    Should I put acrylic mirror behind glass?
    9 Posts 7 Posters 3.9k Views 6 Watching
    • C
      chavenor
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @chavenor
        @chavenor
        Just to be clear, the acrylic mirror would have to be 2-way (sometimes called 1-way). Why are you introducing glass at all?
        • C
          chavenor @Mykle1
          @mykle1 Worried about the chemical resistance of the mirror finish?
          • Mykle1M
            @chavenor
            I’ve only ever used a damp cloth(water) on my acrylic mirror. Doesn’t seem to be any affect. You could put glass in front of it. I don’t see any reason why not.
            • M
              MadScientist
              I would try a thin piece of glass from a picture frame. That can be easily cut and is cheap. You don’t lose much if you’re not happy with the result.
              • dorfman2D
                dorfman2
                One reason I would try adding clear glass. In my mirror setup my 2-way acrylic bows out a little, distorting the reflection just a little. having a flat piece of glass may help alleviate this. Or at least go with the thicker acrylic.
                • B
                  benrules2
                  Any interface you add just introduces more reflection surfaces, so from the side I expect you’d see some ghosted text. If the purpose is to protect the acrylic I think it’s probably overkill.
                  • B
                    bhepler Module Developer
                    My first mirror used acrylic and I didn’t put any glass in front nor behind it.
                    • M
                      MWel1977
                      I just started working on my firts magicmirror
                      And like everybody thought of making a frame with an glas 2-way mirror or an acrylic piece with folie over it.
                      Bot tonight I thought: “Way not putting the folie right over te monitor?”
                      That would eliminate the glas or acrylic part.
