    How to develop modules
    5 Posts 4 Posters 14.1k Views 4 Watching
    • N Offline
      Nikhil
      I am aware of python core, nodejs and javascript. I am running magic mirror with the available third party apps at the magic mirror repository. Now I want to develop some other modules, so what are the other programming languages I need to know to develop magic mirror modules? Can someone please post a tutorial about how to develop the modules?
      • ? Offline
        A Former User @Nikhil
        @nikhil
        • https://github.com/MichMich/MagicMirror/blob/master/modules/README.md
        • https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
        You’d better start from modifying any simple 3rd-party-modules.
          doubleT Module Developer
          I’d second that.
          For a quick overview:
          The DOM (all visible elements) is based on HTML, styled with CSS and usually filled with content and function by Java Script. That’s all you need for basic modules.
          If you go further, you’ll need Python in case you have something connected to the Pi andnodeJS for advanced modules with some backend code, like API calls, though some nodeJS knowledge will help you a lot to understand the whole structure in the first place.
          jQuery can be a helpful Java Script library.
          API calls usually deliver JSON or – rarely – XML, but both should be familiar if you know JS objects and arrays and HTML.
          As Sean said, playing around and manipulating existing modules should help you a lot. Go through the code, see if you understand the connections and find out what happens if you manipulate it.
          Your most important tool when working in js-files is the browser console where you can print to with the js code console.log("show me the content of var x: " + x); MM code Log.info("show me the content of var x: " + x);
          • ? Offline
            A Former User
            I wrote this;
            https://forum.magicmirror.builders/topic/8534/head-first-developing-mm-module-for-extreme-beginners
            1 Reply Last reply Reply Quote 5
              I wrote this 8 months ago and it may help someone. It’s meant to be used as a learning tool for beginner module creators.
              https://github.com/mykle1/MMM-UFO
