    MMM-GooglePhotos
    294 Posts 56 Posters 371.2k Views 59 Watching
    • K Offline
      kivlow
      I use raspberry pi 3b with raspbian borwser chromium.
      cool i wait :] p.s. express response
      • ? Offline
        A Former User @kivlow
        @kivlow
        I’ve fixed.
        cd ~/MagicMirror/modules/MMM-GooglePhotos
        git pull
        node auth_and_test.js
        You can see like this image;
        When the browser is not be opened automatically, copy the url and paste it into your browser manually.
        • N Offline
          NathTheDude
          Hi Sean,
          Firstly thank you for this, it has great potential and is something that has been missing for such a long time compared to the alternative dakboard that I was forced to use to get photos displayed.
          I have an issue though, I believe I have been through the steps correctly but can not get it to work. When I reboot my RPI2 it looks like the ‘auth_and_test.js’ is ran and this brings up the browser with googlin login and if I follow this through it gives me the code which is the same experience I have when running ‘auth_and_test.js’ in order to get the album id.
          This then repeats itself every 5mins or so…
          I have added the album id in the config.js but it does not seem to matter if I put a correct or incorrect one in here the same happens. It does not look like it trys to put images on the desktop so I don’t think the module is getting that far.
          Any idea what I have done wrong?
          Nathan
          • ? Offline
            A Former User @NathTheDude
            @naththedude
            You mean, your MM is trying to re-auth again(every 5 mins.) right?
            First, you should check whether you have token.json in root directory of MMM-GooglePhotos.
            cat token.json
            It should be something similar with this;
            {"access_token":"...","token_type":"Bearer","scope":"https://www.googleapis.com/auth/photoslibrary.readonly","expiry_date":1533304224450,"refresh_token":"..."}
            Your simptom would happen when token.json is missed.
            token.json should be generated as result of auth_and_test.js
            • N Offline
              NathTheDude
              Hey @Sean ,
              Thank you for your quite reply, you are correct the token.josn file was missing. Looks like I needed to run ‘node auth_and_test’ as sudo for this file to be created. Once I did this the photos started to appear :) just need to configure the size and position now.
              Thank you again.
              Regards
              Nathan
              • ? Offline
                @naththedude good to you.
                The only thing I worry is, if you run as sudo there could be a possibility of a problem to refresh token with proper authority.
                • K Offline
                  kivlow @Guest
                  @sean
                  hello :]
                  I make git pull but nothing change :/
                  still when i wrote in terminal even sudo node auth_and_test.js i get only info that is started.
                  my chromium not open and i dont have any link it termina to past it in chromium :[.
                  • ? Offline
                    @kivlow show me what is seen when you execute node auth_and_test.js. (Do not need to use sudo)
                    • K Offline
                      kivlow
                      • ? Offline
                        @kivlow
                        Hmmm… very weird.
                        Could you try this?
                        nano test.js
                        Then, copy below and paste
                        'use strict';
                        const request = require('request')
                        const Auth = require('./auth.js')
                        var authConfig = {
                          keyFilePath: "./credentials.json",
                          savedTokensPath: "./token.json",
                          scope: "https://www.googleapis.com/auth/photoslibrary.readonly"
                        const auth = new Auth(authConfig)
                        auth.on('ready', (client) => {
                          console.log("auth_and_test started.")
                          var token = client.credentials.access_token
                          console.log("token:", token)
                          function getAlbum(client, pageSize=50, pageToken="") {
                            var url = 'https://photoslibrary.googleapis.com/v1/albums'
                            url = url + "?pageSize=" + pageSize + "&pageToken=" + pageToken
                            console.log("url:", url)
                            request.get(
                              url,
                                json:true,
                                auth: {"bearer": token},
                              (err, res, body) => {
                                console.log("response:", body)
                                if (err) {
                                  console.log("Error: ", err)
                                  process.exit(1);
                                var found = 0
                                for (var i in body.albums) {
                                  var album = body.albums[i]
                                  console.log (album.title, " : ", album.id)
                                  found++;
                                if (body.nextPageToken && found > 0) {
                                  getAlbum(client, pageSize, body.nextPageToken)
                          getAlbum(client, 50)
                        Then, close and save (Ctrl+X and Y and enter)
                        Then try.
                        node test.js
                        And show me the result.
                        • K Offline
                          kivlow
                          :] thx you are the best :]
                          ? 2 Replies Last reply Reply Quote 0
                          • ? Offline
                            @kivlow
                            Ok. Now I think I’ve found what’s wrong.
                            https://github.com/eouia/MMM-GooglePhotos#get-auth-and-albumid
                            You seem to have missed 4. Search for "Google Photos Library API". Select the correct result and click Enable. (You may need to enable "Google Plus" also.)
                            Do 1~4 again.
                            You can access your developer console with URL in the screen also.
                            • ? Offline
                              • K Offline
                                kivlow
                                Ok i got it.
                                I enable Photos Library at different account (i have two google account) so everything works fine right now :]
                                • ? Offline
                                  @kivlow Good to you. It’s my pleasure. Have a nice day.
                                  • K Offline
                                    kivlow
                                    Hello again ;p
                                    I have one question - how to show full picture but in spec dimension.
                                    I use top_right.
                                    I set display 1280x720 and from google 1920x1080.
                                    I see picture from google but many is cut :/
                                    • ? Offline
                                      @kivlow
                                      mode:’cover’ will cover your entire target area, but cropped.
                                      mode:’contain’ will show entire image but resized(with black borders)
                                      • K Offline
                                        kivlow
                                        :thumbs_up:
                                        works fine :]
                                          bchabbert
                                          i have a problem when i paste my code error message:
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ cat toto.txt
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node auth_and_test.js
                                          Opening OAuth URL.(https://accounts.google.com/o/oauth2/v2/auth?access_type=offline&scope=https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fphotoslibrary.readonly&response_type=code&client_id=491102864701-4kg1b7lbb90bt2vsc0cuh5af5acefgje.apps.googleusercontent.com&redirect_uri=urn%3Aietf%3Awg%3Aoauth%3A2.0%3Aoob) Return here with your code.
                                          Paste your code: 4/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                          (node:3967) UnhandledPromiseRejectionWarning: Error: Error getting tokens:
                                          at oauthClient.getToken (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:93:24)
                                          at /home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/google-auth-library/build/src/auth/oauth2client.js:158:46
                                          at
                                          at process._tickCallback (internal/process/next_tick.js:182:7)
                                          (node:3967) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
                                          (node:3967) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                          Can you help me please ?
                                          Bérenger.
                                          • ? Offline
                                            A Former User @bchabbert
                                            @bchabbert
                                            Hmmm… I think, your oAuth was failed. But I cannot figure out what was wrong at that moment. I suggest you to try again from scratch.
                                            • 14
                                            • 15
                                            • 2 / 15
