        • lavolp3L Offline
          lavolp3 Module Developer @BKeyport
          @BKeyport I think this sound more like a change you could do to your own version instead of a general change for the module.
          You could insert e.g.
          this.stats.cpuTemp = payload.cpuTemp + " / " + (payload.cpuTemp * 9 / 5 + 32).toFixed(1) + "°F";
          into line 62
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • BKeyportB Offline
            BKeyport Module Developer @lavolp3
            @lavolp3 that’s not working, just get NaN… I think that’s because the string’s already got the “°C” at that point.
            On another point, how do you link back to the code and highlight like that?
            lavolp3L 2 Replies Last reply Reply Quote 0
            • lavolp3L Offline
              @BKeyport said in MMM-SystemStats (cpu temp/load, fre ram ...):
              You can get a direct link by clicking on the line in github.
              • lavolp3L Offline
                ah the parsefloat is missing.
                How about
                this.stats.cpuTemp = payload.cpuTemp + " / " + (parseFloat(payload.cpuTemp) * 9 / 5 + 32).toFixed(1) + "°F";
                • BKeyportB Offline
                  @lavolp3 That did it, thank you.
                  • uros76U Offline
                    uros76
                    Excellent module, works great.
                    I do have a question. I don’t see all the icons :/ how can I fix this?
                    My magicmirror projects: https://forum.magicmirror.builders/post/79889, https://forum.magicmirror.builders/post/93241 and https://forum.magicmirror.builders/post/94586
                    • BKeyportB Offline
                      BKeyport Module Developer @uros76
                      @uros76 The icons are straight from font awesome, and part of the base package, from what I understand. Not having icons might be indicative of a weak connection to the 'net.
                      • V Offline
                        v4r23
                        missing stats
                        Any idea what’s going wrong that it shows:
                        loading …
                        • 6
                        • 7
                        • 8
                        • 6 / 8
