    Making my own translation [solved]
    tips and trickstutorial
    10 Posts 4 Posters 7.2k Views 3 Watching
      Rahansen
      Hi guys, wanted to give MM2 a shot since I already had a RPI2 gathering dust :/
      Would really like to have the interface in my native language (Norwegian).
      What would I have to do to use my own translation instead of the other ones?
      • MichMichM Online
        MichMich
        • Copy translations/en.json to translations/no.json.
        • Modify the translations/no.json to Norwegian translations.
        • Add your translation to translations/translations.js.
        And don’t forget to send us a pull request so others can use it as well! :) (Do do this, you need to make a fork of the repository: https://help.github.com/articles/using-pull-requests/)
          Rahansen @MichMich
          @MichMich Did all of the above yesterday, the only result I got was that the wind direction notations only showed as small squares. The rest stayed in English. We use a special character for east (Ø), so maybe that had something to do with it?
          I’ll doublecheck everything when I get off from work, might just be I made a mistake somewhere :)
          MichMichM 1 Reply Last reply Reply Quote 0
          • MichMichM Online
            MichMich @Rahansen
            I quickly tried using the Ø to see if it would give any problems, but it just works fines. (Tested on both the Raspberry and my Mac).
              Rahansen @MichMich
              @MichMich Thanks, got it working fine now. Made a pull request also, might do Swedish and Danish as well as that’s pretty similar to Norwegian : )
              • prototype0815P Offline
                prototype0815
                Does Norwegian have some special characters? What I want to solve is that the special characters of Germany are displayed at the “compliments”.
                I tried to change some occurrences of “UTF-8” to “ISO-8859” but this didn’t work.
                I would appreciate it if someone give me an answer in the near future, because the MM is the birthday present to my girlfriend.
                Wilco89W 1 Reply Last reply Reply Quote 0
                • Wilco89W Offline
                  Wilco89 @prototype0815
                  @prototype0815 said in Making my own translation [solved]:
                  UTF-8
                  Probaly you can try: http://www.theegglestongroup.com/writing/special_chars.php
                  prototype0815P 2 Replies Last reply Reply Quote 0
                    prototype0815 @Wilco89
                    @Wilco89 Thank you, I’ll give it a try this afternoon.
                      @Wilco89 Hey Wilco89, that works like a charm !! I’m very happy that the first solution proposal works at the firt attempt ! Thank you very much !
                      • Wilco89W Offline
                        Wilco89
                        After years of programming & translations I learned a lot. In my own language (frisian) we do use some of these a lot, and in the other language (Dutch) we don’t use them often.
                        But for every starter it can Be a huge problem to solve this very Tiny issue.
                        I Hope you did finish your translation and Made a PR.
