    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 216.9k Views 28 Watching
    • E Offline
      Escenda
      I don’t get it to work. Followed the instructions in the readme and registered to get th APIkey. But it still doesn’t start.
      What could be wrong? Here is the output:
      magicmirror@2.0.0 start /home/pi/MagicMirror
      electron js/electron.js
      Loading config …
      Loading module helpers …
      Initializing new module helper …
      No helper found for module: faceemployee.
      All module helpers loaded.
      Starting server op port 8080 …
      Server started …
      Connecting socket for: MMM-Facial-Recognition
      Staring module helper: MMM-Facial-Recognition
      Connecting socket for: MMM-ResRobot
      Starting node_helper for module: MMM-ResRobot
      Starting module: newsfeed
      Sockets connected & modules started …
      Launching application.
      Create new news fetcher for url: http://nyhetsbrev.viktoria.se/feed/ - Interval: 300000
      [MMM-Facial-Recognition] Facerecognition started…
      [MMM-Facial-Recognition] Loading training data…
      [MMM-Facial-Recognition] ALGORITHM: LBPH
      [MMM-Facial-Recognition] Training data loaded!
      [MMM-Facial-Recognition] --------------------
      [MMM-Facial-Recognition] PiCam connected
        Alvinger
        Could you please post your config? It seems that MMM-ResRobot is never executed.
        • E Offline
          Escenda
          Here is my config:
          module: “MMM-ResRobot”,
          position: “left”,
          header: “Departures”,
          from: “740059355”, // ResRobot Station ID (or a comma-separated string of IDs)
          to: “740059412”, // ResRobot Station ID of destination (or a comma-separated string of IDs)
          maximumEntries: 6, // Number of departures to show on screen
          truncateAfter: 5, // A value > 0 will truncate direction name at first space after characters. 0 = no truncation
          apiKey: “a6e181d4-3065-4214-a30b-780163xxxxxx” // Your ResRobot apiKey
            Alvinger
            I copied your config and eslint complained about the quote characters. Make sure that you use the standard " character, not “ or ”.
            Using your config with my apiKey works as it should.
            /j
              Alvinger @Notumlord
              @Notumlord and @Klzow, I think I have found the issue. When the ResRobot API call failed for some reason the next update was never scheduled resulting in a “freeze”. I have pushed an update to github which schedules an update when the API call fails. (In my case the ResRobot site returned a “site unavailable” error every now and then which froze the module) Sorry for the bug!
              • K Offline
                Klzow @Alvinger
                @Alvinger Perfect! Thank you very much! Have been running it for 48 hours without any problem now.
                  Alvinger
                  New version out with one minor change: transportation type icons are now displayed (to the left of the linenumber). All rail-bound types are displayed as trains (fa-train), all buses are displayed as bus (fa-bus) and all waterborne transportation is displayed as ship (fa-ship).
                    selarp
                    Thanks @Alvinger for an awesome module! However, I have a problem when I add more than one destination (to:). Displays only the result of the destination that appears first.
                    Here is my config.js:
                        module: "MMM-ResRobot",
                        position: "left",
                        header: "Departures from Skanör C",
                            from: "740000950",   // ResRobot Station ID (or a comma-separated string of IDs)
                            to: "740000003,740001586", // ResRobot Station ID of destination (or a comma-separated string of IDs)
                            apiKey: ”[My API-key]"  // Your ResRobot apiKey
                      Alvinger
                      you need to specify a station id in “from” as well. “from” is used to find the station’s departures, “to” is used to differentiate between destinations going from the “from” station.
                      Change “from” to ‘from: “740000950,740000950”’ to make it work as you want.
                        selarp @Alvinger
                        Of course! Thank you very much @Alvinger!
                        • K Offline
                          Klzow
                          Hi!
                          I have a question /idea /request.
                          Would it be possible to set a limit in minutes in which the module won’t show departures before that limit?
                          For example I have a 15 min walk to bus/subway and during rush hour in Stockholm lots of departures are happening every minute. To be able to plan ahead and see when the bus is leaving I need to show many departures on the mirror to see that far ahead in time. Would it be possible to set a limit to not show departures happening earlier then 15 min ahead since it would not be necessary to know that the subway is leaving in 1 min when I can’t get her there in time to catch it? This would clean up the mirror and save some space on the screen.
                            Alvinger @Klzow
                            @Klzow,
                            That shouldn’t be too hard to do. I will look into it. My current thinking is to introduce a new config value (something like “ignoreBefore=5” with default 0 for backward compatibility) Keep an eye on this thread for developments!
                              Alvinger @Alvinger
                              @Klzow,
                              I’ve uploaded a new version of the module. It has a new config option, skipMinutes, which allows you to skip departures occuring within skipMinutes from now. Feel free to try it out.
                              • FallandeGubbeF Offline
                                FallandeGubbe
                                Hej!
                                Excellent module. Would it be possible to get it to work on Raspberry Pi 1 ? I get it fully working with my Raspberry pi 3 , but when I try with my 1 I get “connection refused” when starting midori…
                                … and when accessing the mirror via Chrome on my PC I see all modules loaded and working…
                                  Alvinger
                                  @FallandeGubbe,
                                  I’m running it on a Raspberry Pi 1 B with 256MB so yes, it’s possible… :-)
                                  You can’t run MagicMirror out of the box but I wrote a post in another thread about it:
                                  [https://forum.magicmirror.builders/topic/1659/3-tries-3-fails-raspberry-b/13]
                                  FallandeGubbeF 1 Reply Last reply Reply Quote 0
                                    FallandeGubbe @Alvinger
                                    @Alvinger Thanks for replying! Yes, I know that Raspberry Pi 1 needs some manual work :)
                                    I followed the tutorial at https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero
                                    and everything is working great! Until I try to install MMM-ResRobot. Something gets messed up apparently… But it works fine on my Raspberry Pi 3 … (same SD card, same image)
                                    OK, I’ll keep investigating then, since you got it working!!
                                      Alvinger @FallandeGubbe
                                      @FallandeGubbe
                                      Maybe a stupid quesrion but did you run npm install after cloning the repository?
                                        @Alvinger No problem :)
                                        Yes , I did. And as mentioned - when I plug the SD-card into my RPi3 all work fine.
                                        When I plug the SD-card in my RPi1 midori won’t connect. If I remove MMM-resrobot from config-file and reboot MagicMirror works fine on my RPi 1 (all other modules load OK)…
                                        I find it strange …
                                          broberg Project Sponsor @FallandeGubbe
                                          @FallandeGubbe @Alvinger could it have something to do with this :
                                          https://forum.magicmirror.builders/topic/922/modules-not-showing-up-on-kweb-or-midori
                                          There are other modules that midori doesn’t like apparently.
                                            Alvinger @broberg
                                            @broberg @FallandeGubbe
                                            One thing popped into my mind: the Pi 1 is much slower than a Pi 3 and loading all the modules takes quite some time. Could it be that you are trying to open midori before MagicMirror has loaded all the modules and therefore is refusing connections? That in itself was the reason I had to go with a script that checked that midori was listening before launching MagicMirror.
                                            Have you checked with journalctl that magicmiror is ready for action?
                                            FallandeGubbeF 1 Reply Last reply Reply Quote 1
                                            • 6
                                            • 7
                                            • 2 / 7
