    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 77.6k Views 35 Watching
    • P Offline
      PhilReis
      Hello, can i view this module only when the CPU temperature is over XX °C?
      • lavolp3L Offline
        lavolp3 Module Developer
        Hello @BenRoe
        I have this module installed for some time and was always wondering how to interprete the “System load” part.
        Now I finally did a bit of research and am still wondering why this value is used. Why is it such an imprtant value for you?
        Also, I’m trying to implement “sd card usage”. I think it’s a quite important value (since my card is quite full :-))
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • ? Offline
          A Former User @lavolp3
          @lavolp3 How about trying MMM-Tools?(https://github.com/eouia/MMM-Tools)
          justjim1220J lavolp3L 2 Replies Last reply Reply Quote 0
          • justjim1220J Offline
            justjim1220 Module Developer @Guest
            @sean
            Got any idea on how to get this and any ofnthe other PC stats modules to show the CPU and GPU temps with Windows PC’s?
            Jim Hallock - 1995
            • ? Offline
              A Former User @justjim1220
              @justjim1220
              See this
              https://stackoverflow.com/questions/24004300/batch-file-get-cpu-temperature-in-c-and-set-as-variable
              • lavolp3L Offline
                lavolp3 Module Developer @Guest
                @sean ooooh that looks good!
                  djuscha
                  I want to move module 10 px to the right. if i change custom css it’s not what i do wrong
                  .MMM-SystemStats  {
                     margin-right: 10px;
                  it does not change even after the reboot
                  • lavolp3L Offline
                    lavolp3 Module Developer @djuscha
                    @djuscha I think you cannot move a module itself. Usually you need to use the main container inluding the content. Here you can try the td with class “title”.
                    .MMM-SystemStats .title  {
                       margin-right: 10px;
                    OR the table itself
                    .MMM-SystemStats table {
                       margin-right: 10px;
                      djuscha
                      @lavolp3 said in MMM-SystemStats (cpu temp/load, fre ram ...):
                      I tried both, that did not work :(
                      • T Offline
                        thedk
                        How can i change the size of the module? Doesnt work for me in custom.css. When i change width or heigt the module moves outside the display.
                        • qu1queQ Offline
                          qu1que Project Sponsor
                          @BenRoe
                          I’ve updated this module to the last version a few days ago. Before the update, it worked perfectly, but now it does not show anything about SystemStats on my smart mirror.
                          I’ve have not changed the lines for this module on the config.js file. They are the same before the update. This is my config:
                                                  module: "MMM-SystemStats",
                                                  position: "top_right", // This can be any of the regions.
                                                  classes: "small dimmed", // Add your own styling. Optional.
                                                          updateInterval: "3000",
                                                          align: "right" // align labels
                          What could be wrong with it? Maybe I would have to add something else in this file after the update?
                          Thanks!
                          Quique.
                            dazza120 @qu1que
                            @qu1que don’t know I had the same thing but I had to delete the JS for it to go on, then it didn’t work with the new JS so I managed to get the JS out of the waste bin and it’s back working again but measuring in kelvin.
                              axis155
                              I also had the same problem. I even removed the module, re-installed, but still cant view it.
                              • CyruS1337C Offline
                                CyruS1337 Project Sponsor
                                I have the same problem. After the upload, it shows me nothing more
                                  Babene1 Project Sponsor
                                  i have a solution,
                                  it is only a comma missing in “MMM-SystemStats.js” in line 20
                                   baseURLSyslog: 'http://127.0.0.1:8080/syslog',
                                  qu1queQ CyruS1337C B 3 Replies Last reply Reply Quote 3
                                  • qu1queQ Offline
                                    qu1que Project Sponsor @Babene1
                                    @Babene1
                                    Thanks! It works for me, that was the problem.
                                      CyruS1337 Project Sponsor @Babene1
                                      @Babene1 It works for me too, thank you !!
                                        bhepler Module Developer @Babene1
                                        @Babene1 - Great work. Did you generate a PR for the module developer?
                                          Babene1 Project Sponsor @bhepler
                                          @bhepler it is a new release with the bugfix from MMM-SystemStats available
                                          • C Offline
                                            chinesesich
                                            I have a mistake, as shown in the figure.
                                            It was good at first, but then it was. I don’t know why.
                                            StoffbeuteluweS F 2 Replies Last reply Reply Quote 0
                                            • 2 / 4
