    MMM-voice
    voice control
    329 Posts 55 Posters 996.3k Views 50 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @Nonamexp
      @Nonamexp are you running the installer as root? all the directories in the screenshot are in root
      D N 2 Replies Last reply Reply Quote 2
      • cowboysdudeC Offline
        cowboysdude Module Developer
        Try to run it like this:
        sudo ./dependencies.sh
          daveyg_71 @strawberry 3.141
          @strawberry-3.141
          I am having trouble getting this module to recognize my USB Microphone.
          I am using this mic:
          https://www.amazon.com/gp/product/B00IR8R7WQ/ref=ask_ql_qh_dp_hza
          I previously used it when I built an Amazon Echo and I didn’t have any problem.
          When I run the installer it returns this:
          INFO] Possible Audio Devices to set in config.js
          0 [ALSA ]: bcm2835 - bcm2835 ALSA
          bcm2835 ALSA
          Do you know if there is any special configuration I need to do to get it find the mic?
            Interesting I’m using the same mic with no issues…
            What are you running it on? RPI 3? I would do this:
            Terminal window:
            sudo apt-get update
            sudo apt-get dist-upgrade
            That will install Pixel - the newest updated version… Then try to find your mic doing this in a terminal window:
            arecord -l
            See what that says… let me know!
              daveyg_71
              I tried the command a record -I
              it returned this:
              pi@magicmirror:~ $ arecord -l
              **** List of CAPTURE Hardware Devices ****
              pi@magicmirror:~ $
              Its just not seeing it. I’m guessing that the mic broke.
              • N Offline
                Nonamexp @strawberry 3.141
                @strawberry-3.141 I’ve conducted the command “sudo bash dependencies.sh”
                I’ve tried the command ‘sudo chmod 777 /opt /home/pi/MagicMirror/modules/MMM-voice’ and than ‘bash dependencies.sh’ and it works!
                  strawberry 3.141 Project Sponsor Module Developer @daveyg_71
                  @daveyg_71 i had this experience couple of weeks ago, what helped in my case was shutdown the rpi switch the microphone into another usb slot an restart the pi, then run the command cat /proc/asound/cards to get the same output as in the installer. Sometimes I had to do it a few times until it worked again. But since two months I didn’t had tis issue again.
                  @Nonamexp Glad you could fix your issue
                  • N Offline
                    Nonamexp
                    This post is deleted!
                    • MichMichM Offline
                      MichMich
                      Awesome work!
                      Would be great if you could configure keywords which show/hide certain modules and configure notifications … something like this:
                      keywords: {
                          'HIDE WEATHER': {
                              hide: ['weather']
                          'SHOW WEATHER': {
                              show: ['weather']
                          'SIMPLE MODE': {
                              hide: ['default','foo','bar'],
                              show: ['simple']
                          'RESTART': {
                              notification: 'RESTART'
                      It might be good to know that I’ll probably be implementing this in the coming weeks: https://forum.magicmirror.builders/topic/241/revising-the-show-hide-mechanism
                        @daveyg_71 when you do what strawberry suggested after you reboot redo the
                        arecord -l
                        Like he said you may have to do it a couple times but it should show you more than likely your mic is 1
                        • 32
                        • 33
                        • 2 / 33
