MagicMirror sleep in 5 minutes
Hi!
I’m finishing my MagicMirror and have one problem. Raspberry is going to sleep after 10-15 minutes. Monitor is connected to electricity over moving sensor, so Monitor is after 12 min off power. When (moving sensor) turn on monitor, Raspberry is on idle so I have to move the mouse or keyboard to wake it.
Is any possibility to set MagisMirror to be on all the time? -
Have you disabled the screensaver? May I suggest installing xscreensaver? In the options of xscreensaver you can disable the screensaver altogether. When your monitor comes on, MM will be visible.
@mykle1 I’ll try that today :)
Thanks -
Great!
I’ve done it with xscreensaver. Perfect.
Thanks!!! -
Fantastic! Now if you would mark the post that solved your issue. :-)
@mykle1 said in MagicMirror sleep in 5 minutes:
I did that on behalf of @matimilko
@yawns said in MagicMirror sleep in 5 minutes:
That’s because you’re awesome! :-)
Cold you please post the command you use after installing xscreensaver
Simply type
xscreensaverin your terminal and Enter. Click Settings and you choose your options here.
