    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 82.5k Views 35 Watching
      A Former User @justjim1220
      @justjim1220
      See this
      https://stackoverflow.com/questions/24004300/batch-file-get-cpu-temperature-in-c-and-set-as-variable
      • lavolp3L
        lavolp3 Module Developer @Guest
        @sean ooooh that looks good!
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          djuscha
          I want to move module 10 px to the right. if i change custom css it’s not what i do wrong
          .MMM-SystemStats  {
             margin-right: 10px;
          it does not change even after the reboot
          lavolp3L 1 Reply Last reply
          • lavolp3L
            lavolp3 Module Developer @djuscha
            @djuscha I think you cannot move a module itself. Usually you need to use the main container inluding the content. Here you can try the td with class “title”.
            .MMM-SystemStats .title  {
               margin-right: 10px;
            OR the table itself
            .MMM-SystemStats table {
               margin-right: 10px;
              djuscha
              @lavolp3 said in MMM-SystemStats (cpu temp/load, fre ram ...):
              I tried both, that did not work :(
              • T
                thedk
                How can i change the size of the module? Doesnt work for me in custom.css. When i change width or heigt the module moves outside the display.
                • qu1queQ
                  qu1que Project Sponsor
                  @BenRoe
                  I’ve updated this module to the last version a few days ago. Before the update, it worked perfectly, but now it does not show anything about SystemStats on my smart mirror.
                  I’ve have not changed the lines for this module on the config.js file. They are the same before the update. This is my config:
                                          module: "MMM-SystemStats",
                                          position: "top_right", // This can be any of the regions.
                                          classes: "small dimmed", // Add your own styling. Optional.
                                                  updateInterval: "3000",
                                                  align: "right" // align labels
                  What could be wrong with it? Maybe I would have to add something else in this file after the update?
                  Thanks!
                  Quique.
                  D 1 Reply Last reply
                    dazza120 @qu1que
                    @qu1que don’t know I had the same thing but I had to delete the JS for it to go on, then it didn’t work with the new JS so I managed to get the JS out of the waste bin and it’s back working again but measuring in kelvin.
                    • A
                      axis155
                      I also had the same problem. I even removed the module, re-installed, but still cant view it.
                      • CyruS1337C
                        CyruS1337 Project Sponsor
                        I have the same problem. After the upload, it shows me nothing more
                          Babene1 Project Sponsor
                          i have a solution,
                          it is only a comma missing in “MMM-SystemStats.js” in line 20
                           baseURLSyslog: 'http://127.0.0.1:8080/syslog',
                          qu1queQ CyruS1337C bheplerB 3 Replies Last reply
                          Reply Quote 3
                          • qu1queQ
                            qu1que Project Sponsor @Babene1
                            @Babene1
                            Thanks! It works for me, that was the problem.
                            • CyruS1337C
                              CyruS1337 Project Sponsor @Babene1
                              @Babene1 It works for me too, thank you !!
                              • bheplerB
                                bhepler Module Developer @Babene1
                                @Babene1 - Great work. Did you generate a PR for the module developer?
                                B 1 Reply Last reply
                                  Babene1 Project Sponsor @bhepler
                                  @bhepler it is a new release with the bugfix from MMM-SystemStats available
                                    chinesesich
                                    I have a mistake, as shown in the figure.
                                    It was good at first, but then it was. I don’t know why.
                                    StoffbeuteluweS F 2 Replies Last reply
                                    • StoffbeuteluweS
                                      Stoffbeuteluwe Project Sponsor @chinesesich
                                      does the Module work on mac?
                                      C 1 Reply Last reply
                                        chinesesich @Stoffbeuteluwe
                                        @Stoffbeuteluwe
                                        no
                                        on Raspberry Pi 2B
                                        • F
                                          Fifin404 @chinesesich
                                          @chinesesich Same issue… something new?
                                          • lavolp3L
                                            lavolp3 Module Developer @Fifin404
                                            @Fifin404 @chinesesich The issue seems to be the change in version of Font Awesome icons.
                                            Try changing line 122 in MMM-SystemStats.js
                                                    c2.innerHTML = `< i class="fa ${sysData[item].icon} fa-fw"></i>`;
                                            to
                                                    c2.innerHTML = `< i class="fas ${sysData[item].icon} fa-fw"></i>`;
                                            ONLY change the “fa” to “fas”.
                                            The rest can stay the same.
                                            Don’t copy my input! I neede to put in a space for it to be viewable.
                                            • 2 / 4
