    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.6m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil after a night’s sleep I think I understood…
        Manu85 @sdetweil
        @sdetweil following my last message I did:
        pm2 stop all
        and then I made your script:
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
        then I went to the folder:
        ~/MagicMirror/installers/upgrade.log
        and I copied the last lines of:
        "upgrade started"
        I don’t know if I did the right thing but I took the history of what you asked me to do
        Upgrade started - ven. janv. 26 13:36:00 CET 2024
        system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
        doing test run = true, NO updates will be applied!
        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
        n (node version manager tool) not installed, doing test run, install skipped
        Check current Node installation ...
        Node currently installed. Checking version number.
        Minimum Node version: v18.18.0
        Installed Node version: v14.21.3
        Node should be upgraded.
        Node.js upgrade defered, doing test run
        Check current NPM installation ...
        NPM currently installed. Checking version number.
        Minimum npm version: V9.8.1
        Installed npm version: V6.14.18
        npm should be upgraded.
        npm upgrade defered, doing test run  ...
        saving custom.css
        remote name = origin
        upgrading from version 2.23.0 to 2.26.0
        fetching latest revisions
        git fetch rc=0
        current branch = master
        On branch master
        Your branch is behind 'origin/master' by 213 commits, and can be fast-forwarded.
          (use "git pull" to update your local branch)
        Changes not staged for commit:
          (use "git add <file>..." to update what will be committed)
          (use "git checkout -- <file>..." to discard changes in working directory)
        	modified:   css/main.css
        	modified:   fonts/package-lock.json
        	modified:   modules/default/calendar/calendar.js
        	modified:   modules/default/weather/weather.js
        	modified:   package-lock.json
        	modified:   vendor/package-lock.json
        Untracked files:
          (use "git add <file>..." to include in what will be committed)
        	core
        	css/icons/
        	css/save_custom.css
        	howEnd: false,
        	liceMultiDayEvents: false,
        	modules/default/currentweather/
        	nohup.out
        	tDaysCount: 0,
        	"ter(\"calendar\", {mberOfDays: 365,"
        no changes added to commit (use "git add" and/or "git commit -a")
        there are 6 local files that are different than the master repo
           css/main.css
           package-lock.json
        save/restore files selection = n
        restoring css/main.css from repo
        skipping restore for css/main.css, doing test run
        restoring fonts/package-lock.json from repo
        skipping restore for fonts/package-lock.json, doing test run
        restoring modules/default/calendar/calendar.js from repo
        skipping restore for modules/default/calendar/calendar.js, doing test run
        restoring modules/default/weather/weather.js from repo
        skipping restore for modules/default/weather/weather.js, doing test run
        restoring package-lock.json from repo
        skipping restore for package-lock.json, doing test run
        restoring vendor/package-lock.json from repo
        skipping restore for vendor/package-lock.json, doing test run
        test merge result rc='' , if empty, no conflicts
        skipping merge, only test run
        Checking for modules with removed libraries
        downloading dumpactivemodules script
        updating dependencies for active modules with package.json files
        	processing for module MMM-SmartWebDisplay please wait
        	skipped processing for MMM-SmartWebDisplay, doing test run
        	processing complete for module MMM-SmartWebDisplay
        	processing for module MMM-ISS-Live please wait
        	skipped processing for MMM-ISS-Live, doing test run
        	processing complete for module MMM-ISS-Live
        restoring custom.css
        removing git alias
        Upgrade ended - ven. janv. 26 13:36:17 CET 2024
          sdetweil @Manu85
          @Manu85 but that is test mode, no changes.
          and the changed mm files are still there
          main.css…
          I thought u restored the originals as you migrated the changes…
            sdetweil @Manu85
            @Manu85 as I will be in the car all day,
            make sure to stop mm before running the upgrade
            pm2 stop all
            I added code a few changes ago to detect and stop mm, but it appears not to be working for you
              Manu85 @sdetweil
              @sdetweil Thank you for your answer if I understand correctly for safety I do
              pm2 stop all
              pi@MagicMirror:~/MagicMirror $ pm2 stop all
              after that
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
              that’s it ? and should I pass this line to the root of the MM or in the MM folder
              pi@MagicMirror:~$
              Or
              I’m waiting for your response before making a mistake
                sdetweil @Manu85
                @Manu85 the current directory does not matter,
                the script goes to it on its own
                M 3 Replies Last reply Reply Quote 0
                  Manu85 @sdetweil
                  @sdetweil ok, I’ll try it, I’ll let you know if everything went well…
                    Manu85 @sdetweil
                    @sdetweil I ran your update script, I don’t get an error message, are there any additional operations or do I reboot the pi?
                      Manu85 @sdetweil
                      @sdetweil hello, I did a reboot of the pi and… it restarted magic (like the mirror :-)) I have some small settings for which I cannot find solutions
                      For Weather:
                      the 1st: it’s the temperature which displays more than 280° C, I know that there is global warming but still…
                      the 2nd: the display of the weather forecast for the following days is a little confusing and I can’t find the settings in the console ctrl+shift+i and do you think I can write the sentence “Feels Like” in French?
                      for calendar:
                      I had put icons for each calendar in config.js, 1 for mine, 1 for my wife etc. ex: {
                      symbol: 'male',
                      url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12OfzlWCbJPUrEhN49IHC1yeFEfqRieBnpxxxxxxxxxxxxx'
                      symbol: 'birthday-cake',
                      url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWxxxxxxxxxxx'
                      in the custom css I had added color to each symbol to differentiate them (I saw that it was necessary to change .fa.fa in the custom css to .fas.fa) ex:
                      .fas.fa-male {
                         color: #2B60DE; /* Dodger Blue */
                      .fas.fa-birthday-cake {
                         color: #ff0000; /* Red */
                      .fas.fa-trash-o {
                         color: #00FF00; /* Green */
                      they all work except this one
                      symbol: 'trash-o',
                      for this one I don’t have any symbol
                        sdetweil @Manu85
                        @Manu85 trash-o is just fa.
                        you have .fas.fa
                        which means MUST HAVE BOTH on the same element
                        add a space
                        but also maybe take .fas off
                          sdetweil @Manu85
                          @Manu85 you just restart mm…(pm2 restart MagicMirror)
                          any how, on the weather
                          I think you have a conflict on how the API reports and what the module thinks it is
                          I think the API is reporting in Fahrenheit, but the code thinks in Celsius
                          see config options
                            sdetweil @Manu85
                            @Manu85 of, feels like…
                            see the translations/fr.json
                            its precip
                            percent possibility of precipitation, (rain.snow)
                            chance of rain or snow
                            some languages don’t have a term for that
                            I think you could change it to blank " "
                            but , then this will be a file to watch out for on future upgrades
                              Manu85 @sdetweil
                              @sdetweil ok, thank you for this information, I will try to resolve one by one, to
                              symbol: 'trash-o',
                              I tried all your suggestions and I still have the same result, what is strange is that for the other icons ex:
                              I do have a birthday cake
                                sdetweil @Manu85
                                @Manu85 see this post where someone needed a custom css class setting
                                https://forum.magicmirror.builders/post/114837
                                and your custom.css would have been
                                .calendar .fa-trash-o {
                                right?
                                  Manu85 @sdetweil
                                  @sdetweil I just did like that but still nothing I have the impression that the symbol in my js.config is not known
                                  symbol: 'trash-o',
                                  url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12xxxxxxxxxxxxxxxxxx'
                                  and all other symbols are ok
                                    sdetweil @Manu85
                                    @Manu85 use
                                     "fa-trash-o"
                                      Manu85 @sdetweil
                                      @sdetweil does not work
                                        sdetweil @Manu85
                                        @Manu85 in the developers window what do you see in the html and console tab view , 401, 404
                                        in console tab, put weath in the filter field
                                          Manu85 @sdetweil
                                          @sdetweil is this what is needed?
                                            sdetweil @Manu85
                                            @Manu85 no… you are looking at weather, not calendar for the trash icon
                                            need the line in calendar where it SHOULD BE
                                            sorry, in console should be calen for filter… oops
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
