    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • daenickD
      daenick @strawberry 3.141
      Yes, that was the first thind I do, but doesn´t works…
      Mysteriously after of the installation of MMM-mail could continue
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @daenick
        @daenick so it is installed now?
        • daenickD
          daenick
          No, now I get this:
          alt text
          • strawberry 3.141S
            @daenick looks like you executed the installer with sudo
            daenickD 1 Reply Last reply Reply Quote 0
            • daenickD
              @strawberry-3.141 can try again without restart everything?
              By the way, you are so friendly. Thanks!
              • strawberry 3.141S
                @daenick remove the node_modules folder in MagicMirror/modules/MMM-voice first and go into /root/pocketsphinx and execute sudo make uninstall same in /root/sphinxbase then rerun the installer
                daenickD 2 Replies Last reply Reply Quote 0
                • daenickD
                  @strawberry-3.141 I ran the bash without the sudo. Finish ok
                  • daenickD
                    @strawberry-3.141 Hello Again,
                    Finnaly I got the MMM-voice installed, but how can I set the micro as default? Sometimes the micro can “hear me” but mostly of time no
                    There´s some kind of special configuration with the micro?
                    Thanks!
                    • A
                      Advokaten
                      @strawberry-3-141
                      I get this error (or is it?) when starting MagicMirror.
                      MMM-voice: Starting pocketsphinx.
                      (node:1844) DeprecationWarning: Calling an asynchronous function without callback is deprecated.
                      The microphone icon appears and after it it states “ERROR”, within MagicMirror.
                      Thanks!
                      • strawberry 3.141S
                        @daenick can you give more details about the issue? the only thing that is configurable is the mic the module should use like microphone: 0 or microphone: 1 …
                        @Advokaten what is inside the error.log, if you only can see numbers in there please enable debug: true in the config and share the debug.log
                        A daenickD 2 Replies Last reply Reply Quote 0
                        • A
                          Advokaten @strawberry 3.141
                          @strawberry-3.141
                          error.log says 11111111
                          debug.log in /home/pi/MagicMirror/modules/MMM-voice ? There’s a ton of INFO: lines and at the bottom it says
                          Error opening audio device plughw:1 for capture: Connection refused
                          FATAL: "continuous.c", line 245: Failed to open audio device
                          It works fine with Alexa.
                          EDIT: When I added debug: true to the config file. When MagicMirror is up, it says “ERROR undefined” rather than just “ERROR”, like it did before.
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @Advokaten
                            @Advokaten did you choose the correct audio device id?
                            • A
                              @strawberry-3.141 when installing it said my mic was 1 so that’s what I have in my config. I tried doing microphone: 0 but that didn’t work either.
                              • strawberry 3.141S
                                @Advokaten can you check out this? http://cmusphinx.sourceforge.net/wiki/faq#qfailed_to_open_audio_device_dev_dspno_such_file_or_directory and troubleshoot section here http://robot.laylamah.com/?p=35
                                • daenickD
                                  @strawberry-3.141 The voice recognition works extremely slow. There’s a way to use Spanish as default language for voice commands?
                                  Maybe using Google voice API?
                                  • strawberry 3.141S
                                    @daenick please read this https://github.com/fewieden/MMM-voice#information if you want to use faster detection you have to use a different module as this one will never support online services like google, apple, amazon, etc.
                                    there are some custom language models for other languages https://sourceforge.net/projects/cmusphinx/files/Acoustic and Language Models/
                                    • A
                                      @strawberry-3.141 I’m lost. Still can’t figure out what’s wrong. :(
                                      • strawberry 3.141S
                                        @Advokaten did you try what the second link suggested?
                                        • A
                                          @strawberry-3.141 Yes, sir! The ERROR text is gone. Now it’s displaying “Initialising…” and the mic icon has a slash through it and is blinking infinitely. I bet I’m doing a rookie mistake somewhere.
                                          • strawberry 3.141S
                                            @Advokaten never had this happened before neither did someone report this issue. I would need to see it myself in order to debug it.
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
